Sooo I charge some brave Frac manufacturer to bring this lovely device into Frac-land. Something similar. Gimme gimme!
(no, I won't go Euro!)
A bunch of reasons, some of them rational, some of them not.flight wrote:Hmm, I'll look into it.
Out of curiosity, why won't you go euro?
There's a drawing on this Blacet page showing how to do it:Roycie Roller wrote:Chris, if you can be fuqt, it's probably highly likely that you can run a Doepfer PLL off a ps500 by modifying the ribbon cable so it terminates in 3 or 4 wires, and a 4 pin power connector. I've seen a diagram showing how to do it, but can't remember where it is, but it's a straightforward modification. Then, replace the doepfer faceplate with a suitable black one. I'm considering doing this to the PLL too, but more to integrate into my own synth that i'm building, which runs off a ps500.
I'm in the same boat.scozbor wrote:i tried to resist going euro, but the malekko stuff convinced me.
at the moment I'm just screwing a few modules into a blacet rack and its working fine. I had to drill some new holes though. I currently have a noise ring and doepfer bbd in there. I'm hoping to not need a euro rack at all.
aaahhh, I see.scozbor wrote:no, i only drill the blacet rails to fit the holes in the euro modules...Cat-A-Tonic wrote: You're going to end up eating some discounts if you ever have to resell those Euro modules with Frac mounting holes.
Why not just screw them into wood while you are waiting for a more permanent solution?
