Dual VCA
Author Dual VCA
jack multiple
Am going to be using the module as is, not the quad, my question is about the BUSS part of the circuit board, what is the numbering on it? the square pad is 1, but there are 2 columns, so how does it go? not sure where to find the pads that need to be linked together.
Also do people recommend filling ALL blank solder pads with a bit of solder ?
thankyou.
Synthbuilder
Start at the top left and go right for pin 2. Then down to the next line on your left and go right and so on... it's a like reading a book. The schematic also shows the BUSS header as it is on the board.
Also do people recommend filling ALL blank solder pads with a bit of solder?
No need to do any holes. But I tend to recommend filling the unused SLV link holes and all the via holes. The unused component holes may be left unsoldered.
Filling the vias goes back to the days when vias would fail over time. Soldering them strengthened them and also allowed more current to travel through them without thermally compromising them.
Tony
jack multiple
ok thx.
