HELP! - MOTM 1190 frac Rack
Author HELP! - MOTM 1190 frac Rack
chamomileshark
I'm just installing my new MOTM 1190 Frac Rack. I can see it emphasised in the instructions that for this module the white is +ve (unlike the filter where red +ve)
Maybe I'm missing something but that makes it very hard to connect to the module (and to the power Blacet power supply).
Am I reading this wrong? If not, do you have any suggestions? (I'm totally impractical so you'd need to be very clear).
(I've sent an e-mail to Paul but I was really hoping to get this set up today)
e-grad
Do you have a DMM or any other device featuring a continuity tester?
If so look for an IC on the board with a pin out known to you (or with datasheet available on the net). Use the tester to determine + and - power rails.
chamomileshark
Nope. Nothing here.
It's more a case of the connector doesn't fit naturally that way. It is the opposite of the filter. I've looked at the instructions, they are clearly different polarities, it's even highlighted in the instructions for the VCA.
But as the connector format is as normal it means the thing just doesn't want to fit!
chamomileshark
Just to completed this, I had an e-mail exchange with Paul last night and it seems there is an error on the instructions..plus that error is repeated on thw Analogue Haven site. He's puting it right now.
jackv
Well... this really explains why I had to push so hard to get the power cable attached a couple weeks ago... I did think it was a bit strange to design the cable to have this problem built in, but the instructions were so emphatic about putting the white to positive... I guess I could reverse it now, if I can get the plug off without breaking anything... but will it make any difference, since all that matters is that positive is to positive and negative to negative right?
Anyway thanks for posting this thread!
chamomileshark
I'm not sure. Maybe if it is working leave it as it is.
You are right about the emphasis. It was even hand highlighted in yellow on my instructions.
jackv
Well I pondered it and decided it shouldn't make any difference and was switching some power cables around anyway so I switched BOTH of the (molex-type) connectors around and nothing got fried.
Now I'm working on connecting the grounds of three power supplies (doepfer, blacet and cyndustries) in order to connect banana to 3.5mm patch cables per the description at http://www.newmusiccircle.org/mm1.htm
so there will be more finger crossing in a few days...
