oozitron
- solder fume huffer
Post
by oozitron » Sat Oct 26, 2019 6:57 pm
All my power supplies are Blacet ones, but I need another, and will need a little more than the 0.4 amps as well.
Anyone have any comments on this one?
https://www.galco.com/buy/International ... IHAA15-0.8
thanks,
Drew
Never want to come down, never want to put my feet back down on the ground
Be Sandy?
- Veteran Wiggler
Post
by Be Sandy? » Sun Oct 27, 2019 2:27 am
That will do the job fine.
I've had that very supply for some of my 5U stuff.
But you will need to be confident in wiring up mains to it safely or know someone who is. There's no built in mains inlet/fuse.
chachi
- Veteran Wiggler
Post
by chachi » Sun Oct 27, 2019 12:17 pm
these work fine but there are threads in the diy forum that explain they develop an audible and sometimes annoying physical buzzing if they are handling a large amount of current. i use these lower current supplies for both frac and euro though and have never had a problem.
werock
- Ultra Wiggler
Post
by werock » Sun Oct 27, 2019 3:33 pm
I have a couple of these supplies from Oakley Sound in addition to a blacet supply (for separate cases):
www.oakleysound.com/psu2.htm
They're designed to be used with external Yamaha power adapters, which avoids having to play around with mains level voltages.
bf
- 12 Bit Wiggler
Post
by bf » Sun Oct 27, 2019 5:00 pm
The power one linear supplies were the core of all of my builds when I was still active in sdiy. Understand things from a safety perspective first and foremost, but have no concerns about their quality and usability.
