4HP Little LFO...is this possible?
Author 4HP Little LFO...is this possible?
jonkull
I want to add an LFO to my rack but only have 4HP free at the moment. Is there any reason why I wouldn't be able to squeeze this behind a 4HP panel?
authorless
if peter grenader can do it so can you!
jonkull
Funny...the same thing occurred to me while looking at the M37 on the BCM website.
krisp14u
The little LFO PCB would not be ideally suited to a 4HP panel
There is a width of around 25mm when using Alpha pots and the recommended pot brackets to hold the PCB to the faceplate and 4HP is only around 20mm so there will be some overhang of the PCB and or pot's hmmm.....
That said with the right pots and some imaginative SDIY work I don't think it would be too hard to do thumbs up
jonkull
Well I guess I'll have to look for pots first then before I buy the PCBs...
jonkull
Would these Bourns 9mm pots work?
http://www.bourns.com/data/global/pdfs/3310.pdf
or
http://www.bourns.com/data/global/pdfs/90sers.pdf
