cats and modular synths, but mostly cats
Artist Challenge #4 is now closed for new submissions! Thanks to everyone who entered, you guys are truly crazy. The official voting thread will be created shortly with the standard two weeks for the voting period. Enjoy the tunes!
Silent Way VCO Calibration
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Silent Way
Author Silent Way VCO Calibration
Navs
Last Visit: 02 Sep 2010
PostPosted: Fri Sep 18, 2009 6:21 am    Post subject: Silent Way VCO Calibration Reply with quote Add User to Ignore List
Hi,
I'm trying out the demo of SW 1.3 with the headphone out of my RME Fireface400.
Calibration works perfectly from C1 - F4 (absolute revelation to hear my M15 tracking so well! hihi ) but then things go awry.
The calibrate graphic on the plug-in seems to confirm this (see attachment).
Am I doing something wrong or is this maybe a limitation of the FF400's outs?
I also got a similar result with my Cwejman VCO-2RM ...
Navs
modules for sale here
http://navsmodularlab.blogspot.com/
http://navs.bandcamp.com/
PostPosted: Fri Sep 18, 2009 6:36 am    Post subject: Reply with quote Add User to Ignore List
That looks fine to me - the jaggy line at the top is where you hit the max voltage and it wraps round the top octave.
If you need more range, use an input that's adjustable and not fixed 1v/octave. E.g. If you can set the VCO to 0.5v/octave then you'll double the reachable note range.
http://www.expert-sleepers.co.uk/
http://twitter.com/expertsleepers
http://www.darkroomtheband.net/
wetterberg
PostPosted: Fri Sep 18, 2009 7:38 pm    Post subject: Reply with quote Add User to Ignore List
-but this will also affect your resolution, right?
Either way, the wrapping around the octave is a nice clever little solution. Good thinking, that.
www.twitter.com/wetterberg
Current Rig (May'10)
View user's profile Send private message AIM Address MSN Messenger
PostPosted: Sat Sep 19, 2009 1:21 am    Post subject: Reply with quote Add User to Ignore List
I have to give Graham at http://www.hinton-instruments.co.uk/ credit for suggesting that feature.
Navs
PostPosted: Sat Sep 19, 2009 4:27 am    Post subject: Reply with quote Add User to Ignore List
Thanks for the confirmation os!
I tried multing and then boosting the CV (A-133) but got the best results using a positive offset of about 2.5V via an A-138 mixer: five perfect octaves smile
PostPosted: Sat Sep 19, 2009 6:37 am    Post subject: Reply with quote Add User to Ignore List
Sounds good!
What's the oscillator you're using? I'd like to add it to the chart:
http://www.expert-sleepers.co.uk/siwacompatibility.html
Navs
PostPosted: Sun Sep 20, 2009 2:22 pm    Post subject: Reply with quote Add User to Ignore List
I can add a Cwejman VCO-2RM and Cyndustries ZO to your list (C1 - C6), with the caveat that the Zero wobbles a bit in the lower registers and, once you start applying FM indexes in excess of 100%, pitch becomes a relative issue wink
I also got a Cwejman MMF-1 filter to track perfectly from C1 - C6.
Doepfer's A-105 is a little less stable (+/- 1-2 cents) over the same span, but easily close enough for rock 'n' roll.
Malekko/ Wiard Borg didn't fare as well: +/- 15 cents, but I didn't expect it to.
Two wild cards:
Bananalogue/ Serge VCS, C1 - C5, up to 6 cents off, but hey!
Plan B Model 10 EG, C2 - C4, +/- 20-40 cents. Also surprising.
The tricky part here is figuring how much Timebase modulation to apply.
With the VCOs and filters that are calibrated for 1V/O maybe these results shouldn't be too surprising.
I guess the real issue is that there are still only two (three if you count the RME's phones out) compatible audio interfaces ...
PostPosted: Mon Sep 21, 2009 6:10 am    Post subject: Reply with quote Add User to Ignore List
Thanks for all those, that's great information.
For the more 'wobbly' modules, I could probably add a more accurate (but much slower) calibration process that fine tuned each note in turn. Do you think that's worth doing? Would users be willing to sit through such a process?
Btw you more than qualify for the bounty, if you can get something on YouTube:
http://www.expert-sleepers.co.uk/index_files/silent-way-bounty.php
Navs
PostPosted: Mon Sep 21, 2009 10:04 am    Post subject: Reply with quote Add User to Ignore List
If it's an easy to implement option, then yes. I'd be happy to test it for you.
The current calibration routine seems to work fine for VCOs and filters with 1V/O inputs though.
Out of interest, how slow is 'much slower'?
Thanks for the bounty tip-off!
PostPosted: Mon Sep 21, 2009 10:13 am    Post subject: Reply with quote Add User to Ignore List
OK, I'll add it to the "to-do" list.
You can hear the current calibration routine stepping between pitches, and how long it spends on each one. Imagine that stepping over all 128 possible MIDI notes.
1nput0utput
Last Visit: 11 Aug 2010
PostPosted: Mon Sep 21, 2009 11:46 am    Post subject: Reply with quote Add User to Ignore List
Almost all MOTU interfaces are compatible. That's way more than two.
Charles Bukowski wrote:
The difference between life and art is art is more bearable.
Navs
PostPosted: Tue Sep 22, 2009 12:56 pm    Post subject: Reply with quote Add User to Ignore List
You're absolutely right.
I should have written 'two or three brands' i.e. MOTU, Alesis (& RME).
PostPosted: Tue Sep 22, 2009 1:13 pm    Post subject: Reply with quote Add User to Ignore List
And Terratec, apparently.
http://www.kvraudio.com/forum/viewtopic.php?t=256572
Navs
PostPosted: Wed Sep 23, 2009 2:27 pm    Post subject: Reply with quote Add User to Ignore List
10V - Interesting!
Are you finding the Ultralite's 4-5V max output a limitation?
PostPosted: Wed Sep 23, 2009 2:37 pm    Post subject: Reply with quote Add User to Ignore List
No, but bear in mind this is the only way I've ever controlled a modular - I don't have any history with MIDI/CV etc. to compare against.
Analog>Plugins
Last Visit: 31 Aug 2010
PostPosted: Sat Sep 26, 2009 3:31 am    Post subject: Reply with quote Add User to Ignore List
I would certainly be happy with a high quality calibration mode for sure.
Don't worry about the time it takes....3 mins would be fine for me.
Loving the updates OS.
antenne
Last Visit: 27 Jan 2010
PostPosted: Sat Sep 26, 2009 12:30 pm    Post subject: Reply with quote Add User to Ignore List
you can add a Serge DSG (dual slope generator)
to the list - just calibrated one for tracking over 6 octaves
i also am loving the updates - thanks os
kim
antenne
PostPosted: Sat Sep 26, 2009 12:45 pm    Post subject: Reply with quote Add User to Ignore List
you can also add a Serge VCFQ ( variable q filter ) patched to
self-oscillate
and ofcourse
the "regular" Serge oscillator modules:
PCO ( precision oscillator )
NTO ( new timbral oscillator )
FREQ ( frequency shifter )
kim
PostPosted: Sun Sep 27, 2009 12:54 pm    Post subject: Reply with quote Add User to Ignore List
Thanks for the info!
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Silent Way All times are GMT - 5 Hours
