GRP R24 Sequencer (Standalone + 5U)
sonicwarrior
Post by sonicwarrior » Thu Nov 14, 2013 8:00 am
Facebook sucks. Don't know how to create a direct link to a Faceboogle article. Anyway somewhere here: https://www.facebook.com/GrpSynthesizer ... n=timeline is an article/entry about an upcoming GRP Synthesizer R24 sequencer.
I'll just put a quote in:
Not only synthesizers! Here at Grp headquarters, we are creating the new R24 Analog Step Sequencer. Based on the same visionary sequencer engine previously tested on the great Grp A8 and on the mighty Grp A4 synthesizers, the new R24 expands programming and interaction capabilities between man and machine. R24 can be used in CV/Gate, MIDI and USB environment, in 8x2, 16+8 o 24 step configuration, with steps freely programmable, permutable and repeatable from front panel - independently on each row. All that was previously achievable on the old A8 and A4 Step Sequencer(s) is now available on the brand new R24, with a wealth of new - terrific - functions. Below, you'll find a first list of functions.
Grp R24 Analog Step Sequencer - preliminary info
The Grp R24 is a 8x3 analog step sequencer firmly based on the mighty step sequencer previously developed in Grp A8 and A4 Analog Synthesizers. The new R24 is full of control capability with CV/Gate, MIDI and USB connections. Hardware-wise, is stand-alone self powered, with hardware compatibility for mount on 5U module format; you can use in stand alone with its internal power, or you can install in your Dot.com/Cotk/Moon Modular system. R24 respects electrical and mechanical standards for the above manifacturers. Still, you can use R24’s own cabinet as a “presto-cabinet” for powering and using your spare 5U modules.
R24 has 128 internal memories for store and retrieve separate sequences; each sequence can be set in 8x2, 16+8 or 24 mode, with any step lenght user’s selectable.
R24 can act as CV/Gate sequencer or as MIDI sequencer, with separate rows for MIDI Note selection and for Key Velocity step adjust.
Is it possible to stack together several R24 units for long sequences in series o for more simultaneous parameter control over parallel rows.
Step Parameters. Each step has:
- CV Value freely programmable and adjustable in real time;
can be routed to Gate 1 bus, Gate 2 bus, Off (non Gate output);
- can be rythmically repeated in “Ratchet Mode” selecting X2 (simple bounce), X3 (triple bounce) or Off (no bounce);
- every bounce/ratchet mode works at double or triple speed - instant TaDream...
_can be used in Normal Mode, Skip Mode (step skipped for sequence length shortened) or End Step Mode (for define the final length of sequence)
Row Parameter. Each horizontal row has indipendent settings for:
- Glide time;
- CV Range X2, X4, X8 octave;
- Sample & Hold value On/Off (for prolonging values between contigous steps);
- Quantize On/Off (in V 1.0 you have standard semitone quantization; next firmware revision will have several quantizing masks user’s selectable);
- Six different permutation Orders selectable; for choose the playing/advance order of steps (the combinations previously available only in the Grp A4 or A8 Step Sequencer, plus several other fun modes…);
- (global) selectable Step Repetition; X2, X3, X4 repetitions before advance to the next step;
- Indipendent (full) Row Repetition (useful in chain 16+8 or 24 step mode); X2, X3, X4, infinite repeat;
- Each Row has indipendent Clock Divider; /2, /3, /4, /6, /8; divider works on Internal, TTL Ext Analog and External MIDI Clock; each row can advance at different rhythmic speed;
- Row B and C can be used with their own set of parameters in full indipendence (e.g., three different sequences in 8x3 A,B,C mode); or but you can decide to use Row A parameters over rows A and B (useful for quick program in 16+8, A+B,C mode); still, you can use Row A parameters over A, B and C (useful for quick program in 24 mode, A+B+C); buttons ON on B and C sets indipendence for Row B and C.
Row Connections on front panel. Each row has dedicated analog connection for:
- Gate Out 1 bus (internally normalled for cascading rows on single hardware connection);
- Gate Out 2 bus (internally normalled for cascading rows on single hardware connection);
First available/active step Gate out (useful for start/stop several sequencers network connected);
- End available/active step Gate out (as above, for serial connection of several sequencers);
- CV Out (internally normalled for cascading rows on single hardware connection);
- CV Control In for Order select (a specified CV received from external unit wil select the desidered Order for corresponding row);
- CV Control In for Row Repeat select (as above);
- CV Control In for Step Repeat select (as above);
- CV Control In for Clock Dividing factor select (as above);
. CV Control In for Transpose (internally normalled for simultaneusly transpose of several rows with a single connection from exterrnal analog equipment).
Sequencer Parameter
- Four-digit display for general menu parameter/value;
- Dedicated display control increase, decrease, Program and Store;
- Clock selectable Internal (with its own panel control), External Analog TTL and MIDI;
- Internal Clock PW front panel control; for adjust percentage of legato/staccato;
- Advance mode Forward, Backward, FW/BW, Pendulum, Alternate, Random;
- Sequence Mode A,B,C (8x3), A+B,C (16+8), A+B+C (24);
- Global Loop always disposable with dedicated control panel (for unconditioned sequence looping);
- Shift control on front panel;
- Row B can be assigned to Internal Clock PW Mod or Internal Clock Speed Mod;
- Row C can be assigned to Internal Clock PW Mod or Internal Clock Speed Mod;
- Dedicated front panel controls for Run/Stop, Reset at first step and individual Step Advance.
Sequencer Connections on front panel
- Remote Run/Stop;
- Remote Loop On/Off;
- Remote Reset;
- Remote Glide On/Off;
- Analog TTL Internal Clock Out (0/+5V);
- Analog TTL External Clock Out (0/+5V);
- Remote CV Control In for Advance Mode select;ì
- Remote CV Control In for Sequencer Clock Modulation;
- Remote CV Control In for Sequence Mode Select;
- Remote CV Control In for Sequencer Clock PW Modulation;
- MIDI In & Out for sequences bulk/dump transfer, for Note On/Off & Key Vel & Clock transmit;
- USB Connection for sequences bulk/dump transfer, for Note On/Off & Key Vel & Clock transmit.
Estimated time for availability: Autumn 2014
Price: To Be Announced.
Stay Tuned
Pic:
For those who can read German there is also an article at Great Synthesizers:
http://greatsynthesizers.com/allgemein/ ... equenzers/
Might also be interesting if you want to see some details.
Soundcloud
For sale: Jürgen Haible Tau Phaser (MOTM format)
Stereotactixxx
Post by Stereotactixxx » Thu Nov 14, 2013 8:11 am
That does indeed look like a very serious device.
I guess we will know in about a year then...
Post by JohnLRice » Thu Nov 14, 2013 11:09 am
Awesome! I probably wont be in a position to get one but I've long lusted for the sequencer that lives in the GRP A8! It seems to have some of the features found in the Roland type sequencers and some features I've not seen elsewhere. :love:
It seems near impossible to find really good demos of GRP synths. But for what it's worth here are a couple:
ericD13
Post by ericD13 » Thu Nov 14, 2013 12:30 pm
Christa Bachmann (synthiefrau) makes some nice demo on youtube with a GRP A8
http://www.youtube.com/user/Synthiefrau
"Unfortunately it took me forty years to conclude that nothing is possible outside DoReMi."
P. Schaeffer
Lots of 5U modules to sell in europe :
https://www.muffwiggler.com/forum/viewt ... p?t=219781
ericD13
Re: GRP R24 Sequencer (Standalone + 5U)
Post by ericD13 » Thu Nov 14, 2013 12:41 pm
sonicwarrior wrote: For those who can read German there is also an article at Great Synthesizers:
This site is also in english :)
There a test of the GRP A8 :
http://greatsynthesizers.com/en/test/gr ... hesizer-3/
P. Schaeffer
odecahedron
Post by odecahedron » Sun May 25, 2014 12:39 pm
anyone know if this is closer yet? my babel fish is broke
sonicwarrior
Post by sonicwarrior » Sun May 25, 2014 12:51 pm
It seems the final version has been posted on Facebook (can't access the Facebook page):
http://www.sequencer.de/blog/grp-sequen ... sion/19194
Now it looks like a Dark Time XXL. :hmm:
Soundcloud
milkshake
Post by milkshake » Mon May 26, 2014 9:13 am
I want this bad.
Any info on how much it's going to hurt?
Shall I ... blablabla ... to thee.
The more you pay for something, the less likely you are to critise it.
ContraPoints
Post by JohnLRice » Mon May 26, 2014 9:42 am
lvoemachine
Post by lvoemachine » Mon May 26, 2014 1:39 pm
that looks fantastic. Really compact but still seems useable.
odecahedron
Post by odecahedron » Mon May 26, 2014 11:51 pm
errmeregeerrhd
WHEN! haha
paulstone
Post by paulstone » Tue May 27, 2014 6:32 am
Fantastic !
Post by JohnLRice » Wed May 28, 2014 8:57 am
For reference this is a good demo for the step sequencer in the smaller A4 synthesizer:
Gringo Starr
Post by Gringo Starr » Thu May 29, 2014 11:30 pm
JohnLRice wrote:Image
Wow! That looks amazing. I've always loved the sequencers in their semi-modular synths.
Weed only gives you the illusion that it’s enhancing your creativity.
Post by JohnLRice » Sat May 31, 2014 10:26 am
Just putting these two pictures together to make it easier to compare since it looks like several things have changed between the initial drawing and the real thing, especially on the bottom row, like the display is one digit wider and the MIDI/USB I/O is gone. (on the back now or?)
odecahedron
Post by odecahedron » Sat May 31, 2014 11:29 pm
anyone care to stab at a price guestimate? im guessing 1.5-2K usd ballpark
milkshake
Post by milkshake » Sun Jun 01, 2014 7:43 am
I hope the price is below 1500 euro.[/img]
ContraPoints
Post by JohnLRice » Sun Jun 22, 2014 5:39 am
I'm afraid of what the price might be . . . :tinfoil: . . .and how cool it might be . . . :hyper:
BTG
Post by BTG » Sun Jul 13, 2014 10:00 pm
Anyone care to give a quick summary of pros/cons vs. Oberkorn and MAQ 16/3? I had an Oberkorn but its quirks finally drove me away (and my Cirklon works well enough). I've been thinking about a MAQ 16/3 for a while however to drive my analog gear in a more analog way than the Cirklon.
sonicwarrior
Post by sonicwarrior » Mon Jul 14, 2014 7:29 am
BTG wrote:Anyone care to give a quick summary of pros/cons vs. Oberkorn and MAQ 16/3?
Dude, it's not even available yet. So we don't know which features will make it into the final version. :despair:
Soundcloud
Vacancy Of Disco
Post by Vacancy Of Disco » Mon Jul 14, 2014 7:57 am
now that this seems to be closer to becoming reality, it's time to start saving away my pennies. looks amazing
fyvewytches
pan galactic gargle master
Post by fyvewytches » Sun Oct 05, 2014 2:17 pm
BTG wrote:I've been thinking about a MAQ 16/3 for a while however to drive my analog gear in a more analog way than the Cirklon.
In what way is the MAQ 16/3 more analog the the Cirklon ? :hmm:
Also, the fun factor aside, what are the advantages, if any, of using analog over digital for a sequencer ?
milkshake
Post by milkshake » Mon Oct 06, 2014 1:15 am
The cirklon has much menu's than the MAQ.
If composing on a guitar, you come up with different results than when composing on a piano. Similar things happen when composing on a analogue sequencer vs daw, you come up with different results.
fyvewytches
Post by fyvewytches » Mon Oct 06, 2014 3:44 am
milkshake wrote:The cirklon has much menu's than the MAQ.
Yes, I know that, I used to use an MAQ, now I use a Cirklon. But this doesn't answer my question. Both a digital hardware sequencers.
milkshake wrote: If composing on a guitar, you come up with different results than when composing on a piano. Similar things happen when composing on a analogue sequencer vs daw, you come up with different results.
I'm not talking about (ewww) a daw. I'm talking about hardware sequencers. You wouldn't believe how many times I've seen people thinking that using an analog sequencer will somehow make their setup sound differently to using a digital hardware sequencer.
alternating.bit
Post by alternating.bit » Mon Oct 06, 2014 5:11 am
The GRP A8 (or even the A4) are on my list to obtain before I die. Whichever comes first, hard to say.
Return to “5U Format Modules”
