Sequencers for D-1000 or D-2000
A place to discuss the brutal yellow evil we all love so much.
Moderators: Kent, metasonix
EPTC
Post by EPTC » Mon Jun 10, 2019 1:13 pm
ExtrasensoryPerception wrote:Bummer...
I came here to search for this exact piece of information... would have loved to add cv control aside from triggers with a faceplate mounted module.
Heya - Let me amend that (a couple years later) to say you can likely remove the front plate of Pam's, position the module in the faceplate slot from behind (make your jokes), and then screw the faceplate of Pam's on top.
Haven't tried this but this is how I got the RK5 LPG to fit in the open section of the faceplate. That's a really nice use of the open space, too.
Bandcamp | Website
This week's show: MLK DAY MELEE — The awful day in Denver CO history when there was a KKK riot.
Charlie Pickle Part 23:
Harko
Post by Harko » Thu Jul 11, 2019 8:48 am
I'm temporarily using a RCD with the Korg SQ-1 for sequencing the D-2000.
The SQ-1's sync output pulse seems to be working fairly good.
lud
Re: Sequencers for D-1000 or D-2000
Post by lud » Sun Apr 12, 2020 7:51 am
Intellijel steppy works really well with the D1000, apart from being slightly fiddly - variable gate length, 4 channels, up to 64 steps. But needs a clock so not so good for the D2000 I guess (I use clock out from D1000)
NightGoat
Post by NightGoat » Thu May 28, 2020 7:47 pm
For my RK4 and RK1 I use Grids and MFB SEQ-03 which both work well as does turing machine pulses.
Tempi does not work due to gate length but I get round this with a Ladik U030 gate to trigger converter
gringostar
Re:
Post by gringostar » Wed Jul 22, 2020 9:36 pm
Thinking about grabbing a D2000 since my trump buxx finally came in (I can’t think of a more appropriate way to spend it than on an instrument that will piss wasps off) and wanted to know if anyone has used a Numeric Repetitor successfully with it since I know it wants very short gates. Also, since it’s already in my rack, if anyone has used a Zorlon Cannon mkII successfully.
Return to “Metasonix”
