last few module, maybe utilities?
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Eurorack Modules
Author last few module, maybe utilities?
loudone
Last Visit: 18 Mar 2012
PostPosted: Mon Oct 12, 2009 11:45 pm    Post subject: last few module, maybe utilities? Reply with quote Add User to Ignore List
Last few for the first 6u case that is Flamey
what other utility modules do i need, what would you add to the last 20 hp
The plaugebearer is top of my list, but would something else be more useful, cv buffer, sample/hold noise modular....? hmmm.....
dougcl
Number 6
Last Visit: 20 May 2013
PostPosted: Mon Oct 12, 2009 11:57 pm    Post subject: Reply with quote Add User to Ignore List
Ring mod, cross fader, S&H, Comparator, slew
loudone
PostPosted: Tue Oct 13, 2009 12:17 am    Post subject: Reply with quote Add User to Ignore List
hmmm..... dougcl,
I must say i respect your advice very much on here.more so than lots of people on here.
you seem, at least from posts i have read, blunt, to the point, and sensible.
Now,how do i get that all into 20 hp, when only two more modules can be doepfer power based, the others have to be bi ole Asys.
Also, what does the comparator do, and how important is slew, and what exactly does it do?
Any idea on what modules combine some of these nifty functions i know little about? help
MicroFi
Last Visit: 21 May 2013
PostPosted: Tue Oct 13, 2009 1:36 am    Post subject: Reply with quote Add User to Ignore List
Doepfer Dual S&H > 4HP
Doepfer Dual Ringmod > 4HP
Slew = portamento
loudone
PostPosted: Tue Oct 13, 2009 2:24 am    Post subject: Reply with quote Add User to Ignore List
gracias micro-fi
that leaves 12hp, perfect for 2 Asys or 1 Asys. Asys has a handy mod, the AS 380. it is 12 hp, has a vc-lfo, noise generator, vca, and sample and hold function.
what about attenuation, crossfader, and slew?
Asys has a 6hp slew limiter, and a 6 hp ring mod, with multiples on it as well.
it seems like i need five functions but can only fit for no matter how i cut it.
very frustrating
i guess i can take the mult. out of the unit and have another 6hp. hmmm..... , let the mult hang out on the side?
Umcorps
Will patch for food
Last Visit: 23 May 2013
PostPosted: Tue Oct 13, 2009 2:30 am    Post subject: Reply with quote Add User to Ignore List
MicroFi wrote:
Slew = portamento
Slew= = waveshaper.
So it can be like a LP filter when it's short enough and is being fed an audio signal. Or it can turn pulses and gates into ramped waveshapes.
And it does portamento. thumbs up
It's a lot more useful that you think it's going to be. And the Doepfer one is good because it's small and does asymmetric shaping. Turns up in the majority of my patches, usually in quite unexpected places.
loudone
PostPosted: Tue Oct 13, 2009 2:45 am    Post subject: Reply with quote Add User to Ignore List
cool thanks Umcorps.
Both the doepfer slew modules are 8hp, Asys one is actually smaller for once at 6hp!
But the doepfer is dual where as the asys is vc and a single slew. the other doepfer is a vc controlled one as well, single slew.
I think i am gonna have to buy another rack way sooner. Dead Banana
anselmi
PostPosted: Tue Oct 13, 2009 6:15 am    Post subject: Reply with quote Add User to Ignore List
what´s about some LFOs?
MFB got some dual and small modules with sync feature
you can also go for the uLFO that is bigger but awesome
authorless
PostPosted: Tue Oct 13, 2009 6:42 am    Post subject: Reply with quote Add User to Ignore List
also, to add to the onslaught of pro-slew limiter propaganda, feed a slew limiter a gate signal and you have an ASR envelope. if you swapped the asys mult with the doepfer mult you could free 4HP (no need for a mult to be as big as the asys if it isn't buffered).
a comparator takes two signals and outputs a high signal if the first signal if a higher voltage than the low signal.
View user's profile Send private message Yahoo Messenger
loudone
PostPosted: Tue Oct 13, 2009 6:59 am    Post subject: Reply with quote Add User to Ignore List
I came up with some ideas for the last 20hp
authorless, i already have everything in there on the first post on its way on some brown or white truck. It's peanut butter jelly time!
but yeah, slew seams big so I did find a Plan B model26 cv processor. it has three functions, slew, binary gate, boolean, and some other thing that i am unsure of. I know about the no plan b, But if i buy it from a store that has it in stock, isn't that supporting the retailer from losing money on stock sitting there? hmmm.....
Yes i would really love more lfo too! anselmi, the vulcan is a dual lfo i bealieve.
so here is one idea....
loudone
PostPosted: Tue Oct 13, 2009 8:03 am    Post subject: Reply with quote Add User to Ignore List
i can just take the ultiple out and have it there hanging on the side correct? huh?
it doesn't use any power.
that frees up 6hp( the Asys/doepfer swap would only save me 2 hp, though that would be valuable).
loudone
PostPosted: Tue Oct 13, 2009 8:29 am    Post subject: Reply with quote Add User to Ignore List
here is another idea... applause huh?
wetterberg
Last Visit: 16 Mar 2013
PostPosted: Tue Oct 13, 2009 8:46 am    Post subject: Reply with quote Add User to Ignore List
this last one is pretty dope.
LFO? THe Envelope gens will oscillate too, which means including the Vulcan you're looking real good.
I would personally have gotten another "real" oscillator instead of the Asys VCA - including the QMMG you have 7 in that example. How about a second "normal" oscillator up in there?
How much of this have you bought already?
View user's profile Send private message AIM Address MSN Messenger
astroschnautzer
PostPosted: Tue Oct 13, 2009 8:49 am    Post subject: Reply with quote Add User to Ignore List
a 4hp multiple like the doepfer would give you 4hp more space...
wetterberg
PostPosted: Tue Oct 13, 2009 8:52 am    Post subject: Reply with quote Add User to Ignore List
which was why I asked what was already bought smile Lets us critique this a bit better.
authorless
PostPosted: Tue Oct 13, 2009 8:53 am    Post subject: Reply with quote Add User to Ignore List
you could have the mult outside of the case but just don't let it come into contact with the face plates of the modules in the case.
loudone
PostPosted: Tue Oct 13, 2009 9:47 am    Post subject: Reply with quote Add User to Ignore List
the very first post in thread is what is coming on the 14th in an Asys 6u rack.
It has 8 doepfer power supplies.So in the first set up i am using 6. The 160 and 161 run off one power supply. You guys probably know that though. thumbs up
If not there is the scoop. I do plan on growing soon enough, those 6u monorockets look pretty nice whistlin'
So, critique away my friends Rockin' Banana!
And about the multiple being outside, is it just the face plates that will cause trouble, or any metal woah
this shit i need to learns about..quckly d'oh!
astroschnautzer
PostPosted: Tue Oct 13, 2009 10:05 am    Post subject: Reply with quote Add User to Ignore List
Okay better that I read the topic otherwise I will only give stupid answers smile
Last edited by astroschnautzer on Tue Oct 13, 2009 10:15 am; edited 2 times in total
wetterberg
PostPosted: Tue Oct 13, 2009 10:10 am    Post subject: Reply with quote Add User to Ignore List
okay, in that case:
get the doepfer dual ring mod
get the doepfer dual s+h
get the MFB osc-02.
- on top of the original layout. You definitely don't need the a-147 when you have all that other stuff.
loudone
PostPosted: Tue Oct 13, 2009 7:08 pm    Post subject: Reply with quote Add User to Ignore List
wetterbug, i can only put two more doepfer power connecter style modules, my case only takes 8.
plus i am keeping my fingers crossed that the sem i ordered gets sent next month. So i do have lfo, 2osc, and such on that little gem thumbs up
Forgot to mention I had that coming. hihi
But the doepfer dual ring, and also the sample and hold are a great idea. As well i did check out the mfb offerings, i even thought about grabbing a kraftzwerg which has all kinds of goodies and saves rack space.
but that is out of budget at this point Dead Banana
we need a burning wallet emoticon!
loudone
PostPosted: Tue Oct 13, 2009 8:05 pm    Post subject: Reply with quote Add User to Ignore List
Here is another idea guys.
hmmm.....
what do you folks with experience think.
i know i end up with three sample and hold, but the rs 380 also has an lfo, vca, noise, s/h. the noise and lfo are nice and the xtra smaple and hold can be interesting. seriously, i just don't get it
i guess??
DGTom
Last Visit: 10 May 2013
PostPosted: Tue Oct 13, 2009 8:21 pm    Post subject: Reply with quote Add User to Ignore List
That makes 6 VCAs / Gates & two EGs - altho the LPGs will all respond OK to gate pulses from the 160/161 thats where Slew Gens. come in handy as really nice envelopes.
I can't see a S&H on the RS380 hmmm..... In that 6U I think there is alot of sound processing / interesting sound sources without the Dual Ring Mod.
Best bang for the space IMO would be the RS-40 - only downside is the Clock isn't VC but that saves your complex LFOs from being stuck doing Clock duties, also gives you a nice little performance interface with the manual S&H trigger, Noise level & Clock Freq. all next to each other.
Then the Doepfer Dual Slew in the last 8hp - that covers alot of bases for 6U & alongside the SEM makes a pretty good base from which to build.
With all this coming in big lumps watch out for modular induced cabin fever & don't forget to eat every once in awhile SlayerBadger! hihi
mateo
Last Visit: 14 Mar 2013
PostPosted: Tue Oct 13, 2009 8:28 pm    Post subject: Reply with quote Add User to Ignore List
Just out of curiosity, what case/rack are you putting these in? I'm trying to figure out which cases are available that will properly fit Asys modules along with the rest
loudone
PostPosted: Tue Oct 13, 2009 8:32 pm    Post subject: Reply with quote Add User to Ignore List
Thanks DGtom, i will go back to rackplanner, Oh darn hyper
Eating is for Suckas! SlayerBadger!
loudone
PostPosted: Tue Oct 13, 2009 8:35 pm    Post subject: Reply with quote Add User to Ignore List
mateo, I am using an Asys rs15 i believe. It is the 6U version, from bigcity music.
Thanks again Josh! thumbs up
He was a big help in helping me get going. Put up with a few hours of me asking the same question ten ways upside down d'oh!
loudone
PostPosted: Tue Oct 13, 2009 8:43 pm    Post subject: Reply with quote Add User to Ignore List
Also DGTom, is the ext clock in on the rs 40 able to use a an audio source for time, like a click track or some other external audio input?
Or would that be the sample and hold function? I am still confused... ijust need to get in the machines and play abit and not worry about what "I need". I will buy more I am sure anyway soon enough!
this is may be it for now... nanners
if any one disagrees with this here union of electrical devices, speak now or forever hold your peace.
Guinness ftw!
DGTom
PostPosted: Tue Oct 13, 2009 9:01 pm    Post subject: Reply with quote Add User to Ignore List
The RS-40 is pretty much like a standard "S&H" block you'd find on an old mono-synth or similar but its not normalled together - the lines on the panel between Noise Out -> Ext In & Clock Out -> Ext. CK In just imply those comman connections.
The Ext. CK In is the trigger for the S&H, it'll take the RS-40s clock, or any of the outs from the 160/161, an external click - say from a DAW or sampler will prob. work, I'd sample the RS-40s own clock & use that, I use my MPC for triggering / clocking modules - just sampled a modular clock into it.
thumbs up I think you'll know within a week exactally where you find yourself saying 'dammit'
Muffwiggler makeover FTW - 'the modular diet & studio tan' lol
Edit: That looks pretty tight nanners lots of juicy sounds in there for sure!! I would live with that for awhile before expanding anymore, theres loads you can do that probally isn't obvious at first, as is you've got a sequencer to build, up to four EGs, a buttload of modulation & (if 'musical' tuning isn't your thing) a crazy sick ass 3 Osc mono synth screaming goo yo Good call w/ the QMMG & ASys VCA as well, pretty much all the audio mixing you'll need all wrapped up nicely.
mateo
PostPosted: Tue Oct 13, 2009 9:14 pm    Post subject: Reply with quote Add User to Ignore List
Hmm, won't you have a problem mounting Asys modules next to the others due to the different positions of the screw holes? Might want to double check that, or you might find yourself with a couple of HP less than you thought!
loudone
PostPosted: Tue Oct 13, 2009 9:51 pm    Post subject: Reply with quote Add User to Ignore List
mateo
Well the borg filter has enlongated holes, and if i need too, i am pretty adapt with a file and can enlongate some holes myself on a modular or too if need be. I will see when i get most of the modules in and see what happens.
hmmm.....
i hope....
I can have one row all Asys, and the other all doepfer/other plus the multiple which i will not be all eek! about filling out holes or bringing it to my friend at the machine shop for a little trim or adjustment.
mateo
PostPosted: Tue Oct 13, 2009 10:35 pm    Post subject: Reply with quote Add User to Ignore List
If I understand correctly (I am new to this myself so don't take my word for it), you'll be able to do a Asys row with the borg filter fine, but your second row will have a gap at each end, totalling 1HP (and that's asuming you file holes into your asys multiple)
dkcg
PostPosted: Tue Oct 13, 2009 10:48 pm    Post subject: Reply with quote Add User to Ignore List
loudone wrote:
mateo
hmmm.....
i hope....
I use the small round file from a set of Nicholson Miniature files. No. 12030
Works great for elongating round holes! I've had the set for years, and it works great as sharp as the day I bought them. The Analogue Systems faceplates are thicker than every other faceplace, I'll only file those if I have to.
I'd be careful about using anything from a machine shop since you'd have to take the faceplate off, or else risk damaging the module with a little slip. Small file takes a little longer than a drill or dremel, but it's rare I file more than a module or two at a time.
Hurrah for Cwejman, Malekko, Metasonix and any other makers who have elongated holes! applause thumbs up
Looks like if you put the borg and one more asys module together up there, you might only have to file one module. razz
loudone
PostPosted: Tue Oct 13, 2009 11:07 pm    Post subject: Reply with quote Add User to Ignore List
dkcg wrote:
loudone wrote:
mateo
hmmm.....
i hope....
Thats one big quote. meh
So yes, i will only have to adjust the multiple it looks like, and i can take the plate off that if need be for adjustments. And i already got me a bunch of nicholson files. thumbs up
felix
Loves the manuals!
Last Visit: 08 May 2013
PostPosted: Wed Oct 14, 2009 4:19 am    Post subject: Reply with quote Add User to Ignore List
hehehehe....elongated holes.
http://felixinferious.blogspot.com
http://felixinferious.bandcamp.com
View user's profile Send private message Send e-mail AIM Address
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Eurorack Modules All times are GMT - 5 Hours
