Muff's Modules & More we weren't even testing for that
Information |
Hello! This is a message to everyone who emailed or PM'ed me asking for an exemption to the '100-post rule' for our Buy-Sell-Trade forum.
You didn't get a reply from me because you aren't above the rules. The rules are the same for everyone. I understand your position and I'm sorry I can't help you, but I can't help you. Thanks for understanding! Please enjoy our lovely forum. |
| View previous topic :: View next topic |
| Author |
Korg Monotribe in CV/gate mode [Video demo added!] |
radiokoala must. build. jacuzzi
Posted: Tue Feb 26, 2013 6:06 pm Post subject: Korg Monotribe in CV/gate mode [Video demo added!] |
Okay, I updated my monotribe and DIY'd a CV/gate sending cable, and here's how it sounds:
[s]http://soundcloud.com/radiokoala/monotribe-fun-times[/s]
Sputnik DWG as a modulator. Osc1 sends CV/pitch information, and Osc2 gates the envelopes. In other words, it is frequency modulation by Osc1 since voltage is continuous, and it makes it sound more interesting than sending note values. Some cross-modulation between two oscillators as well.
For receiving CV I used Hz/V mode, and for gate an inverted trigger mode, because in usual mode I had no luck triggering the gates with a VCO. (Even though with square waveforms not in CV/gate mode it worked!)
Oh, and almost forgot: yes there is delay/reverb, for added liveliness, but it is an output of a monotribe only, nothing else. (No VCO to audio in or anything...)
Regarding the patch itself, overall it looked something like that:
Enjoy.
| spacenoodle wrote: | | There is no space in my case for this but I'm getting two. |
| djGabrielK wrote: | | Yep, True analog is created by vibrations within a transistor. |
soundcloudy soundcloud
analog / modular videos
| Back to top |
felixer Super Deluxe Wiggler
   Posts: 1636 Location: germany
Posted: Wed Feb 27, 2013 1:17 pm Post subject: Re: Korg Monotribe in CV/gate mode...now that's fun! |
| radiokoala wrote: | | For receiving CV I used Hz/V mode, and for gate an inverted trigger mode, because in usual mode I had no luck triggering the gates with a VCO. (Even though with square waveforms not in CV/gate mode it worked!) |
nice sounds
old/original korg gate was 'switching', like moog: at 0V the env starts. modern/normal gate in expects 5V. so it seems your clock-osc does a nice 0V but not 5V you could check with a voltmeter ...
if you are into diy it would be easy to make some cmos osc. those can go up to 10V if you like  _________________ don't need midi, don't need keys, just want knobs and cables (all together now ;-) |
| Back to top |
Posted: Wed Feb 27, 2013 1:23 pm Post subject: Re: Korg Monotribe in CV/gate mode...now that's fun! |
| felixer wrote: | | radiokoala wrote: | | For receiving CV I used Hz/V mode, and for gate an inverted trigger mode, because in usual mode I had no luck triggering the gates with a VCO. (Even though with square waveforms not in CV/gate mode it worked!) |
nice sounds
old/original korg gate was 'switching', like moog: at 0V the env starts. modern/normal gate in expects 5V. so it seems your clock-osc does a nice 0V but not 5V you could check with a voltmeter ... |
They all do nice 0V, it's a lesser of all efforts to generate a 0V voltage But really I think it's +5V/-5V, or what voltage VCOs usually have. No malfunction, that's for sure, but out of interest I will check it when there's a tester around.
BTW, just a few minutes ago uploaded a vid (continuing my CV/gate explorations )
analog / modular videos |
| Back to top |
Posted: Wed Feb 27, 2013 1:57 pm Post subject: Re: Korg Monotribe in CV/gate mode...now that's fun! |
| radiokoala wrote: | it's a lesser of all efforts to generate a 0V voltage But really I think it's +5V/-5V, or what voltage VCOs usually have. |
never assume anything. not in euroland who talked about 'assumption being the mother of all fuck-ups'? often it's 5Vpp, so -2,5V-+2,5V ... sometimes more, sometimes less
and you 'd be surprised how difficult it can be to get 0,000V. it's called 'offset' and not a welcome guest to amplifier-parties
you should def check:
-george duke live on stage with frank zappa using his arp odyssey's s&h to accompany/drive the 'idiot dancing contest'.
-brad pitt in '12 monkeys' (movie by director terry gilliam).
| Back to top |
Posted: Wed Feb 27, 2013 2:05 pm Post subject: Re: Korg Monotribe in CV/gate mode...now that's fun! |
| felixer wrote: |
haha! made me laugh
'idiot dancing contest' sound like fun, and by the way I have a Zappa t-shirt (lumpy gravy)...as for voltages, I sure will check them, now I'm curious myself.  _________________
| Back to top |
crippletoe Common Wiggler
Posted: Wed Feb 27, 2013 4:20 pm Post subject: |
hey radiokoala,
can you explain a little what exactly did you do in order to be able to send in cv/gate signals?
did you have to modify the monotribe or is it some new firmware feature? _________________ -------------------------------------
http://www.eliadwagner.com
wtb: Intellijel buff mult |
| Back to top |
oscillateur Common Wiggler
  Posts: 157 Location: Tokyo
Posted: Wed Feb 27, 2013 6:33 pm Post subject: |
| It's a new firmware update. No mods needed. |
| Back to top |
Posted: Wed Feb 27, 2013 7:06 pm Post subject: |
is that the 2.0 firmware update? what possibilities does it give exactly? couldn't find anything on the korg site... _________________ -------------------------------------
| Back to top |
| Back to top |
Posted: Thu Feb 28, 2013 2:12 am Post subject: |
Yes, correct, a 4-pole mini jack. I DIY'ed my own, it's two mono patchcords on one side and a single plug on the other that is inserted in the monotribe.
When you download a firmware, despite manual is in japanese, inside pdf there is a pinout. Tip is for gate, ring 2 CV, sleeve is ground. Ring 1 is not used, but I have a madman idea that maybe in the future they will add a filter CV?!
Regarding the possibilities of new firmware, in 2.0 there is a plenty (sample&hold, 16 steps for synth...etc), and 2.11 only adds CV/gate mode.
Oh, and last: update procedure is identical to 2.0, just read it in a guide that comes with 2.0 (it's in English). To enable CV, after updating you need to power on monotribe holding SN and GATE. Then press step 1, it turns on CV/gate mode. Last, to save settings press REC. Switching between Hz/V and V/Oct mode is step 2, and trigger/inverted trigger response is selected by a step 3. That's pretty much it.  _________________
| Back to top |
Posted: Thu Feb 28, 2013 7:34 am Post subject: |
wonderful!
of course a standard camcorder has the CV ring wired to ground so those cannot be easily used... puh... still i am so impressed by KORG for doign this!
in fact, i suspect that they did not come out internationally with this yet because the next update should (hopefully) feature a CV/GATE OUT functionality (coordinated with the release of the new ms20 of course ...)
either way, GOOD NEWS! _________________ -------------------------------------
| Back to top |
rockwoofstone Common Wiggler
Joined: 02 Oct 2012 Last Visit: 20 May 2013 Posts: 128 Location: SW London
Posted: Thu Feb 28, 2013 3:58 pm Post subject: |
I've just thrown together the appropriate cable and performed the update, and there's a couple of minor changes you need to make to radiokoala's process to get this to work with standard Eurorack kit.
Assuming you've successfully installed the Monotribe v2.11 update, go into the appropriate setup mode as radiokoala describes by turning on whilst pressing SN and GATE.
You need to make sure that step 1 is lit to enter CV/GATE mode.
This is when things need to be a little different....
Set step 2 and 3 to be UNLIT, which selects V/OCT and the appropriate gate mode for Eurorack (i.e. high gate = note on).
You finally need to calibrate the Monotribe to your input. Easiest way is to use a MIDI module in your rack, so you know exactly what you're feeding in....
Set the VCO Octave on the Monotribe to 16' (I can't tell if you need to do this now, but as it is recommended for when you are doing CV/GATE playback, you may as well do it here just in case).
Select KEY or NARROW range on the Monotribe.
Play note C4 on your keyboard, ensuring your new cable is plugged into the Monotribe (i.e. CV & GATE are both being sent). Whilst holding that note, press PLAY. The LED on the PLAY button will light for around a second then fade out.
Next, play note C5 on your keyboard, and again, whilst holding that note, press PLAY on the Monotribe and wait a second for the LED to fade out.
At this point, you have successfully calibrated the Monotribe, perfectly aligned with an exact 1V/Oct range, and effectively tuned to your system (assuming standard tuning ;-).
Press REC to save the settings, and you're ready to go.
Hope that helps!
One final thing to note is that the MT doesn't appear to be able to respond to any form of envelope, but is limited to it's own three internal envelope shapes, with the second and third picking up a sustain stage in line with the gate length you send. The first envelope has it's own decay, but that cuts off abruptly when the gate closes. Still, better than nothing! _________________ http://soundcloud.com/rockwoofstone |
| Back to top |
Posted: Fri Mar 01, 2013 5:47 am Post subject: |
Of course, as an addendum to the above, that all only applies if you want a "vanilla" approach to controlling your Monotribe. If you want to be somewhat crazier with your sounds, the videos radiokoala is churning out have some great approaches in them! _________________ http://soundcloud.com/rockwoofstone |
| Back to top |
Posted: Fri Mar 01, 2013 6:02 am Post subject: |
| rockwoofstone wrote: | | Of course, as an addendum to the above, that all only applies if you want a "vanilla" approach to controlling your Monotribe. If you want to be somewhat crazier with your sounds, the videos radiokoala is churning out have some great approaches in them! |
Thank you!
You know what else I'm thinking -- if sometime cv/gate out will be added, then you could also have a vanilla chromatic quantizer in the face of monotribe In KEY mode I believe any incoming voltage is quantized to the nearest semitone.
But that's not everything - you could also use monotribe to transpose your sequences! So you could send the same CV to a VCO and to another VCO thru monotribe, where you will use octave selector and transpose the incoming stuff octave up/down, or more. If you have a spare VCO, you could give it some sub-oscillator credentials for example That's very nice, there's not even many modules (quantimator comes to mind) that allow you transposing stuff...
As you see, I still have some ideas, alright  _________________
| Back to top |
Posted: Fri Mar 01, 2013 6:10 am Post subject: |
Hehe!
The quantising idea got me thinking that as the facility is there to calibrate the MT, you could force some further transposition which isn't full-octave focussed by calibrating at something other than C4-C5.
In other words, you can set the 1V/OCT scale to be whatever you like by just substituting C4-C5 calibration to be whatever you'd like 1V to represent, based at whatever note you desire. _________________ http://soundcloud.com/rockwoofstone |
| Back to top |
Posted: Fri Mar 01, 2013 6:22 am Post subject: |
| rockwoofstone wrote: | Hehe!
In other words, you can set the 1V/OCT scale to be whatever you like by just substituting C4-C5 calibration to be whatever you'd like 1V to represent, based at whatever note you desire. |
And last, you could just use it as a simple offset. At 16' mark it is initial voltage, but since the selector goes down (and up) to 64' and 2' respectively, there are possible offsets of -2, -1, +1, +2, and +3V, which could come in handy. (Say, you are using low-amplitude LFO to scan through wavetables, so you patch it to monotribe and with octave selector then can choose the different waves to morph between!)
Things like that.  _________________
| Back to top |
hamildad Common Wiggler
Joined: 01 Jul 2012 Last Visit: 19 May 2013 Posts: 55 Location: London
Posted: Fri Mar 01, 2013 7:53 am Post subject: |
when using the Monotribe MIDI mod, there is significant clicking as the internal envelope gate cannot sync with the incoming midi note on/off, this means its fine when filter resonance is high, but dial it down and the clicking is noticable and unwanted.
How is the monotribe when using the CV/gate for sequences/keyboard?
sounding nice?
cant believe the functionality that this unit has, I had written off another firmware update after 2.0. |
| Back to top |
Posted: Fri Mar 01, 2013 7:55 am Post subject: |
@hamildad It can be a bit clicky, very dependent on the envelope selected, so judicious setting of the knobs is in order to minimise that. I got some reasonably usable output. _________________ http://soundcloud.com/rockwoofstone |
| Back to top |
phono1337 2SK30A-O
   Posts: 811 Location: temple of x0x
Posted: Fri Mar 01, 2013 2:33 pm Post subject: |
awesome thread guys, just added cv/gate jacks to mine, quick video
some pics of the solder points on my blog  _________________ Din Sync |
| Back to top |
Cozmic023 Common Wiggler
Joined: 06 Oct 2012 Last Visit: 15 May 2013 Posts: 66 Location: Somerset, UK
Posted: Sat Mar 02, 2013 5:57 am Post subject: |
Wicked news guys, I've still got my thoughts on getting a desktop module like the Monotribe.
They are very tweakable, and can be modified for midi. (And now CV)
I'm still undecided, but i'm looking at either:
Korg Monotribe
Doepfer Dark Energy (and maybe Dark Time too?)
MFB Nanozwerg
MFB Dominion X
I do own a Blofeld desktop synth (which i love, and is great sounding.) But want something CV synth based that can be used with the modular.)
Lee
Edit: Bought a Monotribe this week, great little box!!  _________________ Bedlamite: soundcloud.com/dj-bedlamite
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
