Author |
vco optional octave switch |
br>Widy75 |
br>hi
introduction
im new to this forum ( first post ) however i'm planing/building a smale okley system ..... but i have some questions ... one for now:
is it possible to exchange one Tune Poti with a octave switch ( e.g octave switch from elby design ) just a rotary with generates 0 - 8 V in 1V steps
Is the Tune Poti just a poti with is connected to 0 and 10 V and generates the input voltages for the freq... if that is so i can do a octave switch instead
or is it possible to add another flying resistor to the sum input of freq cv control to get another control input
normaly i can find out such stuff by myself but i did not own the pcb yet and i need to think about this during panel layout design ( i build panels by my own in 3he ) because for the octa switch i need some extra space
lg widy br> br> |
br>sonicwarrior |
br>A coarse tune poti is always a variable voltage divider so: Yes, you can replace it with a 'stepped' switch (with several resistors instead of a poti), e.g. an octave switch.
In fact: You can always replace potis with a switch made with resistors. Even if the resistors are unselected 1% that is more precise than a poti. Selected ones are used for mastering equipment to get a precise stereo signal and reproducable values for EQs, compressors and maybe other stuff. br> br> |
br>Synthbuilder |
br>The coarse pot is actually slung between the +10V and -10V reference voltages. But you could easily use a rotary switch with 0.1% resistors to make an octave switch. I would use +10V and ground as the resistor chain end points. Octave trimming can simply be done by fine tuning the +10V reference voltage with the PSU trimmer on the board.
Tony br> br> |
br>jack multiple |
br>i'd really like to just carry this on a bit just to learn more stuff.
you say that the tune pot is basically a variable voltage divider and can be changed into a stepped divider by using a switch.
could u or how could you take it further and make it a variable stepped divider using a pot or rotary switch, where each step was an exact semitone?
i have no desire to do this, merely interested . thx br> br> |
br>Dr. Sketch-n-Etch |
br>I just built ianross a 12-position octave switch which generates voltages from 0 to 11V in 1-V steps. I built several of these for myself and Danjel from Intellijel for calibrating Dixies and Rubicons. For Ian, I put the whole thing behind an 8hp euro panel with some very basic graphics. Sorry, I never snapped a picture of it, but it turned out rather well, I thought. It has a hole in the panel for inserting a screwdriver for calibration.
The hardest part of building these is finding a dozen or so matched resistors. In my case, I buy 100 1% 30k resistors on a tape, and then sit in front of the TV and measure each and every one with a DVM. I make a little mark on the tape next to every one which is within 0.1% of the stated value, and then use those for the switcher. For the switch, I use a 24-mm Alpha switch. It is pretty high-quality, and very nice to wiggle. br> br> |
br>...Here's a graphic of what the stuffed PCB looks like:
That stuff on the right is where the jack is attached. br> br> |
br>jack multiple |
br>that looks pretty interesting.
i want to at some point , when i understand it all a bit more, to put something like that on an analog sequencer in place of the normal cv outs .calibrated to 1 semitone per step, think it would be great, with a separate octave swich by each one.
anyway, going to copy that diagram into my list of 10 billion things i dont understand, then pull it out when i do. thx br> br> |
