Intellijel Planar - Vector Mixer / Quad Panner 14hp
Goto page 1, 2, 3 ... 18, 19, 20  Next [all]
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Eurorack Modules
Author Intellijel Planar - Vector Mixer / Quad Panner 14hp
intellijel
Last Visit: 21 May 2013
PostPosted: Wed Oct 10, 2012 9:03 pm    Post subject: Intellijel Planar - Vector Mixer / Quad Panner 14hp Reply with quote Add User to Ignore List
This module has been in development for almost a year.
Thanks to David for his ingenious way of implementing the vector mixing (among other things in the design) and Haven for coming up with the name and some great feature ideas.
This has to be one of the most fun modules we have ever played with! With just a few audio and CV sources and some interdependencies (i.e use the Joystick CV to simultaneously modify the signals being processed by the VCAs) you quickly get highly complex sounds that you can easily control and play with.
Features:
-Vector mixing: put up to four sources into inputs A, B, C and D and then use the joystick to create the vector mix. Positioning the joystick in any corner will isolate that particular source. Putting the joystick in the center will create an even blend of all four sources. Resulting mix is taken from the MIX output.
-Quad Panning: Plug one source into input A and steer it to outputs A, B, C, D. You can also do stereo panning by just using a pair of outputs.
-SENSE gate output. This is a slew detector which means the gate is only active when you are moving the joystick. Excellent for driving envelopes/VCAs to coordinate so that the output mix is only heard/used when the joystick is being moved.
-Manual gate output: pushbutton to manually trigger a second gate output
-CV outputs: The joystick produces either unipolar (0-5V) or bipolar (-5 to +5V) switchable outputs.
-CV Inputs: The module accepts X and Y axis inputs. By using out of phase LFO sources (such as outputs from the Dr. Octature) you can create really interesting swirling/circular patterns.
This input is also very useful when coordinated with a CV recorder. You can record the modulation from the X, Y outputs and then turn the joystick off (see switch at top left) and playback the modulation into the X and Y input.
This will allow you to recreate a complex quad panning or vector mixing jam.
REVERSIBLE! The module will ship with a second faceplate that is designed to mounted upside down (so joystick is at the bottom) and there are jumpers on the back of the module so you can coordinate the reversed orientation of the joystick. This is to facilitate use in a skiff.
*I will post photos of the reverse faceplates when they arrive next week.
These are almost complete in production. Ready to ship by next week!
The joysticks used are very expensive and have a long lead time (plus large minimum order). As a result this batch is going to be kind of limited.
MSRP $340. 14hp skiff friendly
* The part # for the knurled nut driver tool is :
382-0006 @ Mouser.com
www.twitter.com/intellijel
www.youtube.com/intellijel
www.vimeo.com/intellijel
www.soundcloud.com/intellijel
www.facebook.com/intellijel
www.intellijel.com
stellvia
Wibbly-wobbly timey-wimey
PostPosted: Wed Oct 10, 2012 9:08 pm    Post subject: Reply with quote Add User to Ignore List
Sweeet!
And number 2 release is up hihi
www.eschelyn-music.com
www.caprycon.net
http://soundcloud.com/eschelyn/
FS: uVCA V1, STG .COM, Malekko Output, Chaos Brother, DIY'd PEG
intellijel
PostPosted: Wed Oct 10, 2012 9:09 pm    Post subject: Reply with quote Add User to Ignore List
stellvia wrote:
Sweeet!
That's it for today :p
Now I need to go finish manuals and demos.....
www.intellijel.com
reppiks
Obscure Intergalactic Destroyers!
PostPosted: Wed Oct 10, 2012 9:14 pm    Post subject: Reply with quote Add User to Ignore List
i have no idea how i can possibly not need this
TOKYO FESTIVAL of MODULAR 2013: http://tfom2013.tumblr.com/
NEW RELEASE: http://pro-noise.com/album/mutant-circuitry
LIVE! http://www.youtube.com/watch?v=2WxYl97OMhA
LIVE! http://www.youtube.com/watch?v=5JJq58nUd-I
Albums: http://daveskipper.bandcamp.com/
stellvia
Oh dear, no Pulse Tornado for exper today hihi
Keep up the great work Danjel. Loving the modules (my new uScale should arrive in the next hour or so!) applause
www.caprycon.net
reignbear
PostPosted: Wed Oct 10, 2012 9:15 pm    Post subject: Reply with quote Add User to Ignore List
i knew there was a reason i kept putting off buy a joystick for my girlfriends little video set-up...
Matos
Modular masturbator
PostPosted: Wed Oct 10, 2012 9:16 pm    Post subject: Reply with quote Add User to Ignore List
Sorry exper. Keep your chin up lad.
This looks sweet as hell. Nice job!
www.joylessrapture.tumblr.com
Last Visit: 20 May 2013
PostPosted: Wed Oct 10, 2012 9:18 pm    Post subject: Reply with quote Add User to Ignore List
Just wow. SlayerBadger!
stk wrote:
You don't change the MakeNoise, it changes you Om
My current system:
http://www.modulargrid.net/e/racks/view/5549
Help Muff out and donate. He could use it right about now.
rico loverde
PostPosted: Wed Oct 10, 2012 9:23 pm    Post subject: Reply with quote Add User to Ignore List
one of these and 2 jags = boner
works for Malekko Heavy Industry
View user's profile Send private message Send e-mail Yahoo Messenger
ringstone
antipodean experimentalist
PostPosted: Wed Oct 10, 2012 9:24 pm    Post subject: Reply with quote Add User to Ignore List
Damn! Make it make some noise please... dying to hear what it can do!!
Blair
Ecclesiastical Scaffolding Facebook
Mindless Eye * Soundcloud
some noise
tronabetes
PostPosted: Wed Oct 10, 2012 9:59 pm    Post subject: Reply with quote Add User to Ignore List
Oh man!, I need at least two of these.
Kalerne
PostPosted: Wed Oct 10, 2012 10:05 pm    Post subject: Reply with quote Add User to Ignore List
i love quadriphony so Dead Banana
WA JIE MENG XUN !
new 12" LP devoted to Taiwanese Frogs & Modular Synthesis ! :-)
Check it here : http://www.iniitu.net/
keetz
Last Visit: 30 Mar 2013
PostPosted: Wed Oct 10, 2012 10:12 pm    Post subject: Reply with quote Add User to Ignore List
MY ASS IS BLEEDING
What a great design. The sense output is a brilliant idea. I was just about to pull the trigger on a second FoH Choices, obviously glad I didn't! This will be right at home next to my JAG.
What's fucking horrible though, is that this will of COURSE require a second JAG.
I'm scared of the fact that I no longer excitedly use terms like "I WANT this module!" or "that'd be cool to have", its devolved into a deadpan, matter-of-fact "yup, I need that."
hamburgerlady
PostPosted: Wed Oct 10, 2012 10:16 pm    Post subject: Reply with quote Add User to Ignore List
True that!
Soundcloud / Moduluxxx 2013 - May 24 & 25, Sydney
WTB: Cylonix Cyclebox (ver II) / TipTop BD909 / Bubblesound uLFO / Intellijel Dixie v1 / Intellijel uStep / Plan B Model 23 ASR
amnesia
PostPosted: Wed Oct 10, 2012 10:26 pm    Post subject: Reply with quote Add User to Ignore List
Quad Panner?
You need a quad output module next :-)
vicmod records
vicmod blog
modular vids
tumblr its in my brain now
discog
cray news
radiodread87
PostPosted: Wed Oct 10, 2012 10:51 pm    Post subject: Reply with quote Add User to Ignore List
Looks fantastic Danjel! well done!
www.equinoxoz.com
infoequinoxoz@equinoxoz.com
numan7
numan "sonic" seven
PostPosted: Wed Oct 10, 2012 11:07 pm    Post subject: Reply with quote Add User to Ignore List
woah foly huk... these Intellijel hits just keep on coming! we're not worthywe're not worthywe're not worthy
SlayerBadger! i needs 2 of 'em! thumbs up
cheers
"if you want to raise some hell, VCO2 is your friend - just set the sub pitches to modulate each other in a feedback loop. and enjoy the chaos... " -- karl ekdahl (poster) Viking
artisokka
PostPosted: Wed Oct 10, 2012 11:11 pm    Post subject: Reply with quote Add User to Ignore List
Dead Banana Dead Banana Dead Banana
Awesome design!
dequalsrxt wrote:
fat is warmer than digital is analog, except when it's more west than east, in which case cold is the hotness, but not very musical.
John Noble
Pining for the fjords
PostPosted: Thu Oct 11, 2012 12:37 am    Post subject: Reply with quote Add User to Ignore List
Nice to see some new analog controller action!
http://eurorackdb.com/node/1332
Variable Resistor at The Eurorack Database: http://eurorackdb.com
Ask me about custom passive Euro modules!
Music: http://soundcloud.com/prettyhowtown/
Dr. Sketch-n-Etch
PostPosted: Thu Oct 11, 2012 12:45 am    Post subject: Reply with quote Add User to Ignore List
We had a lot of fun developing this one -- I got to flex my design muscles and incorporate some pretty cool innovations under the hood, prototyping and debugging went pretty smoothly, and then, the first time we played with the prototype, it was obvious that this was probably the sickest module we've ever done. It is just insanely fun to play with.
I'm really looking forward to the videos on this one.
Also, with four speakers, there is a very cool panning trick you should be able to do with Planar + Doc Oc + uFade which involves sending the audio around the room at different speeds and in different directions, and using the joystick to focus the sound in different locations. Basically, you take one sine wave output of Doc Oc to Planar X, and two other sine wave outputs at +/- 90 degrees to the uFade inputs, then take the uFade output to Planar Y. The Doc Oc frequency sets the CW or CCW speed of rotation at the extreme pot settings of the crossfader (and it can be rotating at audio rates), and the crossfader pot sets the speed and direction (in the centre, the rotation comes to a stop). If the joystick is on, then moving it should focus the rotation to tight circles in the soundspace. I'm not sure how this is going to feel to people standing inbetween the speakers, but I'm really looking forward to giving it a try.
And this abundance of technical means allows the heart to overflow freely.
Olivier Messiaen (1908-1992)
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Eurorack Modules All times are GMT - 5 Hours
Page 1 of 20
