"Choices" gets no power from LC9 case-others work
Gear, Suggestions and Discussion.
Moderators: Kent, infradead, computer controlled, flight
boondibis
Post by boondibis » Tue Oct 01, 2013 12:03 am
I have a Flight of Harmony choices which, no matter what cable I use or power point I plug into, does not function when connected to my Doepfer A-100-LC9 case.
To confuse matters, when I plug the Choices into my Pittsburgh Modular Double Cell 90 case, it works just fine.
Is there any reason why my Doepfer LC9 cannot power my Choices module? I thought all Eurorack power was the same juice. Why would it work in the Cell 90 but not the LC9?
Just to be clear, I am using the proper power cable, and the -12v is lined up correctly. Any help would be greatly appreciated, I really want my choices in the LC9 case, as I am probably going to sell the Cell 90 soon.
flo
Space Jack
Post by flo » Tue Oct 01, 2013 2:03 am
How far away from max power consumption (on the whole case) are you?
boondibis
Post by boondibis » Wed Oct 02, 2013 1:45 am
I'm not actually sure, but I guess it is probably a good idea to check into that.
I would have figured with like 14 power connections per bus board, so almost 50 total, that it could handle the 18 or so modules I have in there no problem. I really hope it's not because it doesn't have enough power for the modules, as the last row of the case is only half full. What's the point of a case that big if it doesn't have enough juice to power enough modules to fit it.
Anyway, can I calculate the power consumption on modulargrid.net or something? Or do I have to just add it all up from the various module manuals?
flo
Space Jack
Post by flo » Wed Oct 02, 2013 1:48 am
Yeah check it on modulargrid, but make sure to count in the occasional module for which the power requirements are not listed on there...
Return to “Flight of Harmony”
