What happens if you swap input and output on a module
GeneralBigBag
My codename's Happy Harry, I'm Into CV
Post by GeneralBigBag » Thu Apr 03, 2008 2:29 pm
On a filter or something, i.e., put your sound source into the ouput jack, and hook the input to your VCA?
Would you
a) (what I imagine to be the case) Get no signal
b) Fry your module
c) Get strange sounds
Kwote
Voltage Controlled Crackpot
Post by Kwote » Thu Apr 03, 2008 2:32 pm
get no signal.
i don't think you can fry a module unless you exceed it's voltage capacity.
kwotemusic.com
my other sites
thermionicjunky
Thyratron Genius
Post by thermionicjunky » Thu Apr 03, 2008 3:05 pm
I'm sure certain products are more vulnerable than others. I have some Moog stuff that warns you not to connect two outputs together. There is the exception of the Metasonix TM-1, which will give an audio output from the beam tube cv input. Aside from that, I can only think of some switching modules with bi-directional jacks.
consumed
International Filter Conspiracy
Post by consumed » Thu Apr 03, 2008 4:02 pm
d) create a tear in the fabric of space-time and wake up the next day with a massive headache.
Squibbons
Post by Squibbons » Thu Apr 03, 2008 5:20 pm
I probably do this at least once per patch. Especially on modules with a more left-to-right setup and not the Blacet top-to-bottom setup. I must mis-patch my Frequensteiner every time I use it. It doesn't do anything but not produce sound.
GeneralBigBag
Post by GeneralBigBag » Thu Apr 03, 2008 6:26 pm
So I guess there's no through-the-looking-glass world of reverse synthesis, replete with RSDAs, FPLs, OFLs, and OCVs :)
Kwote
Post by Kwote » Thu Apr 03, 2008 8:05 pm
GeneralBigBag wrote:So I guess there's no through-the-looking-glass world of reverse synthesis, replete with RSDAs, FPLs, OFLs, and OCVs :)
thank god. the synth might not explode but my mind would.
kwotemusic.com
my other sites
