4-Pole 3-position rotary switch...broken?
Author 4-Pole 3-position rotary switch...broken?
pleaseohplease
totally newb question, but i never used one until now...
originally it seemed to only move three positions. But upon mounting and adding a knob, it seemed to turn twelve positions. Did i break it in, or just break it?
BugBrand
You probably removed the 'limiting' washer - this is a washer with a little prong that sticks into holes around the base of the shaft -> this limits the 'stops' of rotation - mechanically the 3pole-4way switch can still travel through the full 12 rotations, it is only the limiting washer that stops this from happening in general.
pleaseohplease
On the money mr. bugs. Found it, popped it back in, works like before. Thank you so, so much.
