Quantimator firmware update!
toppobrillo
Post by toppobrillo » Wed Jun 25, 2014 3:19 pm
yep, paid 2 months ago... nothing yet
PM me
How can we tell which chip we've got, installed? I got my quantimator couple weeks ago from Schneiders, would like to check wether this has the new chip installed ...
you should have the new one :) check the instructions here
http://www.toppobrillo.com/quantimator.html#rev
Drakhe
Post by Drakhe » Wed Jun 25, 2014 3:45 pm
Thanks, checked, and confirmed ... :yay:
narwhal
Post by narwhal » Wed Jun 25, 2014 4:15 pm
PMed!
makers
Post by makers » Thu Jun 26, 2014 3:22 am
Is a recalibration of 1 v/oct output recommended after the chip swap?
toppobrillo
Post by toppobrillo » Sat Jun 28, 2014 6:54 pm
Nope!
narwhal
Post by narwhal » Sat Jul 12, 2014 1:20 pm
paid in april. still no sign of chip nor response to emails. i like toppobrillo but :waah:
waveglider
Post by waveglider » Sat Jul 12, 2014 1:46 pm
I also paid in April, got no response after emailing, but mine did show up finally 3 weeks ago, so it seems a slow, low priority process...
toppobrillo
Post by toppobrillo » Sat Jul 12, 2014 9:02 pm
hey yaaa all paid update chips have been shipped at this point, please pm me if you haven't received one yet.
narwhal
Post by narwhal » Sat Jul 19, 2014 11:51 am
finally arrived and installed today. :party:
maudibe
Post by maudibe » Sat Jul 19, 2014 2:36 pm
arrived yesterday.... but haven't had the guts to do the upgrade yet. Thanks Toppobrillo - I had actually forgotten I ordered this, so it was a nice surprise.
narwhal
Post by narwhal » Sat Jul 19, 2014 7:43 pm
it's easy. just unscrew the 2 screws on the back. slide the module into 2 and replace the chip. waggle it at both ends equally and it will pop out without bending the legs. make sure the new chip is orientated the correct way and put it back together. takes 5 minutes. :tu:
maudibe
Post by maudibe » Sun Jul 20, 2014 12:15 pm
:guinness:
Yea, no problemo.... I'm used to building modules :)
Milanm
Post by Milanm » Sun Aug 31, 2014 6:40 am
Anyone know if this chip is still available?
lordofthebored
Post by lordofthebored » Mon Oct 20, 2014 3:41 pm
Is there a link to the .hex file around here?
thank you thank you thank you
Milanm
Post by Milanm » Tue Nov 11, 2014 8:16 am
I have paid for this on the 22nd of October and have emailed toppobrillo at gmail dot com for information but got nothing back.
Does anyone have another contact for Josh? PM'd him here today
Ta,
C
Junk Rhythm
Big Bottom Shaker
Post by Junk Rhythm » Tue Nov 11, 2014 10:10 am
Milanm wrote:I have paid for this on the 22nd of October and have emailed toppobrillo at gmail dot com for information but got nothing back.
Ta,
C
PM me the email you used for the payment and your name. I can send him a text in a few hours.
Socrates
Post by Socrates » Tue Mar 31, 2015 9:24 am
hello guys, just a quick one. i just received in the post the chip for the update of the firmware...i know there's a video somewhere with the exact instructions on how to remove the old chip and install the new one, but i cant seem to find it. anybody got the link? thank in advance! :oops:
Dogma
Post by Dogma » Tue Mar 31, 2015 9:27 am
I got mine fro the BST and I have no idea how to check what chip I have can anyone tell me how to check?
look up!
grantmoney
Post by grantmoney » Tue Mar 31, 2015 9:34 am
Dogma wrote:I got mine fro the BST and I have no idea how to check what chip I have can anyone tell me how to check?
What worked for me.
From the website
To enable new "Trigger on Quantize" function: power on your new or newly upgraded Quantimator, and an animation will play on startup. It will 'hang' for a couple of seconds at the last frame- tap the MODE button 3X to toggle TOQ mode "on" or "off". You should see a "t" flash on the LEDs when enabling, and an "n" when disabling
If you can do that, you got the latest version.
nard0
Post by nard0 » Tue Mar 31, 2015 10:13 am
Does anyone know if there will be another run of these? I've been looking for one for ages.
WaveRider
Re: Quantimator firmware update!
Post by WaveRider » Tue Feb 02, 2016 8:54 pm
I still don't know how to change the chip
any instructions out there?
Junk Rhythm
Big Bottom Shaker
Post by Junk Rhythm » Tue Feb 02, 2016 10:16 pm
WaveRider wrote:I still don't know how to change the chip
Remove the module from the rack entirely. Remove both screws and gently pull the back PCB off of the module. Once the screws are out it should come apart easily. On one side of the chip, there is a little notch like the one in the photo below. If you look closely at the socket, there should also be similar notch on the same side as the notch on the chip. This shows the orientation that the chip should face when inserted and fully seated. Now to remove the old chip, gentle push a tiny flathead screwdriver under the edge of one end of the chip, in between the chip and socket. Slowly work it up a little bit and then do this to the other. Go back and forth in this manner from one end and then the other until the chip pops free. Go slow and take your time to prevent bending or breaking off any of the pins on the old chip. Once it's out of the socket, put the new one in while paying close attention to the location of the notch in the chip to verify that the chip is facing the correct direction. Insert the new chip slowly to make sure no pins bend under instead of going into the socket and make sure that it is fully seated. You may need to bend the pins inward slightly so that it's easy to push into the socket. When they are new, the pins tend to push outward a little bit. The easiest way to bend the pins inward is to place the chip on it's side on your desk. Gently rock the entire chip to the side so all pins slightly bend at once. Again take your time and go slow. A little force goes a long way. So once the chip is inserted and you've quadruple checked that that it's seated properly, put the PCB back on the module along with both screws. Pop it in the case and fire it up.
This is one of the prototypes and not the actual production unit so it will look a lot different. Use this as a reference for identifying the notched "D" looking shape on the left side of the largest chip in the photo.
Ebotronix
Post by Ebotronix » Wed Feb 03, 2016 6:44 am
old OS: the dorian scale is the melodic minor scale .
is the scale List place nr 2 the dorian scale in the new OS?
old OS:
two of the scales are equal, # b diminish and #2.arabian.
fixed in the new OS?
all scale steps.....
viewtopic.php?t=136698&start=0&postdays ... highlight=
Quantimator Scales playlist
WaveRider
Post by WaveRider » Thu Feb 04, 2016 2:46 pm
thank you Junk Rythm :yay:
Junk Rhythm
Big Bottom Shaker
Post by Junk Rhythm » Thu Feb 04, 2016 3:28 pm
WaveRider wrote:thank you Junk Rythm :yay:
Glad to help out!
Ebotronix
I wish I could answer your question as well but I don't know the nitty gritty specifics as to what changed in this firmware. I would suggest sending an email to info AT toppobrillo.com so it catches Josh's attention.
