VERBOS ELECTRONICS
The Junglechrist
Re: VERBOS ELECTRONICS
Post by The Junglechrist » Sat May 09, 2020 12:51 am
burgers wrote:
Thu May 07, 2020 8:07 am
fav non-verbos modules to pair with your verbos modules?
Intellijel Quadra with expander + Make Noise QMMG is my non Verbos combo in my Verbos rack, my goal being to fool myself into believing I own a Buchla hahaha.
But more seriously they pair very well. One bad point with this combo is that I need to attenuate the audio from the Verbos vcos before hitting the QMMG if I want a clean sound, but I often don't so it's alright.
Stazma The Junglechrist / Repeat Eater: http://stazmathejunglechrist.com/
My label Concrete Collage : https://concretecollage.bandcamp.com/
Wired Brain Video Channel : https://www.youtube.com/channel/UCh4pym ... vkKp6ofzVA
Kroggel
Post by Kroggel » Sat May 09, 2020 3:30 am
One short question regarding the Complex Oscillator.
Is patching the same v/okt sequence in both v/okt doing the same as have the osc sync switch on?
The Junglechrist
Post by The Junglechrist » Sat May 09, 2020 3:38 am
Not at all, the sync switch is to hard sync the modulation oscillator to the main one.
Kroggel
Post by Kroggel » Sat May 09, 2020 4:19 am
ah ok, so no pitch difference there, just timbre change. thanx
The Junglechrist
Post by The Junglechrist » Sat May 09, 2020 4:43 am
Yes exactly, you need to mult your pitch the both VCO if you want those to track the same.
In a side note the Sync of the CO is one of my favorite, perfect for crazy sound whith AM on VCO 1.
Kroggel
Post by Kroggel » Sat May 09, 2020 10:27 am
I am still in discovery phase of this beast. Not so many knobs but much to learn
advrsry
Post by advrsry » Sat May 09, 2020 1:24 pm
Voltage Multistage question: What's the best/easiest way to run the sequence in reverse?
mritenburg
Post by mritenburg » Sat May 09, 2020 1:33 pm
Analog address mode with a falling saw. Or, an AD envelope with instant attack and gradual decay.
advrsry
Post by advrsry » Sat May 09, 2020 2:29 pm
Thank you! That's what I tried but was wondering if there's another way that I was missing.
advrsry
Post by advrsry » Sat May 09, 2020 3:41 pm
One thing I think is unfortunate is that you don't get gate outputs in analog mode. Actually I'm not sure what gate/ref outs do in this mode. I can get pulses out when I plug something into "advance"
mritenburg
Post by mritenburg » Sat May 09, 2020 5:01 pm
Yeah, that’s a challenge. The per stage gate outputs are active in this mode, so you can combine them with a buffered mult or similar to get 8 gates per cycle.
3pand
Post by 3pand » Sat May 09, 2020 9:38 pm
It has to be a passive multiple I believe. Does it work with a buffered one? In any case, a really cool feature of the system.
advrsry
Post by advrsry » Sun May 10, 2020 8:48 am
That's a good idea, thanks.
mritenburg
Post by mritenburg » Sun May 10, 2020 9:36 am
I don’t know if it has to be a passive mult, but I think you are correct that a passive mult will work with in this case because I just checked and the gate outputs on Verbos modules are floating diodes.
Disappointment with any module is usually a failure of imagination.
Ummm, I guess you would call it techno.
The Junglechrist
Post by The Junglechrist » Mon May 11, 2020 2:02 am
Some acid riffage with my Verbos system and the aforementioned QMMG :
bayrumblues
Post by bayrumblues » Mon May 11, 2020 10:58 am
Did some rearranging on my VERBOS system. She's lookin good!
Noise & Filter + Control Voltage Processor were in a different rack at the moment, so forgive the Make Noise modules up top!
Bjarlstedt
Post by Bjarlstedt » Mon May 11, 2020 12:43 pm
Pamela’s new workout and Magneto.
Each harmonic cv input on Harmonic osc being slowly modulated by PMW in different ways is pure joy. And then Magneto in shift mode as an end of the line module and I’m in heaven. If I would have to choose just three modules from my setup it would’ve been those three.
gloamtrotter
Post by gloamtrotter » Mon May 11, 2020 12:59 pm
Nice, that looks awesome! I've yet to use any verbos gear but it sure looks appealing to me.
burgers
Post by burgers » Mon May 11, 2020 3:08 pm
THE QMMG :hail:
had no idea
Paul_N
Post by Paul_N » Mon May 11, 2020 5:21 pm
How is the TPK working out for you? I had to return mine after two weeks back to Perfect Circuit when I had it - I could not get it to track 1v/oct at all. I went with the mini-horse, and eventually the standalone-case so that I could free up some space in my setup.
-Paul
Smcjr
Post by Smcjr » Tue May 26, 2020 3:03 pm
Complex Osc was the first module I bought after power and output. Almost sold it recently because I felt like it was too much then finally watched some videos that re-inspired me and am so glad its the center of my setup now. So many sounds right under my fingers!
Yunsnare
Post by Yunsnare » Thu May 28, 2020 12:01 pm
Hello everybody.
Here's my last patch. I'm still discovering the Verbos HO but here, it's the main voice !
valouxxx
Post by valouxxx » Sat May 30, 2020 2:04 pm
Hi there,
Little techno jam with some Verbos electronic stuffs
Main bass lead is Verbos Harmonic oscillator saw in a Make Noise Mmg
Melodic line is made with the Voltage multistage.
Additional voices are
- Harmonic oscillator sum in the Verbos pan & tone then in the Verbos Multi Delay (right side)
- Random sources Ncom with the Harmonic oscillator 3rd and 8th osc inputs, used as oscillator
And some Make Noise telharmonic
Snare is Verbos random metallic noise in Make noise optomix
AndreFish
Post by AndreFish » Sun May 31, 2020 11:52 am
Hi,
Recently got a second hand Dual Four Pole, which sounds great, but all the knob turns feel very loose compared to my other Verbos modules. Is this normal for a Dual Four Pole, or is it a possibility that the potentiometers have worn out with use?
Tumulishroomaroom
Post by Tumulishroomaroom » Sun May 31, 2020 1:15 pm
Mine isn't that loose; it's a rev5 but I'm not sure it matters.
