Quantimator firmware update!
studio460
Re:
Post by studio460 » Thu Apr 08, 2021 10:48 am
sockmonkey wrote:
Mon Jun 20, 2016 1:00 pm
OK, got it. For the record, I popped the Quantimator ATMega328 chip into the socket on my Uno, hooked up a USBasp (ICSP) programmer to the ICSP headers and ran from the OSX Terminal:
avrdude -p m328 -c usbasp -P usb -U flash:w:quantimator1.2.cpp.hex
Done and done.
Thanks for posting that! Can you tell me where the ICSP header is? Also can you tell me which exact USB ASP programmer is?
studio460
Re: Quantimator firmware update!
Post by studio460 » Thu Apr 08, 2021 10:50 am
So the procedure for macOS users:
1. Insert EEPROM into USB ASP device (don't know which one).
2. Plus USB device into computer.
3. Open Terminal in macOS utilities or run AVRfuses app for macOS.
4. Type: avrdude -p m328 -c usbasp -P usb -U flash:w:quantimator1.2.cpp.hex
[AVRfuses ATmel programmer link: https://vonnieda.org/software/avrfuses]
Questions:
A. Where do you put the hex file? On the USB flasher? Is the flasher also a USB storage device?
B. Looks like a 28-pin device from the photo. Do I plug this into the second Amazon product I linked?
C. Is it possible to brick the device or the module if I do it wrong?
I searched "USB ASP EEPROM 28-pin programmer" in Amazon and a lot of devices came up, one made for ATMel devices. Just can't seem to find one with a socket with 28 pins. Most are only 10-pin devices?
Okay, I found this programmer for ATMel devices on Amazon. It has a 10-pin cable. Where does that go?
Or do I also need to buy this thing?
toppobrillo
Post by toppobrillo » Thu Apr 08, 2021 4:52 pm
https://www.ebay.com/sch/i.html?_from=R ... nc&LH_FS=1
any AVR ISP programmer should work, these are all hella cheap. https://vonnieda.org/software/avrfuses this is the software I use, it's simple and effective. If you know someone locally who has flashed ATmel microcontrollers before, should be easy for them to do so. I regret I did not include ICSP pins on the back of that module, makes it a little easier. Reach out on facebook too maybe. If you can't figure anything out, I can sort you out but not for a few weeks as I am in the middle of moving rn.
toppobrillo
Post by toppobrillo » Thu Apr 08, 2021 5:02 pm
just sent you a dm. you can get your friend to contact me if that's easy.. otherwise I'll sort you out
studio460
Post by studio460 » Thu Apr 08, 2021 6:35 pm
Oh, thank you sooooo much! Really appreciate your help! I'll be on my own since the only place I could find locally is this uber-expensive synth repair place, so I'm going to attempt this myself. Absolutely in no hurry—I'm enjoying the crap out of your module as-is. Using Lydian-mode now for some triads, and it's fantastic!
Thanks again—PM'd you back.
toppobrillo
Post by toppobrillo » Thu Apr 08, 2021 10:20 pm
cool!
yeah it's a ton of fun. I'll dm you my email address, easier to keep track of that way. Thanks!
