Pan tremelo
Author Pan tremelo
bcitral
Tony, do you do a module that will do pan/ tremelo?
Like the old boss pn2 pedal.
the pedal I was going to use requires quite a bit of modification so would be easier to build one from scratch.
thanks Paul
Synthbuilder
The 5U Classic VCA and Dual-VCA modules will do panning. You'll need a LFO of some sort to modulate them though.
Tony
bcitral
So could I tap out of the filtrex with its lfo to drive the vca module?
the dual vca isn't ideal as I really wanted independent lfo rates on the filtrex and on the pan module though. The power supply is going to be reaching its max capacity too if I use the dual VCA, an additional lfo module would exceed my motm power supply.
Will I get a similar signal routing with this modules ie; mono to stereo or stereo to stereo? like the boss pn2 pedal? I bought a behringer pn2 copy but the components they use make it difficult to modify.
I was going to hard wire the mono signal in and have a channel 2 input to the other input.
I was going to use my filtrex 1 as the input 2.
I tapped out of the trigger section on the filtrex 1 so I can control filt 2 making a semi stereo unit with what I've already got.
If I can't do anything with the pedal Ive got, then the vca may be the way to go.
Thanks Paul
