Muff's Modules & More cats and modular synths, but mostly cats
| View previous topic :: View next topic |
| Author |
Few questions... |
mangros Learning to Wiggle
  Posts: 29 Location: Manchester, UK
Posted: Mon Jul 09, 2012 1:07 pm Post subject: Few questions... |
I'm well impressed by what I've seen of Silent Way. I have a few questions I haven't seen asked here... any info would be appreciated.
Firstly I've got a Saffire LE interface. This isn't DC capable but has coax SPDIF out - so the product I'm looking at getting is the ES-4. Will any interface doing SPDIF work or is there some incompatibility out there?
Secondly most of my gear is DIY 5U 15V with 1/4inch jacks. I'll probably end up building a 15>12V circuit or proper 12V supply with some jack adaptors - does the ES-4 need a 5V line? Would it be ruined (or behave unreliably) if I tried to run it from 15V, and if so are there are any plans to do anything in 5U/15V land?
Thirdly, out of interest I installed the plugins and made up a basic rectifier cable just to see what results I could get. However I can't get that far. I'm using Live 8.2.5 on Win7 and SW AC encoder causes crashes every time. It happens the moment I flick to another track. When I return to the SW track, all the SW VST GUIs are blank. Live becomes unresponsive and will then crash after a minute or so. I've tried 1.7.1 and the latest beta from the links in this forum, both have the same effect.
It doesn't actually seem to do anything, even if I manage to stay on the same track. I've tested my rectifier cable and it will give out reasonably steady DC if I send some fast sinewaves through it and play with the track level. _________________ http://soundcloud.com/radiantsuicide |
| Back to top |
os Super Deluxe Wiggler
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
