Addac WAV 1v/oct
Moderators: Kent, infradead, __ag
Alwaysnew
Addac WAV 1v/oct
Post by Alwaysnew » Mon Jan 21, 2013 9:19 pm
Is it possible to have the addac wav player react in a 1v/oct fashion? I.e. To use it as an oscillator? If so with the sample rate cv I suppose.
bj_gzp
Post by bj_gzp » Thu Jan 24, 2013 7:37 am
No, the sample rate is not scaled to 1V/Oct, for both versions 101 or 111 :(
I was hoping for this in the 111, but that feature didn't made it into the final version.
But there are workarounds:
For 101+111: Use a programmer like PGM4x4 or Pressure Points to set the desired pitch and rock it from there.
For 111 only: Record different notes and put them within the first 8 samples on the card. Then play the samples using the Gate ins of the expansion module 111b.
The only Eurorack sampler tracking v/oct is the RS290. It even has a calibration mode, to calibrate it over 3 octaves to your CV keybord.
BJ
Return to “ADDAC System”
