Banana Frac: The Definitive Guide
Goto page Previous  1, 2, 3, 4  Next [all]
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Fractional Rack Modules
Author Banana Frac: The Definitive Guide
parasitk
I Play Loco Gigs
Last Visit: 25 May 2013
PostPosted: Thu Oct 15, 2009 1:00 pm    Post subject: Reply with quote Add User to Ignore List
Thank you!
BananaPlug wrote:
The jack incorporates the equivalent of a SPDT switch. The Blacet jacks I've seen are not in little plastic boxes so if you look carefully at the mechanics of the switch you can actually see what's going on. The extra wire for the switch usually goes to a pad marked with an S. If something is plugged in, the jack's tip connection is whatever was plugged in. Unplug that cable and the signal on the wire from the S pad is hooked up instead.
So while that basically makes sense, I'm still not exactly clear on how you'd wire it up with a banana and SPDT switch. oops Sorry!
I, Parasite | Synth fuckery on Soundcloud
dkcg wrote:
But in the end, it felt like I was playing WiiSoundMasterJedi.
View user's profile Send private message AIM Address
BananaPlug
Last Visit: 24 May 2013
PostPosted: Thu Oct 15, 2009 1:54 pm    Post subject: Reply with quote Add User to Ignore List
You know how a switch works, right? Now look at the jack and see what the little bits of metal do when you plug something into it. Got it? Now ignore the ground wire. What's left is two wires and a switch. Bingo.
DGTom
PostPosted: Fri Oct 23, 2009 8:36 pm    Post subject: Reply with quote Add User to Ignore List
Fellow banana fracers,
just wondering if anyone has converted Blacets Micro LFO to nanners & would lend me the wisdom of yr experi-ances with regards to dealing with these pesky board mounted sockets hmmm.....
I have two ideas; first is expand the holes of the sockets towards the edge of the panel - drawback being an odd shaped hole & possibly a gap that will need a washer behind the banana.
2nd idea; (leaning in this direction at the moment) expand the size of the pot holes so that they & the board can be scooched over to the right, freeing up enough room on the left - drawback is misalignment between the knob & the ring of dots, but, this might make some room on the left for a switch to replace the normal in the Rate CV socket...
Plan to use a pull-up resistor on the Gate input, much like BananaPlug has described for the BZ Gate(Rst) input, hopefully that will work here.
Part of me is hoping that once I get the socket holes drilled out I'll get lucky & the bananas will just fit in... somehow I doubt it cry
DGTom
PostPosted: Sat Oct 24, 2009 11:51 pm    Post subject: Reply with quote Add User to Ignore List
Well, after playing around & taking a closer look I realized the best way to do it will be to remove the pots & LED from the board & mount the PCB on stand-offs, little trickier, but will be alot neater than hacking the panel.
DGTom
PostPosted: Mon Oct 26, 2009 8:34 am    Post subject: Reply with quote Add User to Ignore List
They said it couldn't be done.... no wait, they said it probably shouldn't be done... wait, whose 'they' ... what?
nanners It's peanut butter jelly time! Dead Banana ambulance
wetterberg
Last Visit: 16 Mar 2013
PostPosted: Mon Oct 26, 2009 3:07 pm    Post subject: Reply with quote Add User to Ignore List
that is dope, son!
View user's profile Send private message AIM Address MSN Messenger
the bad producer
PostPosted: Mon Oct 26, 2009 4:01 pm    Post subject: Reply with quote Add User to Ignore List
that looks tricky DGTom nanners , did the pull-up resistor work?
Charlie
http://loudestwarning.tumblr.com/
DGTom
PostPosted: Mon Oct 26, 2009 7:48 pm    Post subject: Reply with quote Add User to Ignore List
Yeah, exactally the same set-up on the Micros Gate In as on the Binary Zones Gate(Rst) - so after I got the latter to work as per BananaPlugs posts I did the same thing on the Micro, 220K from the socket to the switch pad on the PCB. The panel switch selects between the internal pulse or the socket for the Rate CV, which is awesome! Kinda thinking of putting a Centre Off in there so you can toggle between skewed waveshape / normal / CV'd without touching the pot.
I'm buzzing now the headache has worn off, that was easily the hardest one of the lot, the last few modules should be a breeze.
Love your blog Charlie, gave me an idea for converting the Quad Mix VCA - bring the internal Bias Voltage out to a socket = Global Volume control / multi-purpose CV source SlayerBadger!
Almost run of of nanners now! Gotta email Bugs grin
parasitk
I Play Loco Gigs
PostPosted: Fri Nov 06, 2009 2:04 am    Post subject: Reply with quote Add User to Ignore List
So as posted elsewhere, I bananafied all of my Frac modules except my two Wiards. I'm leaving the Borg alone, because I still might sell it, depending on how I feel about the 292c clones I'm building. The Noise Ring just kind of scares me – I definitely need to talk to someone who's done this (Tom Bugs was suggested in another thread).
Binary Zone and Quad VCA are half finished because I don't have any switches here at the moment, nor 220K resistors. I also somehow killed the 4204 on the BZ. So I have a Mouser order to place tomorrow.
N00b questions:
Switch terminology still confuses me – what kind of switch should I be looking for?
The 220K "pullup" resistor is just a standard 220K resistor, right? "Pullup" is just describing what it's doing?
And finally a pic:
I also have some "in progress" pics here: http://twitpic.com/photos/parasitk
BananaPlug
PostPosted: Fri Nov 06, 2009 9:05 am    Post subject: Reply with quote Add User to Ignore List
Yup, pulling up the voltage.
panda30y
PostPosted: Fri Nov 06, 2009 9:42 am    Post subject: Reply with quote Add User to Ignore List
I believe you would want a spdt with a On-none-On configuration.
BugBrand
Knowledge of Bugs
Last Visit: 23 May 2013
PostPosted: Fri Nov 06, 2009 9:47 am    Post subject: Reply with quote Add User to Ignore List
Which may also be referred to as SPDT C/O --- that means Single Pole (one switch element) Double Throw (can go two ways) Centre Off (has a central position where no connection is made)
http://www.bugbrand.co.uk
http://www.bugbrand.blogspot.com
parasitk
I Play Loco Gigs
PostPosted: Fri Nov 06, 2009 11:47 am    Post subject: Reply with quote Add User to Ignore List
Thanks guys, I'll be ordering stuff today! applause
johnnymad
turbo wiggler
PostPosted: Fri Nov 06, 2009 12:48 pm    Post subject: Reply with quote Add User to Ignore List
thumbs up nice work, Chris!
www.soundcloud.com/johnnymad
www.youtube.com/therealjohnnymad
rezzn8r
Aural Enthusiast
PostPosted: Fri Nov 06, 2009 8:20 pm    Post subject: Reply with quote Add User to Ignore List
here's to success with the 929 Chugging Beers
perhaps you'll think of me if selling the borg help
WTB: Miniwave Vowels & GR-New ROMs
http://analognoisemonster.bandcamp.com/
http://www.youtube.com/user/rezzn8r
DGTom
PostPosted: Fri Nov 06, 2009 8:30 pm    Post subject: Reply with quote Add User to Ignore List
+1 on the centre off toggles, I'm thinking I will swap out the standard ones I have in the MicroLFO & BZ right now, having an off position, especially with the BZ, is crazy usefull.
I really like the Modcan A scheme on the Fracs grin
I'm gonna do the QMVCA this weekend, I'll let you know how the Bias Out goes SlayerBadger!
BugBrand
Knowledge of Bugs
PostPosted: Sat Nov 07, 2009 5:46 am    Post subject: Reply with quote Add User to Ignore List
parasitk wrote:
.. The Noise Ring just kind of scares me – I definitely need to talk to someone who's done this (Tom Bugs was suggested in another thread)...
It was actually relatively easy (as was the Borg) - I think Indexofmetals had a JAG too which I said NO to due to board mounted jacks (it could be done but would have been tricky and I didn't have the time).
Here's the pic I sent IoM after mod:
Jacks simply replaced with bananas (little bit of hole size increasement) and two sub-mini switches added for the normalization.
Sub-mini switches, if I remember right, were the only ones that'd fit without obscuring lots of the lettering.
parasitk
I Play Loco Gigs
PostPosted: Sat Nov 07, 2009 9:45 am    Post subject: Reply with quote Add User to Ignore List
Thanks for the info and pic! You wouldn't happen to have a pic of the back of the module would you? oops
BananaPlug
PostPosted: Sat Nov 07, 2009 10:58 am    Post subject: Reply with quote Add User to Ignore List
Bugs, when replacing normals like Ext Rate with switches I connect the jack to one side of a spdt switch, the wire feeding the circuit to the middle and the alternate source to the other side. That way when Ext Rate is switched to use the signal from Aux out, it's also disconnected from the jack so you don't have the possible problem of shorting two outputs together.
Maybe your tiny switches are spst though.
parasitk
I Play Loco Gigs
PostPosted: Wed Nov 18, 2009 8:57 pm    Post subject: Reply with quote Add User to Ignore List
My Binary Zone is fixed! Thanks to BananaPlug and DGTom for all the tips and help.
I punched a new hole for the switch, and left the jack where it was. I replaced the 4024 chip and all functions as expected. Did the pullup resistor thing, but I haven't tested it yet. I never really use that jack anyway oops
Next to finish: The QuadVCA and tackle that Noise Ring!
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Fractional Rack Modules All times are GMT - 5 Hours
Page 2 of 4
