SnazzyFX Ardcore
Discussion and Support for our Atmospheric Modification Devices.
Moderators: Kent, infradead, loss1234
Pighood
SnazzyFX Ardcore
Post by Pighood » Mon Dec 10, 2012 10:33 pm
I have decided to mandate one of these in every case. CAPICHE? :bacon:
matttech
Post by matttech » Tue Dec 11, 2012 4:44 am
i kind of fancy one in my skiff, so that i can change its function on a regular basis, depending on the other modules i've selected at the time....but still not sure how well we'll get on
thelizard
in it for the money
Post by thelizard » Tue Dec 11, 2012 5:19 am
Mine just arrived today. I was using it as a Euclidean Sequencer clocked by Wogglebug and triggering a Maths, which resulted in 45 minutes of recording. So far, I've only tried about 4 patches. Each patch really is like having a new module. Having this next to my Z-DSP = :bacon:
I'm going to try porting over some of my chaos generating code from DrawJong and see what I can get.
exeterdown
Wiggling with Anxiety
Post by exeterdown » Tue Dec 11, 2012 6:12 am
I'm definitely interested, but feel a bit intimidated about programming it myself. How easy is it?
ikkini
Post by ikkini » Tue Dec 11, 2012 6:20 am
Without programming you'll already have days and days of fun !
As I have a small configuration (6U), tha Ardcore is awesome ! Each time I miss a module to achieve something, the huge library of sketches helped me find a solution !
matttech
Post by matttech » Tue Dec 11, 2012 6:31 am
i reckon it could replace things like the Noiesring, or Turing Machine quite easily
Neo
Post by Neo » Tue Dec 11, 2012 7:56 am
it's dead simple to program. if you've done any coding before you'll love it (well i do)
bodo
Post by bodo » Tue Dec 11, 2012 11:30 am
Really happy with mine as well, so many great sketches out there, whom are relatively easy to modify.
thelizard
in it for the money
Post by thelizard » Tue Dec 11, 2012 4:01 pm
exeterdown wrote:I'm definitely interested, but feel a bit intimidated about programming it myself. How easy is it?
It uses a language almost identical to Processing, which is essentially a simplified version of Java. The hardest part would be audio programming, if you're not familiar with DSP. However, CV/clock programming is a cinch.
It's much, much easier than Z-DSP, which uses assembly. However, the Z-DSP is a lot better for effects. Ardcore is 8-bit, so you can use it for glitchy audio, but it shines with CV and clocking. They sit right next to each other in my portable 6U system.
Matos
Modular masturbator
Post by Matos » Tue Dec 11, 2012 4:03 pm
I love my ardcores. I have two and the sequencers are so fun and useful. Great fucked up dirty oscillators and plenty of cv madness. Good times all around.
Pighood
Post by Pighood » Tue Dec 11, 2012 11:09 pm
I don't mind that it's 8-bit. KRÃœNCHÂ¥ :fap:
chisel316
Post by chisel316 » Tue Dec 11, 2012 11:35 pm
matttech wrote:i reckon it could replace things like the Noiesring, or Turing Machine quite easily
I've made some sketches including a simple NoiseRing and extremely simple Rene.
viewtopic.php?t=70929&highlight=
viewtopic.php?t=72906&highlight=
viewtopic.php?t=73185&highlight=
Peace \/
chisel316
withakay
Post by withakay » Wed Dec 12, 2012 4:53 am
I have been pondering this for a while, finally decided to order a PCB and DIY myself up and Ardcore. :bacon:
vonkhades
Post by vonkhades » Sun Jul 21, 2013 4:01 pm
withakay wrote:I have been pondering this for a while, finally decided to order a PCB and DIY myself up and Ardcore. :bacon:
A friend of mine is trying to DIY one too... do you have any schematics/eagle you could share??
makers
Post by makers » Fri Aug 02, 2013 3:50 am
This thread has alot of info:
viewtopic.php?t=75848&highlight=ardcore
Collinrudolph
Post by Collinrudolph » Fri Aug 02, 2013 7:24 am
Has anyone used it for drums? How does it sound?
pedroflute
Ardcore "Analog Tracking Generator"/"Curve Re
Post by pedroflute » Tue Oct 29, 2013 7:18 pm
Hi there... Is there a sketch to reshape the curve-response of an incoming input CV? --à la NI Reaktor's Ctrl. Shaper 3 BP Event Processor &/or Oberheim Xpander's "Tracking Generator"?
http://www.musicsynthesizer.com/DIY/Gra ... ister.html
…Kinda "CV programmable Waveshaper" [please see description below taken from Reaktor's manual page 419]
THANKS!! God bless!!!
PS. [taken from NI's Reaktor's manual page 419]; "Event signal shaper with piecewise linear input/output curve and three fixed breakpoints. The output produced by linear interpolation between the given points.
• 100: Output value at In = 1 (100%).
• 75: Output value at the upper breakpoint at In = 0.75 (75%).
• 50: Output value at the middle breakpoint at In = 0.5 (50%).
• 25: Output value at the lower breakpoint at In = 0.25 (25%).
• 0: Output value at In = 0 (0%).
• In: Event input for the signal to be shaped
• Out: Event output for the shaped signal
BELOW FROM http://en.wikipedia.org/wiki/Oberheim_Xpander
Tracking Generators - there are three tracking generators available for each voice. The tracking generator provides a mapping from a control source (e.g. key range on the keyboard, or volume pedal, or mod wheel) to a modified output, based on the user-defined settings of the generator.
Return to “SNAZZY FX”
