Old School Sequencer?
Author Old School Sequencer?
TimeActor
After the build of my oakley modular system later this year i´m planing to build an diy sequencer.
Is there an 3 row with 8 steps per row diy sequencer out there?
I like the moog 960 form or everything similar.
The Klee sequencer doesn´t have seperate row´s? Is that right?
Or is Tony in developement of an analog sequencer? love
jbi
Take a look at the MFOS sequencer at http://www.musicfromouterspace.com/analogsynth_new/SEQ16_2006/SEQ16_20 06.php
I'm just waiting for the boards from the US before I start the build. I've also done a 5U fpd for the front panel if you're interested.
John
TimeActor
Hi John and much thx for your reply!
The MFOS i didn't think anything of it.
I´ll take a look at this!
Yes i´m very interested about your design! Can you show me?
Martin
jbi
Here's the 5U panel design. Waiting for it to arrive from Schaeffer, but I think it will work.
RealDudes
check out the hex-inverter simpleSeq
http://shop.hexinverter.net/category.php?id_category=5
TimeActor
Thank you jbi - i´ll take a look (or two) on this!
@RealDudes,
thank you too - there is only one direction (forward) how the sequence run isn´t it?
TimeActor
@jbi,
Hi John - i like your design much! More than the funny circle design i saw.
For me it is better to see the steps horizontal for better sequence controll!
Has the MFOS Step Seq seperate rows?
I like to use one row for pitch the other row for filter sweep or anything.
I want to use 3 rows -this row additional for length, volume or something but i didn´t find a diy sequencer project with this functionality and completely analog useability. (i must build a second one then!)
kecked
Look at the www.picaxe.com website and go to the forum. Look under completed projects and you'll see one I did that is as you ask but based on a micro and a chip similar to 4066 switches but run by the spi interface. Worked well for me and has the added benefit that you can select the note and octave of every note in the sequence with pots. I tried to find a nested pot so the inner ring was note and the outer was octave but the cost too much. I also wanted he shaft to have an led to show the sequence position but again too expensive. You can select the length of the sequence and make it go forward, backwards or back and forth. You can change the rate with a pot and it has a fast and slow setting. I list the code for the micro as well and it is in basic so almost anyone can modify it. I believe it is 16 or 24 steps but it has been a while since I played with it.
If you don't want the note/octave then just use them as separate sequences.
http://www.picaxeforum.co.uk/showthread.php?22384-16-channel-analog-vo ltage-sequencer-for-analog-synthesizers
TimeActor
Hello kecked,
is it possible to show a pic of your sequencer here?
To see the pic it is necessary to login in but i don´t like.
Thx!
Martin
kecked
#picaxe 28x2
' Converted by X2 Conversion Wizard Version 2.0.5 (2010r4.1)
let dirsB = %11111111
let dirsc= %11111111
let dirsa=%00000000
let adcsetup = 0
main:
readadc a.2, b4 'number of steps
b4=b4/16
if pina.1=1 and pinc.0=0 then goto forwrd:
if pina.1=0 and pinc.0=0 then goto backwrd:
if pina.1=1 and pinc.0=1 then goto arpforwrd:
if pina.1=0 and pinc.0=1 then goto arpbackwrd:
forwrd:
For b0=0 to b4 step 1
readadc10 a.0, w4
If pina.3=0 then let w4=w4/2 endif
If pina.3=1 then let w4=w4*2 endif
let pinsb=b0
pulsout c.7, 10
w4=w4+1
pause w4
next b0
goto main
backwrd:
For b0=b4 to 0 step -1
readadc10 a.0, w4
let pinsb=b0
pulsout c.7, 10
w4=w4+1
pause w4
next b0
goto main
arpforwrd:
readadc10 a.0, w4
let pinsb=b0
pulsout c.7, 10
w4=w4+1
pause w4
next b0
readadc10 a.0, w4
let pinsb=b0
pulsout c.7, 10
w4=w4+1
pause w4
next b0
goto main:
arpbackwrd:
readadc10 a.0, w4
let pinsb=b0
pulsout c.7, 10
w4=w4+1
pause w4
next b0
readadc10 a.0, w4
let pinsb=b0
pulsout c.7, 10
w4=w4+1
pause w4
next b0
goto main:
TimeActor
?? hmmm.....
kecked
that's the code for the microprocessor to run the sequencer.
I've had my eye on the sequentix cicrkon or whatever its called.
http://www.sequentix.com/
TimeActor
Ah ok,
I've been Looking for an diy sequencer after building my oakley System.
