MUFF WIGGLER Forum Index MUFF WIGGLER
Harder, Better, Faster, Stronger
Listen to Wiggler Radio - Click Here
MUFF WIGGLER Advanced Search
OBX voice card (with non-custom CEM3310 equivalent circuits)
Goto page Previous  1, 2, 3 ... 16, 17, 18 ... 72, 73, 74  Next [all]
Post new topic   Reply to topic    MUFF WIGGLER Forum Index -> Music Tech DIY
Author OBX voice card (with non-custom CEM3310 equivalent circuits)
EMwhite
Last Visit: 26 Jan 2015
PostPosted: Sun Aug 18, 2013 10:08 am    Post subject: Reply with quote Add User to Ignore List
By the time you get done soldering [EDIT] ~2,100 components you are going to want to mount it on a pedestal in the middle of your room with spot lights shining on it from every angle as if it was sold by Swarovski.
Looking at Crow's partial build is starting to make me nervous (board weight perspective. So maybe a plexi case with slots grooved on each side wouldn't be a bad idea. I may work something up with a base footprint that rests nicely on my Kurzweil.
Btw: my panel is finished and on it's way to me, should arrive Friday. If the holes don't line up, it will be relegated to control my multi-voice SEMs project hihi. Couldn't resist taking advantage of that 20% off special. Will see hmmm.....
Beware of programmers with screwdrivers...
negativspace
Manhattan Analog
PostPosted: Sun Aug 18, 2013 10:18 am    Post subject: Reply with quote Add User to Ignore List
1200... I routinely do that in a day or two of building Manhattan Analog modules. Sounds fun!
cretaceousear wrote:
But really, why don't we dream more music?
mOBiTh
PostPosted: Sun Aug 18, 2013 12:53 pm    Post subject: Reply with quote Add User to Ignore List
i can't stand perspex cases, yuk, they're so bendy (especially on one this big!) and cheap feeling, and the edges feel horrible Dead Banana
Think I'm gonna go wood and metal with plenty of ventilation It's peanut butter jelly time!
you only live once - may as well have the best synth... hihi
SND1: http://soundcloud.com/mobith/sets/mobith-2012/
SND2: http://soundcloud.com/mobithsynth
oldcrow
PostPosted: Sun Aug 18, 2013 2:15 pm    Post subject: Reply with quote Add User to Ignore List
EMwhite wrote:
Looking at Crow's partial build is starting to make me nervous (board weight perspective).
When it is finished I will have a support system in place to hold the voice cards. I originally wanted to install them vertically, but they're too long to fit in a 5U height. So, I will use between-board nylon spacers and an edge frame. --Crow
http://www.last.fm/music/Scott+Rider
View user's profile Send private message Send e-mail AIM Address Yahoo Messenger
The Real MC
PostPosted: Mon Aug 19, 2013 12:07 am    Post subject: Reply with quote Add User to Ignore List
Verified large shipment of components from Digikey from my BOM, and all is correct!!
I haz a wrench, to fix da synth.
http://www.retrosynth.com/~analoguediehard/
The Real MC
PostPosted: Mon Aug 19, 2013 12:22 am    Post subject: Reply with quote Add User to Ignore List
oldcrow wrote:
Slowly the master vision takes shape: here is a nearly-finished host board with a fully-populated carrier board mounted to it, and the carrier board loaded with a slot adapter and attached crowbx voice board.
More later,
Crow
That is (going to be) one seriously dense module!
gslug
PostPosted: Mon Aug 19, 2013 5:58 pm    Post subject: Reply with quote Add User to Ignore List
That is one seriously impressive piece of gear! The TSSH is what finally persuaded me to join the forum, but I'll have to get one of these too...
One day I'll get an avatar!
suitandtieguy
Hammond King
Last Visit: 02 Jan 2015
PostPosted: Mon Aug 19, 2013 9:11 pm    Post subject: Reply with quote Add User to Ignore List
this is exciting!
http://suitandtieguy.com
http://stgsoundlabs.com
suboptimal wrote:
... if it's music you want to make with your modular, STG should be in your system.
View user's profile Send private message AIM Address
mikecameron
Thread Killer
Last Visit: 25 Jan 2015
PostPosted: Tue Aug 20, 2013 3:08 am    Post subject: Reply with quote Add User to Ignore List
Just added the rev1 single voice and rev. 2 4-voice crOwBX to the gear list for Knobcon. Looking forward to getting my eyes and ears on this thing oldcrow!
oldcrow
PostPosted: Tue Aug 20, 2013 10:21 pm    Post subject: Old Crow and the Art of Cap-fu Reply with quote Add User to Ignore List
Due to the dense packing of boards, I knew there would be a few "interesting" mounting requirements for the larger components in the "regulator" corner of the voice and slot adapter boards. It turns out voice boards #2 and #4 along with slot adapters #1 and #3 will use a capacitor mounting scheme like this. Perhaps in a future rev I'll go to SMT electrolytics.
Voice board, the slot card is shown positioned closer than the actual mounting dimension to verify the clearances.
Slot adapter capacitor and 78/79L15Z regulator detail. Also note the close trimming of the KK156 male headers needed on slot adapters #1 and #3.
Almost done with first of four rev2 voice boards...
negativspace
Manhattan Analog
PostPosted: Wed Aug 21, 2013 12:27 pm    Post subject: Reply with quote Add User to Ignore List
Mouser stocks a pretty good array of through-hole aluminum organic polymer caps, it might be worth a browse through their catalog. I've used some 100uF that are only 5mm high or so and would probably work here.
oldcrow
PostPosted: Wed Aug 21, 2013 2:17 pm    Post subject: Reply with quote Add User to Ignore List
Yep, I'll have a look at other cap case types. I'm just using what I have here already for these proof of concept builds. --Crow
The Real MC
PostPosted: Wed Aug 21, 2013 2:20 pm    Post subject: Reply with quote Add User to Ignore List
Axial caps may be another solution
oldcrow
My Haribo "Gold-Bears" sample packet arrived today. It came with this complimentary front panel! SlayerBadger! SlayerBadger! SlayerBadger!
mikecameron
Thread Killer
PostPosted: Wed Aug 21, 2013 2:36 pm    Post subject: Reply with quote Add User to Ignore List
"REV 2 Knobcon Edition"
baylortrewerton
Last Visit: 05 Dec 2013
PostPosted: Wed Aug 21, 2013 6:01 pm    Post subject: Reply with quote Add User to Ignore List
oldcrow wrote:
parquix wrote:
Is there sound demo out there? Can't wait to hear it!
Getting to that as soon as I can, right now I am trying to build and test a full rev2 4-voice system in time for a conference. --Crow
Does this mean you're going to be at Knobcon? I was on the fence before, but now....
negativspace
Manhattan Analog
PostPosted: Wed Aug 21, 2013 6:08 pm    Post subject: Reply with quote Add User to Ignore List
Those panels they send with the gummi bears rock.
oldcrow
PostPosted: Wed Aug 21, 2013 6:42 pm    Post subject: Reply with quote Add User to Ignore List
Yes. I would have gone last year if I'd known about it: the place is 20 minutes from my house. Guinness ftw! Guinness ftw!
oldcrow
PostPosted: Wed Aug 21, 2013 8:18 pm    Post subject: Reply with quote Add User to Ignore List
One rev2 voice board done, three to go... SlayerBadger!
paults
mice nuts
PostPosted: Wed Aug 21, 2013 8:54 pm    Post subject: Reply with quote Add User to Ignore List
Over 65 trimmers??!? sad banana Dead Banana
Post new topic   Reply to topic    MUFF WIGGLER Forum Index -> Music Tech DIY All times are GMT - 5 Hours
Page 17 of 74
