TM3030 power supply ?
Author TM3030 power supply ?
analog therapy
hello I practice synth DIY for 5 months so I'm a novice and I'm almost finished my TM3030, the problem is that I do not understand what power is best for someone like me who lives in europe. If someone can tell me from the power sector that I found which can operate safely for my TM3030 it will be great!
number 1: Power Adjustable Power 9 V, 12 V, 13.5 V, 15 V, 18 V, 20 V, 24 V DC 1000 mA 24 W VOLTCRAFT SPS24-24W
Power / compact power adapter with adjustable output voltage, constant.
Output voltage 12.09.13, 5/15/18/20 V / DC 24 V / DC
Choice of voltage via jumpers
DC connection cable 1.5 m
Protection against overload and short-circuit
2 plugs on jack: 2.5 mm and 3.5
6-pin male hollow (OD / mm interior) 5.5 / 2.5, 5.5 / 1.5, 5.5 / 2.1, 4.0 / 1.7, 3.5 / 1, 35; 2,35 / 0,75
7 riders
Number 2: PSSE29 power 220v 110v usb 5v 15v 16v 18v 19v 20v 22v 24v switching power supply 70W
Input: 100-240V 50/60Hz 1.8A
power: 70W
max. output current: 2950mA
8 selectable output voltages: 15Vdc: 4A 16/18/19/20Vdc: 3.5A, 22/24Vdc: 2.9A, USB (5Vdc): 500mA
plugs: 5.5x2.1 - 6.5x4.3x1.4 - 4.8x1.7 - 5.5x2.5 - 6.3x3.0 - 5.5x1.7 - 4.0X1.7 - 3.5x1.35
Number 3: Power 40W multi-mode voltages.
- Input voltage: 100-240VAC ~ 50/60Hz
- Output voltage: 12-24VDC - no 1V
- Extra output 18.5 V and 19.5 V
- Maximum power: 40W (Max 2.5A)
- 8 detachable DC plugs
- Output stabilized minimum ripple.
- Protection against short circuit and overload.
- High efficiency and low energy consumption.
- Conforms to European directives.
- Suitable for many applications thanks to the DC connectors supplied:
6,5 x1, 5 / 6,3 x3 / 5,5 x2, 5 / 5,5 x2, 1 / 5.5 x 1 / 4,95 x1, 98 / 3,5 x1, 35 mm.
Number 4: Mains controlled - Multi-voltage - 9/24V - 24W
Adjustable output: 9.12, 1.5A 15V, 18, 20V 1.2A, 24V 1A
24W power
Supplied with 7 plugs: 2.5mm mono, mono 3.5mm, 1.0x3.0mm, 1.35x3.5mm, 1.7x4.0mm, 2.1x5.0mm, 2.5x5.5mm, 1.5x5.5mm
I hope at least that there is a good one because that's all I've found that matches the instructions in construction Guide TM3030.
I Thank all in advance who can help me.
Bests regard, Analog therapy!
Synthbuilder
Those all look they would work but they all seem too complex or overly powerful for the TM3030. We have different plugs here in the UK, but Banzai (in Germany) sell various ones that would work. For example:
http://www.banzaimusic.com/EH-18V-DC-EU-500mA.html
Tony
analog therapy
thank you for your reply! thumbs up
