Author |
Elby Design - Panther Series : TGTSH not working :: HELP |
br>Synesthesia |
br>Just finished the TGTSH kit - and - it doesn't look to work ... or it's me .
Can you make a TGTSH work without a timing signal input ?
Technically, this is my first module ever, so I'm a bit stuck ( I don't have a vco, and I have a plague bearer on the way ... )
Any suggestions there ? br> br> |
br>frijitz |
br> Synesthesia wrote: | Just finished the TGTSH kit - and - it doesn't look to work ... or it's me .
Any suggestions there ? |
We can help.
The answer is no, it will not work without a timing signal. What exactly are you trying to make it do? How do you expect it to act?
Ian br> br> |
br>Synesthesia |
br>Well, sample and hold
my issue seem to be electric - when i plug my module, the second light on the bus is flashing like mad ...
so ... am I plugged in the correct sens ? the red side of the harness is at the bottom - for the -12V ... looking at the pcb, it looks correct ...
ARGHHH br> br> |
br>wetterberg |
br>sample and hold still means it needs to be told when to "hold". br> br> |
br>frijitz |
br> Synesthesia wrote: | Well, sample and hold |
Well, it needs a clock to sample and that's what the timing signal does.
Quote: | my issue seem to be electric - when i plug my module, the second light on the bus is flashing like mad ...
I don't know anything about your PS/bus/harness etc. I would suggest measuring the PS voltages.
Ian br> br> |
br>Synesthesia |
br>I have a doepfer A-100 DIY Kit #2 as BUS
When you say a clock - I suppose it would be a signal from a LFO ... can I use a CV signal ? br> br> |
br>Synesthesia |
br>it's probably a stupid question but i have to start somewhere .... br> br> |
br>sandyb |
br> Synesthesia wrote: | I have a doepfer A-100 DIY Kit #2 as BUS
When you say a clock - I suppose it would be a signal from a LFO ... can I use a CV signal ? |
i don't know the specific module you're using but, yes, a pulse output from an lfo should do the job as a clock.
sandy br> br> |
br>frijitz |
br> sandyb wrote: | i don't know the specific module you're using but, yes, a pulse output from an lfo should do the job as a clock. |
Any kind of oscillating signal at all will work. That's the main idea of the module.
A CV will not work.
Ian br> br> |
