Quad or Dual E.G. For frac?(AD or AR)
KoryB
Post by KoryB » Sat Oct 29, 2016 11:49 pm
Hey all,
I might be getting a frac system soon and curious am curious as to E.G.'s available?
Is there anything comparable to a Buchla quad function generator?[/list]
fracmonkey
Post by fracmonkey » Tue Nov 01, 2016 4:34 pm
Cyndustries Four Transients?
http://www.cyndustries.com/modules_four_transients.cfm
Blacet EG1, DAD. The LFO and Window Comparator are also gateable...
werock
Post by werock » Tue Nov 01, 2016 5:37 pm
Cyndustries are best avoided :eek:
fluxmonkey
Post by fluxmonkey » Tue Nov 01, 2016 8:16 pm
I did a mashup of a mattson mini-modular Quad AD/ASR and Quad VCA... does not have the VC options of the buchla function gen, but it's solid, and economical...
http://mattsonminimodular.com/wiki/inde ... _Generator
http://mattsonminimodular.com/wiki/inde ... _Amplifier
www.fluxmonkey.com
KoryB
Post by KoryB » Tue Nov 01, 2016 8:39 pm
Thanks! I've read questionable things about Cyndustries.
Will check out the Mattson!
KoryB
Post by KoryB » Tue Nov 01, 2016 9:48 pm
Mattson looks awesome!
Will it work in a frac system?
werock
Post by werock » Wed Nov 02, 2016 7:23 am
I built a Mattson VCF into my Frac system, it's pretty easy, they even have a frac type power connector on the board.
fracmonkey
Post by fracmonkey » Wed Nov 02, 2016 10:02 am
Cyndustries is not accepting orders.
Mattson does have a standard frac power connector. The front panels are not frac however. You would have to do a FP Express panel. The wiring info looks good and the pcb would fit behind a 3" frac panel. Some work involved but might be good for adding frac...
J3RK
Re: Quad or Dual E.G. For frac?(AD or AR)
Post by J3RK » Wed Nov 02, 2016 12:58 pm
KoryB wrote:Hey all,
I have 3U-friendly PCBs for my Angle Generator, which is very similar to the Buchla 281. Linear slopes, End of Envelope Pulse, and I also have a variable input analog OR Mixer that can be added to mix the peaks like on the 281. It works in AD and AR modes. AR is retriggerable, so works well with keyboard input.
I do custom builds including Frac. Feel free to PM me if you're interested.
That aside, I second the above. Blacet and Mattson are great! I've used circuits from both.
fluxmonkey
Post by fluxmonkey » Wed Nov 02, 2016 6:20 pm
gate ins are normalled, so 1 gate into the top triggers all 4, unless something else is inserted in one of the intervening gate ins. outs are also normalled to the VCA CV ins, unless something else is plugged into the cv in jack
www.fluxmonkey.com
fracmonkey
Post by fracmonkey » Thu Nov 03, 2016 9:51 am
Looks like a handy module!
Also now available from Synth Cube are many Ray Willson modules. PCB only which can be quite challenging to build into modules in general but worth considering for the experienced diyer. These tend to look like they need a bigger panel than frac although looking at the dual AR, I can see a possibilty there. You would do a right angle pcb mount.
e-grad
Post by e-grad » Thu Nov 03, 2016 10:56 am
I've built two 281 Dual Function Gen. for Frac and might part with one of them. Let me know if interested.
whomper
Post by whomper » Wed Oct 11, 2017 8:29 am
I've been using MFOS dual AR, such a handy tool once your main ADSRs are all used.
dJ dAb
Post by dJ dAb » Wed Oct 18, 2017 4:25 pm
Quad / Postman EG from Hexinverter work fine. Designed Frac panels for 'em. Came out great!
Hmmm... been dabbling in Electronic music & DJing for 25+ years. Collector & curator of a fairly large vintage recording studio. Ran a couple record labels featuring DJ ESP, Hakan Lidbo, Jacob London, Martin Venetjoki, Vitamin D, Chris Anderson, etc. and licensed to greats like Carl Cox, Dave Angel, Chris Simmonds, etc. Oh yeah, I'm also a builder of D.I.Y. electronics junk, including a mighty fine modular synth.
Frac Rak Users!
dJ dAb
Post by dJ dAb » Wed Oct 18, 2017 4:46 pm
Frac Rak Users!
KoryB
Post by KoryB » Wed Jul 18, 2018 12:36 am
Thanks for all the replies! I thought I had thanked everyone, but realized I hadn't! Very rude of me sorry!
charlie-dude
Post by charlie-dude » Wed Sep 05, 2018 10:09 am
dJ dAb wrote:Quad / Postman EG from Hexinverter work fine. Designed Frac panels for 'em. Came out great!
Panels look good! How did you make them?
charlie-dude
Post by charlie-dude » Wed Sep 05, 2018 10:10 am
