| View previous topic :: View next topic |
| Author |
Tiptop Audio - Trigger Riot |
tta Wiggling with Experience
Posted: Sat Jan 26, 2013 4:16 pm Post subject: Tiptop Audio - Trigger Riot |
Wigglers, time for a riot
The Trigger Riot represents a new type of sequencer that is both creatively deep on one hand and intuitive on the other.
From a conceptual view, the Trigger Riot generates 16 clock streams consisting of multiple time manipulation functions (division, offsets, etc) that interact to create the trigger output, and direct access to each parameter via individual knobs allows for quick manipulation. The 8 outputs are the sum of those manipulated streams per row. The outputs of the module are arranged as either a 4x4 matrix, where each of the 16 knobs affects both row and column, or as a set of independent outputs for each row or column. This allows forming 8 complex musical interactions in a ‘Matrix’ mode or 8 independent streams in ‘Independent’ mode and is switchable from one to the other on press of a button for some unexpected results.
Since each of the 16 knobs represents a real time tweakable trigger generator/modifier the Trigger Riot is extremely playable and can result very complex patterns with only few knob turns; patterns that would otherwise take much longer and in some instances be almost impossible to produce using grid based step sequencing. Patterns can have unique time signatures that can repeat or be randomized through probability, time shifted and phased, divided, multiplied and counted, it’s unbelievable how complex this module can get with minimal input.
Functions include:
Divide: Divide the clock stream into either even or odd divisions from 1 to 255
Speed: Multiply or Divide the clock streams in sub clock particles based on 24 PPQ, breaking up the standard grid values.
Probability: Sets the odds of a trigger firing which makes more varied and less rigid patterns or can create subtle accents and fills.
Pulse Width: Sets the pulse width of each stream, creating overlaps and as a result all kind of odd time signatures; also great for sustaining envelopes or for programming a high pulse fro some time.
Clock Offset: Moves the trigger streams in time to change the relationship between streams. Streams can be set to the same amount but offset to trigger in between each other rather than simultaneously to create syncopation effects.
Time Shift: Shifts the triggers streams variably in between clocks for swing type feels and off the grid patterns.
Step: Places single shot triggers on individual clock ‘Steps’ to trigger events once per pattern. This can also be seen as a pulse counter.
Mute/Sel: Muting of each trigger output for live dub mixing or to select which row to edit in ‘Independent’ mode.
Tap tempo: Tap in your own time.
Cycle: Internal reset counter to constrain pattern length and relationships between divisions
Clock Out: Trigger out of the Riot’s highly accurate internal clock
Clock Input: External clock
Reset Out: Trigger output based on the internal reset length
Reset In: External trigger input to reset the internal count
Playing sets:
The Trigger Riot features 4 banks of 4 presets for saving, and instant recall of patterns with any level of complexity making it a real time sequencer. Patterns and banks are not volatile and can be loaded for stage or studio sessions on power up.
Several riots can be synced together with all control signals shared based on a master reset, clock, and pattern across multiple units and even synced with the Circadian Rhythm sequencer.
In addition to that, a master touch controller is in development which can control up to 4 Riots for the ultimate in hardware sequencing for Tip Top’s wide array of drum and synthesis modules (of course, it works great with every other module too).
A little bit of what going on under the hood: The Trigger Riot is made with the latest in high-end microprocessors and a special combination of hardware and firmware technology designed to achieve unprecedented levels of timing and extreme types of pattern complexity.
Engine: State of the art 80MHz 32bit Processor MIPS M4K Core
Available: We are hoping to have it released late march 2013, keep your fingers crossed
Price: TBD
_________________ Gur
Tiptop Audio |
| Back to top |
XidZeta custom text avatar
Posted: Sat Jan 26, 2013 4:19 pm Post subject: |
sold!  _________________ www.xidzeta.com
free music: IDM, Downtempo, Noise, Ambient, Glitch
www.youtube.com/broembach
modular patch videos
trade me your Optomix for my Borg2! |
| Back to top |
kuxaan-sum best wiggler ever!
   Posts: 438 Location: Denver, CO
Posted: Sat Jan 26, 2013 4:26 pm Post subject: |
Same here...can't wait for this. (...and supporting modules) _________________ the road to the sky leading to the umbilical cord of the universe...
Gear Here: OpenTape Here: YourSpace Here:  |
| Back to top |
hpsounds the french icelander
    Posts: 1463 Location: Iceland
| Back to top |
chinard Super Deluxe Wiggler
    Posts: 2190 Location: Toronto
Posted: Sat Jan 26, 2013 4:43 pm Post subject: |
| nifty! |
| Back to top |
distorted Common Wiggler
Posted: Sat Jan 26, 2013 4:48 pm Post subject: |
| totally in for this! |
| Back to top |
thelizard in it for the money
   Posts: 474 Location: Canton, OH/Chicago, IL/Santa Barbara, CA
Posted: Sat Jan 26, 2013 4:50 pm Post subject: |
The "Techno to Complete Riot" video finally explains to me why people would set up modular drum machines. Some of those micro-rhythms that came and went have me extremely intrigued by what this module does. It's an excellent concept.
My ultimate dream would be to see more CV-control on drum modules. I love that we can do fantastically cool, evolving rhythms, but if we could see modules with patch points into parameters like osc/noise balance, decay rate, etc. (without having to manually assemble that voice with five-ten other modules... something like a single uTonic voice or any of the forty or so Machinedrum synths), I would be much more interested in dedicating an entire case to building a TipTop drum synth and sequencer.
Congratulations on this trigger-spitting achievement. I can't wait to see more info on Circadian Rhythm! _________________ http://mhetrick.com/
http://www.unfilteredaudio.com/
My music: http://soundcloud.com/the-february-thaw
My videos: http://vimeo.com/mhetrick
Listening to: http://www.last.fm/user/TheLizard528 |
| Back to top |
sixteen Common Wiggler
 Posts: 194 Location: London
Posted: Sat Jan 26, 2013 4:52 pm Post subject: |
This looks spot on!
Cant wait to get my grubby hands on it...
Nice one Gur _________________ http://soundcloud.com/yeseffect |
| Back to top |
Transistor Common Wiggler
   Posts: 98 Location: The Hague, The Netherlands
| Back to top |
Mono Recalcitrante Wiggling with Experience
   Posts: 296 Location: Bilbao
Posted: Sat Jan 26, 2013 5:02 pm Post subject: |
| That is really cool! Do not understand how it work very well, but seems very interesting... |
| Back to top |
ignatius Super Deluxe Wiggler
    Posts: 6319 Location: oregon
Posted: Sat Jan 26, 2013 5:11 pm Post subject: |
Fucking ay. _________________ LABEL TWITTER FACEBOOOK SAMPLE LIBRARY
| Quote: | | Think for a moment about what an amazingly obscure piece of commonality that is. |
| Back to top |
jimmyedgar Ultra Violet Vibrator
Posted: Sat Jan 26, 2013 5:19 pm Post subject: |
| getting 2 for sure |
| Back to top |
burnn_out! deep fried intoxicated wiggler
  Posts: 850 Location: the dirty D
Posted: Sat Jan 26, 2013 5:27 pm Post subject: |
Fuck me standing, that is a must own. Even at the expense of starting a new case.  _________________ wtb: tiptop zdsp, tyme sefari mk2 |
| Back to top |
radiokoala must. build. jacuzzi
Posted: Sat Jan 26, 2013 5:39 pm Post subject: |
Damn, that 3rd video is INCREDIBLE. (watching it fifth time already!)
I hear many similarities to music I make myself (example 1, example 2), and it is such an awesome experience for me personally, that I can't be thankful enough... If you had released it as a track, it would be my favorite one hands down.
With interest in improvised music above all things, this module is an exceptional value for that... can very well be a centerpiece of a performance modular I'm sure. _________________
| spacenoodle wrote: | | There is no space in my case for this but I'm getting two. |
| djGabrielK wrote: | | Yep, True analog is created by vibrations within a transistor. |
soundcloudy soundcloud
analog / modular videos |
| Back to top |
Mans Veteran Wiggler
   Posts: 700 Location: Rotterdam
Posted: Sat Jan 26, 2013 5:51 pm Post subject: |
| thelizard wrote: |
My ultimate dream would be to see more CV-control on drum modules. I love that we can do fantastically cool, evolving rhythms, but if we could see modules with patch points into parameters like osc/noise balance, decay rate, etc. (without having to manually assemble that voice with five-ten other modules... something like a single uTonic voice or any of the forty or so Machinedrum synths) |
Cwejman BLD
OT What a great concept. Someone said your new modules would change the way people sequence. I found that a bit far fetched but now I can see where he was coming from! Will be a blast to work with. |
| Back to top |
Karl_Joseph Common Wiggler
Joined: 08 Oct 2012 Last Visit: 22 May 2013 Posts: 164 Location: Minneapolis
Posted: Sat Jan 26, 2013 5:55 pm Post subject: |
I want to hear more ! ! !
...cowbell... _________________ - KARL
| Back to top |
amalthea Common Wiggler
 Posts: 111 Location: USA
Posted: Sat Jan 26, 2013 5:58 pm Post subject: |
Wow, this looks and sounds incredible. This really makes me want to put together an all-TTA drum/rhythm case. Blown away....
| Back to top |
jonne74 Common Wiggler
 Posts: 150 Location: Göteborg, Sweden
Posted: Sat Jan 26, 2013 6:03 pm Post subject: |
That third demo sounds very nice. _________________ -------------
"I encompass and I eclipse.. * ..got the hiccups" |
| Back to top |
tweakfilter Learning to Wiggle
Joined: 02 Jun 2012 Last Visit: 22 May 2013 Posts: 39 Location: Portugal
Posted: Sat Jan 26, 2013 6:07 pm Post subject: |
Will be on left side of my z8000  _________________ "I say, play your own way. Don't play what the public want - you play what you want and let the public pick up on what you're doing - even if it does take them fifteen, twenty years." - Thelonious Monk |
| Back to top |
Paranormal Patroler Super Deluxe Wiggler
 Posts: 3113 Location: (geography) a point in physical space
Posted: Sat Jan 26, 2013 6:08 pm Post subject: |
Totally sold.  _________________ • • • • • • • • • • • • • |
| Back to top |
