Program with three clock dividers for the Ardcore Expander
Discussion and Support for our Atmospheric Modification Devices.
Moderators: Kent, infradead, loss1234
Alwaysnew
Post by Alwaysnew » Sat Oct 26, 2013 12:36 am
This is my first version of a compound clock divider sketch for the expander:
https://github.com/Magnus-G/Ardcore/blob/master/Clocks
Feed a clock in "Clock in" and set A0 to select one of these programs:
Cycle Program
Stepping through 0-7 outputs with a trigger on each clock in.
Set A0 to full CCW.
Halves Program
Clock goes out each time on output 0, every second time on 1, every fourth time on 2 and so on.
Set A0 to noon.
Divider Program
Clock goes out each time on output 0, every second time on 1, every third time on 2 and so on.
Set A0 to full CW.
Drum Program
Inspired by Grids by Mutable Instruments
There is a 1 second signal as the program is changed.
Any comments or feedback is welcome!
Alwaysnew
Post by Alwaysnew » Sat Oct 26, 2013 5:27 pm
Now updated with probability control on A2!
Alwaysnew
Post by Alwaysnew » Sat Oct 26, 2013 6:20 pm
And now updated with internal clock if A1 is not fully CCW (it then only reacts on "Clock In" trigging)
pulsewidth
Post by pulsewidth » Fri Nov 08, 2013 12:51 am
I just received my Ardcore expander today and loaded this sketch. This is fantastic. The perfect companion to my Rene! Thank you for this!
Alwaysnew
Post by Alwaysnew » Sun Nov 10, 2013 6:27 pm
Thanks! I have now updated it to contain a fourth program that produces drum patterns (a bit like Grids but with 8 outputs). Take a look at the code and add your own patterns in the drum matrixes. Let me know if it's useful and I'd love to create a drum pattern library so upload yours!
(New link to code above)
makaton
Post by makaton » Tue Nov 12, 2013 6:38 am
Thank You.
Return to “SNAZZY FX”
