| View previous topic :: View next topic |
| Author |
QMMG: Am I the only one that... |
LDT The Modu-Lars
    Posts: 750 Location: Copenhagen, DK
Posted: Sat Aug 15, 2009 5:10 pm Post subject: QMMG: Am I the only one that... |
... is driven nuts by the lack of attenuation?
I have just spent my first couple of hours "quality time" with the QMMG, and first of all, let me say that it sounds absolutely great.
But guys, does any of your oscillators have attenuators on their outputs? No? Thatīs what I thought. And we tend to put vcoīs in filters donīt we? And what happens if you put an unattenuated vco into the QMMG? You get a very nice overdriven sound. On my other filters, if I want the clean sound, I turn down the input attenuation. Blablabla, yes I am stating the obvious here and, yes I have at the moment four passive attenuators that I can use, but dammit I have to use them ALL THE TIME now as the QMMG donīt even have attenuation on the cv inputs. (You can however use one of the channels in vca mode to attenuate an incoming cv on another channel).
Of course nobody ever said that it had attenuators. I just have to admit that it is only after actually working with it that it really got under my skin just how annoying that is.
And sorry, but one more party-killer: That huge *THUD* when you switch mode. I always thought that switches were great for performance oriented work, but switching from "both" to LP seems to be a no-no on a big sound system.
What breaks my heart is that it sounds so good  _________________ -Lars
Do not attempt to buy anything from Randal/Synthcase.com ! The poor guy needs professional help, but not funded by our money.
www.soundcloud.com/terkelsen-machine www.myspace.com/ldterkelsen www.larsdanielterkelsen.dk www.flickr.com/larsdaniel |
| Back to top |
wetterberg Super Deluxe Wiggler
    Posts: 7656 Location: Copenhagen, Denmark.
Posted: Sat Aug 15, 2009 5:43 pm Post subject: |
yes, you ABSOLUTELY need to have attenuators for it - as a VCA you don't really need it, imo, but for the other modes, absolutely.
A quad attenuator near the QMMG is a really good idea  |
| Back to top |
felix Loves the manuals!
      Posts: 3819 Location: San Jose, CA
Posted: Sat Aug 15, 2009 5:45 pm Post subject: |
I wouldn't say I'm bothered by it, but I do wish it had attenuators on the inputs, although for me I want them on the various CV inputs. But I generally want that on all modules.
Maybe this is why the line is drawn. It's obviously an already large module, and large modules have a hard time selling in Euro, so adding attenuators for each input (at the least for audio and gate level) would add at least 8HP, likely more. And it would ruin the lovely symmetry of the module.
*And* there's always the argument that static input attenuators don't add anything when you want to vary the amount of input via voltage control. You'd still have to have another VCA.
FWIW, I usually end up using one channel of the QMMG as an attenuator of signal for some other channel of the QMMG. The normalization and gate modes almost beg for that to be done. But, if you're mixing 4 signals together, you're out of luck there.
In terms of the audio ins being sensitive (overdriven with non-attenuated inputs), get in touch with Tony, there might be a way to calibrate it so that it's less overdriven. _________________ dress yourself for the public. you now must exit your home and acquire a dental mirror and lubrication!
http://felixinferious.blogspot.com
http://felixinferious.bandcamp.com |
| Back to top |
dougcl Number 6
    Posts: 4000 Location: Portland OR
Posted: Sat Aug 15, 2009 6:05 pm Post subject: |
| Never once thought it needed anything. I use it as a pair of two-channel LPGs as suggested by Tony. First channel is LP, second is BOTH. Typically ADSR-VC2 is driving it, so I can back off the decay or increase the attack to get whatever depth of modulation I'm after. Recently I did discover how well the output attenuation on the M10 works with the QMMG though. |
| Back to top |
Posted: Sat Aug 15, 2009 6:11 pm Post subject: |
| dougcl wrote: | | Recently I did discover how well the output attenuation on the M10 works with the QMMG though. |
Yeah, I always noticed that with the M13 as well. I always figured that the reason that the M10 had the attenuator on the output as because there was no input control attenuation on the M13. _________________ dress yourself for the public. you now must exit your home and acquire a dental mirror and lubrication!
| Back to top |
NV Super Deluxe Wiggler
Posted: Sat Aug 15, 2009 6:49 pm Post subject: |
Just to play devil's advocate I think there's room for four passive attenuators on the QMMG faceplate, although that would mean choosing between the audio or the CV inputs which would ultimately please some of the users and annoy the rest. A solution to that would be to add a small switch beside the pot to switch the attenuator between the inputs. I think a configuration like that could fit on the faceplate and would be simple to integrate circuitry-wise, but it would require a panel and PCB redesign which is hardly something most designers crave doing and can end up becoming an expensive endeavor.
From the other perspective however, every system could use more free-floating attenuators in my opinion - nearly every input and output out there could use an attenuator, and maybe 1 in 20 actually have them. The merits of integrated vs. isolated attenuators is a topic in itself though, so I won't drag it in here.
Passive attenuators are so cheap and easy to build that I think it's something every modular owner should try DIYing at least once. It's DIY at its easiest and you can comfortably fit 2 on a 4HP panel, 4 on an 8HP panel, or 6 on a 10HP panel for about $10-$15 if you're crafty, or go for broke and mash 20 on a 1U panel. |
| Back to top |
revmutt Knutty For Knobs
    Posts: 1074 Location: NYC
Posted: Sat Aug 15, 2009 8:45 pm Post subject: |
just took a joy ride with the bastard for the first time. I patched up something simple with a bunch of LFO's, a pair of modulating AFGs, a Plague Bearer and had the whole thing clocked to a Binary Zone.
Can you say delicious?
-no with a German accent!
The shit was growling, mellow, cool and smooth with no additional attenuation. Mind you I didn't do any kind of fully feeding back shit with it but it was very easily controlled. |
| Back to top |
blungo2 wiggly wiggler
    Posts: 1430 Location: the high cold desert
Posted: Sat Aug 15, 2009 9:13 pm Post subject: |
| I'm just learning about modular synthesis, so for my very basic patches i only occasionally need to use attenuation. Not so much to get a clean signal, but more to balance the mix level to the QMMG. |
| Back to top |
Posted: Sat Aug 15, 2009 9:52 pm Post subject: |
Having only just bought this unit, can anyone verify whether switching modes on the current model is a bit noisey?
Even using a single channel, I find the click to be rather loud. |
| Back to top |
Posted: Sat Aug 15, 2009 9:59 pm Post subject: |
I'm not amplifying mine very loudly, but the click is not too bad with mine. |
| Back to top |
Posted: Sat Aug 15, 2009 10:06 pm Post subject: |
I just looked and I hadn't attenuated up for the lower sound source. As soon as I lowered the volume on the monitors and switched input sources all was good.
Doh! |
| Back to top |
incekt Veteran Wiggler
    Posts: 677 Location: milwaukee wi
Posted: Sun Aug 16, 2009 12:45 am Post subject: |
what oscillators are you running into the qmmg? afg straight through the qmmg vca turned all the way up and there is no distortion on the oscilloscope... _________________ free modular industrial albums at www.incekt.com |
| Back to top |
REwire Super Deluxe Wiggler
     Posts: 1878 Location: Los Angeles
Posted: Sun Aug 16, 2009 3:01 am Post subject: |
I think the QMMG was created to be the first full Euro version of Buchla 292's 4 LP Gates (model 13 being half that). The adding of HP and Resonance was to spice it up make it more useful as a multifilter, but the first intention of it being 4 VCA's is why it doesn't have attenuators, as most VCA's don't. They attenuate the output but not the input.
The 292 and other VCA's are usually used after mixers and filters so it's easy to scale volumes before they get to them. If you are going raw osc to the QMMG and getting distortion I bet the same would happen if you went right into other VCA's. As I use mixers for all my oscs, they are all balanced before going to attenuated and unattenuated filters and then to the QMMG.
As for attenuators, the Model 36 leveler is great and soon the Doepfer A-182 and 83 will be out. Attenuators on PWM are the most missing thing I find annoying (even new Macbeth Osc doesn't, as for M15 and Asys RS-95's, all my fav oscs). _________________ http://www.REwireMusic.com |
| Back to top |
Reptil In space no one can hear you wiggle
    Posts: 1504 Location: low orbit
Posted: Sun Aug 16, 2009 3:39 am Post subject: |
I get the point, but..
OMG guys, we're into modules. respectfully, just get an attennuator module. (a-183-1 ??)
why does everything have to be inside ONE module? I don't get that.
ok, space requirements etc. but having everything prepatched limits flexibillity.
| Back to top |
LDT The Modu-Lars
Posted: Sun Aug 16, 2009 3:41 am Post subject: |
| Quote: | | so adding attenuators for each input (at the least for audio and gate level) would add at least 8HP, likely more. And it would ruin the lovely symmetry of the module. |
I dunno, but as I see it, you can easily have pots and four jacks per 8hp (one channel). So four channels like that, and you have a module that is 32hp but has attenuation on inputs AND cv (symmetry easily obtainable).
| Quote: | | In terms of the audio ins being sensitive (overdriven with non-attenuated inputs), get in touch with Tony, there might be a way to calibrate it so that it's less overdriven. |
Oh no, I love the overdriven sound. I even expect it as other filters I have are like this. But they also have attenuation so you have the choice. Not as something that you actively must add, but as an intuitive no-brainer. An example is my RS-110: I set the input to 3 for a clean vco sound, and the whole range from 3 to 10 gradually changes the character (particularly in regard to the behaviour of resonance).
| Quote: | | The merits of integrated vs. isolated attenuators is a topic in itself though, so I won't drag it in here. |
I donīt mind, - it is a very relevant discussion.
| Quote: | what oscillators are you running into the qmmg? afg straight through the qmmg vca turned all the way up and there is no distortion on the oscilloscope...
I was using the MFB02 and RS-90. I wouldnīt call it distortion (though technicly one could say that any change is distortion). I would call it at a soft overdrive, mostly noticably with resonance a bit up. Try this:
Take a vco driven by a sequencer in a arpeggio like pattern (to cover several frequencies -makes the changes in sound more clear). Put it through an attenuator and into one channel of the QMMG set to LP. Set the filter frq and resonance medium-ish. Run the output into an attenuator too. Turn the first att. to max and the second att. around 10 oīclock. Let the sequence play as you slowly turn the input att. down while you turn the output att. up, thus keeping the volume as steady as possible. Notice the very nice sonic change. _________________ -Lars
| Back to top |
LDT The Modu-Lars
Posted: Sun Aug 16, 2009 3:48 am Post subject: |
| Quote: | | The 292 and other VCA's are usually used after mixers and filters so it's easy to scale volumes before they get to them. If you are going raw osc to the QMMG and getting distortion I bet the same would happen if you went right into other VCA's. As I use mixers for all my oscs, they are all balanced before going to attenuated and unattenuated filters and then to the QMMG. |
Differences in cultures I suppose. For me, it is not a Buchla module. For me it is "just" a module is my euro system. I "grew up" with Asys modules, and I am used to having attenuation on filter inputs AND vca inputs. Sorry, I guess I am spoiled. _________________ -Lars
| Back to top |
LDT The Modu-Lars
Posted: Sun Aug 16, 2009 4:04 am Post subject: |
| Quote: | | OMG guys, we're into modules. respectfully, just get an attennuator module. (a-183-1 ??) |
I do understand that.
| Quote: | why does everything have to be inside ONE module? I don't get that.
ok, space requirements etc. but having everything prepatched limits flexibillity. |
I have a hard time understanding how some integrated attenuation on my QMMG would limit flexibility. Yes, that attenuator would only serve one purpose, but it would not take up much space, would be infinitely intuitive to use and would not add to the cable clutter. In performance youīd better not get the idea to attenuate, if you donīt have the attenuator patched already.
If you are so sure that prepatching (integrating) an attenuator is such a bad idea, I wonder why so many modules have attenuation. OMG to having a modular made to suit this "nothing prepatched" concept. Every single module removed from its attenuators
But donīt worry, my QMMG will soon be flanked by two 138-1īs.
No further response on the loud THUD from the switch? Hmm, I guess I am strange. _________________ -Lars
| Back to top |
Robba Wiggling with Experience
    Posts: 420 Location: Netherlands
Posted: Sun Aug 16, 2009 4:46 am Post subject: |
| Sometimes I hear the loud thud. No allways, my guess is that it depends on the signal going through. |
| Back to top |
LDT The Modu-Lars
Posted: Sun Aug 16, 2009 4:54 am Post subject: |
| Quote: | | my guess is that it depends on the signal going through. |
Yes, and how you switch. Mine is bad from both to LP, but not so bad the other way.
| Quote: |
+1 on that. I will have a 183-1 sitting right between my RS-90īs. Iīve got 4 183-1īs on order plus a 183-2 and a 183-3. _________________ -Lars
| Back to top |
Posted: Sun Aug 16, 2009 7:35 am Post subject: |
mine thuds, too - but I do my switching before feeding audio through, most times.
/goes back to drawing up attenuator panels. |
| Back to top |
