Complex Random weak gates?
Moderators: Kent, infradead, __ag
Selador
Post by Selador » Tue Feb 19, 2013 2:52 pm
Hi guys,
Anyone have any issues with the Addac Random gates? Mine are weak--unfortunately I don't have a way to measure precise voltage, but they need separate amplification to trigger an envelope or open a VCA/LPG entirely.
:sadbanana:
Anyone have similar experience or solutions? I'd hate to constantly lose a VCA every time I want to use it.
Born like this, into this, as chalk faces smile
DonKartofflo
The knob-twisting Hive Mind
Post by DonKartofflo » Thu Feb 21, 2013 9:27 am
normally emailing andré on this will yield a quick and helpful reply as well as a repair offer if the problem is not solvable on your own.
Nelson Baboon wrote:Beware of people who tell you to smile.
FS:
Mutable Instruments Tides 1 120€
Addac sys 12U powered frame 200€
Selador
Post by Selador » Thu Feb 21, 2013 1:29 pm
Probably should have given that a shot at the get-go. Thanks for the heads up!
DonKartofflo
Post by DonKartofflo » Thu Feb 21, 2013 5:26 pm
Selador wrote:Probably should have given that a shot at the get-go. Thanks for the heads up!
always a pleasure :tu:
FS:
Gribs
Post by Gribs » Fri May 10, 2013 9:15 am
I have this issue as well. The gates are particularly weak on the expansion module. I just sent an email to Addac about this. Is it better to send a PM here?
Gribs
Post by Gribs » Fri May 10, 2013 9:28 am
Edit,
Wow that was fast. I heard back from Andre within about 15 minutes. Does he ever sleep?
It appears that this was an issue with some early units. The solution is to send it to Addac for a repair/upgrade - no biggie other than some time.
Functionally, if you want random voltages and gates with fine control over the parameters for the time series, this module is the best I have tried.
Selador
Post by Selador » Fri May 10, 2013 9:30 am
I've just resigned to amplifying the gates with a Positronic Transient Gate to get them high enough. The gain distortion can make for some interestingly shaped envelopes, but it's still a bit inconvenient. If you get any response back please do report back, I've held off until shipping a module to Europe is feasible.
Cheers! :guinness:
Selador
Post by Selador » Fri May 10, 2013 9:32 am
Well, that was indeed quick. That explains why I was able to snag my expander for eighty dollars.. Looks like I'll be investing in postage soon.
Return to “ADDAC System”
