Dual TM3030 Midi problem
Author Dual TM3030 Midi problem
Scorchi
OK, I've just rebuilt my dual TM3030 (after swapping out unit 2 fro midi controllers for a work project).
Since I first built it I now have a Midi DAC on the modular (Krisp 1 built). When I use the Midi Thru on the dac to run TM3030 I get missed notes and stuck slide and no midi to unit 2.
When I run direct to TM3030, Unit 1 is fine and Unit 2 still gets no Midi. Its the same when I run both off separate midi interfaces (but thats a pain).
Heres a pic of my midi wiring which worked fine with initial build.
Any ideas? Cheers.
Oh yes I did search forums and there is something about it but its buried in some thread somewhere.
Scorchi
Ah found the thread......
https://www.muffwiggler.com/forum/viewtopic.php?t=23727
Will try suggestions in there.
