Read this! list of working euro rack cases
A place to discuss the brutal yellow evil we all love so much.
Moderators: Kent, metasonix
FatRocky
Post by FatRocky » Wed Sep 07, 2011 4:45 pm
assigning one 1.2amp psu for each row in a G6 case looks a bit complicated for me. I'll get a big monorocket! thanks.
FatRocky
Post by FatRocky » Tue Dec 27, 2011 8:19 pm
FatRocky wrote:assigning one 1.2amp psu for each row in a G6 case looks a bit complicated for me. I'll get a big monorocket! thanks.
here it is:
metasonix
Tube Pioneer
Post by metasonix » Wed Jan 18, 2012 4:46 pm
As requested, here is a repost of info on the new Monorocket cabinet that is intended specifically for Metasonix R modules.
The Mission 9M is specifically designed for Metasonix modules, and particularly the new R-55 oscillator module which, on its own, draws enough current to shut down any other eurorack power supply on the planet. This power supply puts out a whopping 8.5 amps (8500mA) on the +/-12v rails and 8 amps (8000mA) on the +5v rails! It truly is 'The Mother Of All Eurorack Power Supplies'! The M9M power supply is an internal universal supply (100v to 240v) so this case can be used anywhere in the world.
Bus boards include both standard sockets and Analogue Systems type sockets for easy connecting with no adapter cables required.
Monorocket cases use the sliding-nut mounting system which eliminates any gaps between modules by different manufacturers.
The M9M includes mounting screws and IEC power cable.
The standard color will be Metasonix Yellow, but you can custom order pretty much any color you can imagine.
Big City Music purchase page.
FatRocky
Post by FatRocky » Thu Jan 19, 2012 10:35 pm
metasonix wrote:As requested, here is a repost of info on the new Monorocket cabinet that is intended specifically for Metasonix R modules.
this is great , but it seems that the BCM guys don't like to send these outside the States. We have to find our own way to get lots of yellow in our systems. :despair:
cinnamonjuly
Post by cinnamonjuly » Wed Mar 21, 2012 8:18 am
Anyone have ideas for modifying Doepfer P9 cases for these....?
oversee
Post by oversee » Sun Jul 01, 2012 6:50 pm
Can anyone here speculate about how well the new monorocket M6c ps might handle Metasonix modules?
I was considering the M9M, but realistically it is too much case for me. I've got an R51, R52, and an R54 (of course there would be other modules but no high draw digital ones.) Any one of the R serries in my Zeus powered case introduces an unacceptable ammount of hum. I've got an M6c on order, but now that I see it is a switching, not a linear power supply I worry I may encounter the same problem with the monorocket as I've had with Metasonix modules and my Zeus.
Thanks.
hednoize
Post by hednoize » Fri May 10, 2013 9:53 pm
5V Power module for Metasonix R-55 modules:
http://voltergeist.org/
This 2HP module allows you to add 4 amps of 5V power to your Eurorack system. This is enough to power up to 2 Metasonix R55 modules. They are available in black, blue, or yellow.
Brent Daniels [Free]
brentdanielsmusic.com
@brentdaniels
Magma2008
Post by Magma2008 » Mon Mar 21, 2016 11:04 am
I use Metasonix's RKP Power System to run a R54, R57, and four solid state modules.
otoskope
Post by otoskope » Wed Mar 23, 2016 10:03 am
I've seen no mention of the Synthrotek Deluxe Power module here. It uses an external 6A 19V switching brick, and is rated at 2A +12V, 1.5A -12V and 1.5A 5V.
I've run it successfully with four R-modules in different configurations, primarily R51+53+54+57. Sometimes its power LEDs flicker for a second or two during startup (due to the cold start current rush), but not always, so this is close to its limit.
This has been a temporary solution while waiting for some beefier Doepfer PSUs, but I thought it'd be good to know, as it is more powerful than some of the other similar panel power modules.
The brain is always greener on the other side.
soundcloud1 soundcloud2
bandcamp
youtube
FA
Post by FA » Thu Dec 28, 2017 3:46 pm
I read on the Metasonix website that the new PSU3 from Doepfer should be able to handle at least 3 RK modules, has anyone here tried this and had any success? Perhaps even with some other solid-state modules as well?
I did find a older thread where someone claimed to have no problems even with additional modules from other manufacturers but I would just like to have this confirmed by someone else just in case before I order anything.
Being the novice that I am I'm a little weary that the PSU3 is a switching type which from what I've gathered might not provide enough power for the startup of the Metasonix modules. Apologies in advance if I'm missing something very obvious here, I'm still learning.
I did find one seller of a LC6 case that a claims that it has the older PSU2, no idea if this is just a case of not having a up to date website or not but assuming it is true, would that be preferable to the PSU3?
otoskope
Post by otoskope » Thu Dec 28, 2017 3:51 pm
Hi FA -
Indeed, the PSU3 can run more than 3. In my system (see below), I use a PSU2 for the lower row, a PSU3 for the middle row (4 modules), and the standard PSU for the Doepfer 1-frame for the top row. Also, the PSU3 provides 5V to all of them.
So you should have no problem.
bandcamp
youtube
FA
Post by FA » Thu Dec 28, 2017 3:55 pm
otoskope,
Thank you for the very swift reply! Since You have 4 modules with a PSU3 I would assume that 2, perhaps even 3, RK modules along with say 2-3 regular solid-state modules would be no problem at all right?
Edit: With "Doepfer-1 Frame" do you mean this? If that's the case then their power supplies are obviously very conservatively rated.
http://www.doepfer.de/a100p_e.htm#A100LC3
otoskope
Post by otoskope » Thu Dec 28, 2017 3:59 pm
I'd say you can have a large number of normal (non-Metasonix) modules on the PSU3. It can power a big system. So you should be fine with the configuration you suggest. As you can se in my earlier post a few steps up, even a Synthrotek Deluxe Power (a small panel power module with an external switching power brick) could power 4 R-modules. That's what I used before.
bandcamp
youtube
FA
Post by FA » Thu Dec 28, 2017 4:04 pm
That's fantastic to hear about the PSU3 and I'll certainly look into the Synthrotek as well!
Did you have chance to look at my edit of my post above? Posted it right before you answered.
otoskope
Post by otoskope » Thu Dec 28, 2017 4:05 pm
Yes, correct - that's the doepfer 1-frame I have. It is just repainted in my system.
bandcamp
youtube
FA
Post by FA » Thu Dec 28, 2017 4:06 pm
Again, thank you very much for your swift replies!
gringostar
Post by gringostar » Fri Jun 22, 2018 12:57 am
Has anyone tried the Bastl Marton?
http://noise.kitchen/shop/case/bastl-marton-case/
Power specs are listed as +5V/5000mA, +12V/2800mA, -12V/500mA which seems like it should be able to handle a few RK modules but if anyone has seen this case in the wild I would love more information on it.[/url]
Return to “Metasonix”
