motm/modcan b series in a dotcom cabinet
sandyb
Post by sandyb » Sat Jul 18, 2009 12:12 pm
this has come up a few times recently and in the past so here's some information on mixing motm format (which includes modcan b series) modules into a synthesizers.com cabinet. i'm only talking about the wooden cabinets here - not racks.
there are three main things to consider.
first, how to physically mount the motm format modules (height issues)
second, what number of each module format can you fit? (width issues)
finally, powering the motm format modules. there's a post about this already so i'm not going to cover the subject here.
viewtopic.php?t=1739
mounting issues - height
dotcom and motm format modules are technically the same height. the real difference is the fact that dotcom format modules have a lip at the top and bottom which motm doesn't.
here's a picture of the dotcom lip:
and here's a picture of a motm module showing that the module is straight with no lip at the top or bottom:
the mounting holes of motm format modules are also placed at a slightly different vertical height to those on dotcom. this means that if you place a motm format module on the floor of a dotcom cabinet its mounting holes will not reach the top rail completely. to counter this you need to make sure that any motm format modules are centered in the rails before you drill mounting holes for them. the picture below shows in red the gap that i've left in order to centre the module.
actually mounting motm modules is fairly straighforward. the rails of dotcom cabinets are made of wood and can be easily drilled out for motm. i've found that the holes for motm do not interfere with the dotcom holes that are already present. mark the holes making sure the module is centered as mentioned above. drill the hole with a 1mm or 2mm bit. i usually then screw in one of the mounting screws to "tap" the hole before i actually mount the module. the motm mounting holes will be closer to the edge of the rails than the dotcom ones. the picture below has motm holes marked in green and dotcom in red:
here's a picture of the two formats together (don't worry about the gap here - it's just that i didn't replace modules i'd pulled to take the mounting hole photos)
mounting issues - width
so now you need to consider how many of each module you want in the case.
1 dotcom unit = 2.125 inches.
1 motm unit = 1.75 inches.
these are the widths of single space modules.
22 space dotcom cabinets have rails 46.75 inches wide
the figures below show all the combinations of dotcom format modules and motm format modules you can have in a 22 space dotcom row.
the table shows:
number of single space dotcom format modules
resulting space remaining (in inches) in cabinet
number of (whole) motm format units available
the gap (in inches) that will remain when the case is full
as you can see some combinations work better than others. 8 dotcom format and 17 motm format spaces is the magic figure where you have no gap at all. note that i think this table will only work if you mount all the motm format modules in a block together and the dotcom ones together. sticking them in between each other would, if you used the pre-drilled dotcom mounting holes, mean more gaps. you could of course drill different dotcom mounting holes in the relevant place(s) to leave you with the smallest possible gap. i'm planning on having 3 dotcom modules in my case. this means i have 23 motm format units to play with. i'll have a gap of 0.12 inches which i can live with!
sandy
dude
fuck yeah!
Post by dude » Sat Jul 18, 2009 12:39 pm
your posts are so thorough and informative! you have been so helpful yet again! thank you.
drewtoothpaste
Post by drewtoothpaste » Sat Jul 18, 2009 3:09 pm
Great info and just in time for me, as I recently bought a MOTM module to go in my dotcom cabinet. :)
What power setup are you using to power the motm/dotcoms? I've got the QPS1 power supply and figured on using the motm-.com adapter that .com sells, but this is only good for one module - do you have a motm bus-board?
sandyb
Post by sandyb » Sat Jul 18, 2009 3:17 pm
drewtoothpaste wrote:Great info and just in time for me, as I recently bought a MOTM module to go in my dotcom cabinet. :)
thanks.
i use a QPS1 power supply with one of the STG busboards these days as having a whole dotcom cable harness for 3 modules was a pita. when i had lots of dotcom and only a few motm i used a motm 995 adaptor board powered off one leg of the dotcom cable harness. there's links for all these in the power distribution thread if you need more details.
sandy
Post by JohnLRice » Sat Jul 18, 2009 3:22 pm
Great post, Sandy! :party:
Scaff
Elbe Kontrollspannungsverein
Post by Scaff » Sat Jul 18, 2009 7:15 pm
I have MOTM 995 on my QPS1 and also a board from cotk. This works great with my frankensynth with motm,cotk,modcan,anyware-instruments, dotcom and moonmodular. Its great to have the choise now!
If your system doesn't sound good enough, you haven't spent enough
Scaff
Post by Scaff » Sat Jul 18, 2009 7:16 pm
:emt:
drewtoothpaste
Post by drewtoothpaste » Sat Jul 18, 2009 9:05 pm
Scaff, I'll probably get one'a those - along with a VCEG from moon once I get around to clearing out some room in the cabinet!
doctorvague
ole fuckity fuck
Post by doctorvague » Thu Sep 03, 2009 10:25 am
I'm not sure if this has mentioned in exactly this way, but it works out for me that 6 adjoining MOTM spaces fills 5 adjoining dotcom spaces pretty perfectly. It's an easy rule of thumb for my simple brain.
pugix
Post by pugix » Tue May 18, 2010 5:29 pm
I know this is an old topic. Just to add this link to my dot com cabinet page.
http://pugix.com/synth/synthesizerscom-motm-cabinet/
I have only MOTM/Modcan modules in my dot com cabinets. I used rails supplied by Larry Hendry, but you can get these rails now from Bridechamber.
The cabinets are very nice and the depth is just right.
Richard
http://www.pugix.com
Dob
Post by Dob » Mon May 09, 2011 12:23 pm
Thanks for bringing up this old topic. Great info, will come in handy soon!
The Hamburglar
Post by The Hamburglar » Fri Jul 22, 2011 4:25 pm
Can you put Modcan B / MOTM in a .com portable system?
dude
fuck yeah!
Post by dude » Fri Jul 22, 2011 4:29 pm
different rails methinks
Henfield
Better Chemistry through Sound
Post by Henfield » Fri Jul 22, 2011 8:02 pm
The Hamburglar wrote:Can you put Modcan B / MOTM in a .com portable system?
The simple answer is yes, as the rails are the same wooden rails that are in the studio cabinets, with one caveat: You have to watch the mounting depth as is only around 5" from the front of the rail to the back of the cabinet. Actually, I just checked the Dotcom site and it lists the mounting depth as 5.25", so you would have to check the MOTM or Modcan modules. Just remember that you also need to mount a power supply inside the cabinet as well, which restricts the cabinet depth in that area.
Juxwl
Come for our...uhhh...corn?
Post by Juxwl » Tue Dec 27, 2011 5:04 pm
Thanks for the info. I've been trying to find the perfect mixture of MOTM and Dot com.
T S
Post by T S » Wed Jul 04, 2012 4:39 am
Does anyone have details on this?
I know the portable22 cabinet has 5.25" behind the modules and most MOTM modules are 4.5" is there space for a PQS1 power supply? The MOTM-900 power supplies are unavailable at the moment
Tom
sandyb
Post by sandyb » Wed Jul 04, 2012 1:18 pm
Tom
welcome to the forum.
i doubt you'd fit a 4.5" deep module in a space in front of the power supply. but, with a bit of careful module placement you should be ok with a pqs1 in there. just stick your shallower modules in front of it.
Post by JohnLRice » Wed Jul 04, 2012 1:43 pm
Tom
Maybe check out the ones mecanikill sells here? They use the Power-One MAP series switching supplies and are a lot shallower than the linear Power-One (QPS) supplies.
viewtopic.php?t=56165
T S
Post by T S » Wed Jul 04, 2012 3:25 pm
Thanks guys, really appreciate the advice, both are great ideas... just need to make a decision now or try and find an MOTM-900
sduck
experimental use of gravity
Post by sduck » Wed Jul 04, 2012 3:47 pm
Contact Paul Schreiber directly - he'll sell you a 900. Or tell you how to get one. I just bought one from him recently.
The Hamburglar
Post by The Hamburglar » Thu Nov 08, 2012 10:16 pm
For anyone still wondering, my portable dotcom case has Modcan b / MOTM/ and inexplicably both MOTM and MU format Oakley from krisp1.com. I just placed the modules where I wanted them, penciled in a guide for myself, and drill baby drilled.
It's as simple as this: 5 MU = 6 MOTM.
odecahedron
Post by odecahedron » Mon Dec 10, 2012 12:02 am
for those who want the best of both worlds...
im about to build a 2-tier cabinet to house a dedicated row of MOTM and a dedicated row of MU, surely im not the only 5U user to have this notion so thought it may be beneficial to post a relative-width chart here for a visual aid
obviously the best matching "total" widths are 14MU-17MOTM, and then 23MU-28MOTM with almost zero "leftover", tho a couple other combos are pretty damn close.
myself- im probably going to go 18MU-22MOTM - this produces a mere 3 or 4 mm gap on the MU row, which i think i can easily live with, or perhaps could be filled with some kind of thin veneer at one of the ends.
ill post a pic of the actual thing once its completed.
pugix
Post by pugix » Mon Dec 10, 2012 8:04 pm
Thanks for that diagram. I never realized that the spacing would be so even with 23 MU to 28 MOTM. I adapted the QCS22 (22MU wide dot com slant cabinet) to MOTM, which fits 26 MOTM 1U widths. There's a bit of leftover space at the ends. Kinda handy for ventilation, actually. :)
Richard
odecahedron
Post by odecahedron » Mon Dec 10, 2012 9:14 pm
yeah i dont really see leftover as a big problem - its an aesthetic thing i guess... 'module tetris' so to speak. i chose the 22MOTM-18MU cos its about the same approximate length as my Juno which the modular sits above.
odecahedron
Post by odecahedron » Mon Dec 10, 2012 9:15 pm
actually i would love to see other examples of combined formats in this way (dedicated rows) - no idea how you'd search such a thing tho
Return to “5U Format Modules”
