Choices: Possible to dismount the joystick for travel?
Gear, Suggestions and Discussion.
Moderators: Kent, infradead, computer controlled, flight
Knights Who Say Neve
Post by Knights Who Say Neve » Wed Oct 03, 2012 11:57 am
I am putting together a mobile system. I am wondering if it's possible to dismount / remount the joystick arm from the unit to get a little more clearance.
RealDudes
Lives in a Dudeplex
Post by RealDudes » Wed Oct 03, 2012 12:08 pm
IIRC the pots that are controlled by the stick are held in with screws and the base of the shaft goes into these guide things. looks like a pain to have to put together and take apart, seems like having a taller lid on your case would be a much more elegant solution
edit to add photo and this: when the stick is all the way down, it's not much taller than the knobs, like maybe a quarter inch or so
the most important track you'll ever make is the next
https://soundcloud.com/doom_asylum
https://soundcloud.com/wade_blazer
Umcorps
Will patch for food
Post by Umcorps » Fri Oct 05, 2012 8:02 am
You can unscrew the handle from the shaft. If you lie the stick down after doing that its about the same clearance as the knobs. But, as has been said, its not much bigger if you leave the handle attached, plus you don't have to work about losing it.
I have managed to completely dislocate the stick on mine by closing my case without remembering to lie the stick down first. I managed to pop it back into place without problem but I wouldn't recommend it as a routine course of action. :hihi:
flight
The Plague Bearer
Post by flight » Thu Oct 11, 2012 5:56 pm
All in all, a taller lid is the only real choice. You can remove the joystick on the pre-r2 versions, but be careful with the old type with three screws, as that holds the stick itself into the main joystick assembly.
Umcorps wrote:You can unscrew the handle from the shaft. If you lie the stick down after doing that its about the same clearance as the knobs. But, as has been said, its not much bigger if you leave the handle attached, plus you don't have to work about losing it.
This only works on the cylindrical handles. The tapered style are epoxied at the factory.
:doh:
I'm-a pretend I didn't read that.
~flight
flight(at)flightofharmony(dot)com
http://www.flightofharmony.com
Return to “Flight of Harmony”
