Quad Plague Bearer holy crap
Gear, Suggestions and Discussion.
Moderators: Kent, infradead, computer controlled, flight
slow_riot
Post by slow_riot » Fri Jan 25, 2013 7:51 am
This device is simply spellbinding. I wanted to get a little music device as sometimes when my main synth is all patched up it's nice to spend some time away from it to clear my head without the worry of forcing composition. Also planning to get a little battery powered speaker so can take the thing out and about.
Anyways, the sounds. Wow, wow wow. You can get full on dense beautiful controllable drones out of this thing. And I'm sure I've only scratched the surface.
It's funny, I've had 5 Plague's come through my euro set up but they never fully clicked and I ended up selling them. But 4 in a box makes an incredible instrument. The limitations of the filter now become advantages if you use it right. Look forward to finding more.
oskies
Post by oskies » Sat Jan 26, 2013 5:04 pm
Can you post some sounds? My PB is just sitting in a
corner and I'm one of those that doesn't get it :despair: . Yet.
slow_riot
Post by slow_riot » Sat Jan 26, 2013 6:44 pm
sure thing. give me a couple of days/weeks.
I'm lucky that I've spent a lot of time with the PBs as euro modules, so I already know a lot of the 'tricks' that it can do, and the necessary minor fiddling that will determine whether you get silence, garbage, beauty or anything in between. Eg output to input will give you an oscillator with variable tone.
In the mean time, try this.
2 leftmost PBs are set to self oscillate via the method I mentioned. It will self oscillate really easily, and there are a number of different ways to vary the tones.
PB 3 has input at zero, with the other knobs set in the position described in the manual to give variable noise. The output of this goes into PB 4 with the input level really high. PB 4 is the output stage.
Now, with your 2 oscillator PBs, send the output of PB1 to modulate High on PB3, and PB2 modulates High of PB 4.
You will need to do a lot of fiddling. Sometimes you get silence, and sometimes the oscillation of one or both oscillator PBs are silenced, because they rely on the PB that they are modulating to be in a certain position for them to be audible. And all the parameters seem to interact and influence each other.
Anyways, this is the basic patch that I am using at the moment, and will give a LOT of variations. I've found tones that are bigger than a Sunn 0))) concert where they require 100 KGs more equipment and much more men in robes that the PB does. Good luck!
oskies
Post by oskies » Sun Jan 27, 2013 5:19 pm
Thanks for the elaborate reply. Will definitely try some of the feedback
tricks, and I can totally see the point of having 4 of them in a separate case - limitations and inspiration and all that.
But I still wonder if I cannot get most, if not all, of the filtering and fsu with
an ordinary filter + feedback loops - for example, feedback loops in the toppo multifilter allow for an extremely wide pallet. I recently had some
real long decay time Sunn O))) type of sounds going - will try to see if I can recreate that patch.
In the meantime, maybe we can turn this into a big O'Malley inspired thread ;-)
reppiks
Obscure Intergalactic Destroyers!
Post by reppiks » Thu Feb 21, 2013 5:44 am
i've just ordered a Quad PB - CAN'T WAIT!!
Tsarik
Post by Tsarik » Mon Mar 11, 2013 12:02 pm
i have gotten some insane results out of my Quad Plague Bearer.. but ultimately it has been a hard beast to tame... hell.. i would be happy if i could just get a wider variety of usable results more often
i definitely blame myself and not the device.. this thread has inspired me to play with it some more... i fully intend to go from :bang: to this :sb: in a few hours... and ultimately end up @ :omg:
burnn_out!
deep fried intoxicated wiggler
Post by burnn_out! » Mon Mar 11, 2013 12:57 pm
I owned for probably two years now. All I can say is that in use of a single channel or all four at once, its very delicate and sensitive to settings. The best results usually involve keeping off the gain and input volume. In most cases the input volume is almost none existent in most patches. It's strength in my mind comes from how vesitile it can be. Typical routings for me:.use of each channel individually, two sources using dual PB's, one source routed thru 3 or 4 PB's, and of course any variant of the above use a PB as the sound source...
born in bathsalts..
If your not dead you might as well be dancing, and if your not dancing you might as well be dead. - windspirit
HeWhoWantsJeans
Post by HeWhoWantsJeans » Mon Mar 11, 2013 3:47 pm
burnn_out! wrote:I owned for probably two years now. All I can say is that in use of a single channel or all four at once, its very delicate and sensitive to settings. The best results usually involve keeping off the gain and input volume. In most cases the input volume is almost none existent in most patches. It's strength in my mind comes from how vesitile it can be. Typical routings for me:.use of each channel individually, two sources using dual PB's, one source routed thru 3 or 4 PB's, and of course any variant of the above use a PB as the sound source...
Yep - if you keep the Input low and crank the Gain, that's how you get the most character out of the PB. :deadbanana:
I've archived over 400 answering machines, and the best of which is constantly updated on Tumblr. Public domain! Enjoy! Donate, too!
http://answerphone.tumblr.com/
http://www.answer-phone.org
obscurerobot
Turing Tested
Post by obscurerobot » Tue May 21, 2013 8:17 pm
I just received my second plague bearer, and built a mini-plague system:
  • A-143-2
  • PB v3.3
  • PB v3.3
  • CVP
  • Outs
All in a TT Happy Ending Kit.
Not sure if I want to add two more PBs to this mini rack, or go for a standalone quad.
chvad
Post by chvad » Wed Feb 01, 2017 3:00 pm
Digging up an old thread to just say... I just got one of the final Quad Plague Bearers (5/10) from Flight and it really is true... I've had single Plague Bearers... double Plague Bearers... but the magic number is really four. This thing is just a mangling monstrosity. So so awesome. Wasn't sure I'd get my hands on one but glad I did!
EarlJemmings
Post by EarlJemmings » Fri Feb 10, 2017 9:00 am
Yeah, mine came in a few days ago (2/10). Holy. I've just had it plugged into a matrix mixer with some sloths and random sources controlling various parameters.
This thing is just what my live set ordered.
soundinett
Post by soundinett » Fri May 17, 2019 4:40 pm
PBQuad as a synth!!!
mt3
Post by mt3 » Wed Jul 24, 2019 7:58 pm
soundinett wrote:PBQuad as a synth!!!
:party:
flight
The Plague Bearer
Post by flight » Tue Aug 06, 2019 6:59 pm
These are incredible, thanks for doing them! May I post them on the f(h) twitter account?
~flight
flight(at)flightofharmony(dot)com
http://www.flightofharmony.com
soundinett
Re:
Post by soundinett » Thu Jan 02, 2020 3:47 am
[/quote]These are incredible, thanks for doing them! May I post them on the f(h) twitter account?
[/quote]
of course!
soundinett
Re: Quad Plague Bearer holy crap
Post by soundinett » Thu Jan 02, 2020 3:50 am
This is also mostly Plague Bearer Quad...
flight
The Plague Bearer
Re: Re:
Post by flight » Thu Jan 02, 2020 4:03 pm
[/quote]
of course!
[/quote]
Sweet, thanks!
Love the new track as well, delightfully unsettling.
~flight
Return to “Flight of Harmony”
