newbie question about link on oakley dizzy board
Author newbie question about link on oakley dizzy board
Blake Smith
Hi there,
This is probably a silly question, but I'm wondering if there is any need to wire in the optional links into any of the "R" positions on the dizzy board if I'm going to be using it with a Blacet PSU?
Thanks,
Blake.
Synthbuilder
I'd fit R3 if you are going to be using the Oakley Buss. R1 should be omitted and R2 can be omitted.
R2 will ground the earth point on the Dizzy. Now I don't know how the Blacet PSU earths itself. I would assume that their ground is indeed hardwired to earth. However, this may not be the case so you should check with their documentation. If it is then you can omit R2. If it isn't then R2 should be fitted and the Dizzy's earth point should be taken to the earth bonding point on your power supply inlet - using appropriate wiring and hardware.
Tony
