Modular Synth Basics! Cases, power, modules, CV?! Come in :)
retoid
Post by retoid » Thu Nov 30, 2017 2:24 pm
Very helpful videos! Thank you for taking the time to make these. :)
familybuckets
Post by familybuckets » Sun Dec 10, 2017 5:31 am
Excellent videos, thanks very much.
bunkbeds
Post by bunkbeds » Sun Dec 10, 2017 7:50 am
just adding to the heaps of praise here: thanks so much for putting these together! i'm interested in building a modular synth set up for the first time and am looking for all the advice and information i can get. i'm very excited to watch through these!
flx
Post by flx » Sun Dec 10, 2017 10:04 am
Thank's a lot, everyone! :sb: It's great to read that the videos are still a valuable resource. Feel free to post questions about the individual videos in their comments on YouTube or in this thread.
You can also find and contact me here:
tuesdaynightmachines@gmail.com
YouTube
nightmachines.tv
Audiodog
Great!
Post by Audiodog » Wed Dec 13, 2017 12:29 pm
I'm a real newbie to Modular - these videos are great. Thx so much for taking the time to do this
Audiodog
Beginner setup examples
Post by Audiodog » Wed Dec 13, 2017 12:36 pm
Quick question
Can anyone point me to a resource/website that would help me understand or see examples of beginner Eurorack setups that include all of the modules required to have a basic or intermediate fully operational system?
Apologies if this is a dumb question but its a very steep learning curve!
fuzz0r
Post by fuzz0r » Wed Dec 13, 2017 3:24 pm
Very helpful, thanks!
flx
Re: Beginner setup examples
Post by flx » Wed Dec 13, 2017 6:11 pm
Audiodog wrote:Quick question
There are definitely a lot of "critique my rack" threads here, as well as a "minimal Eurorack setup" thread I think. It's a difficult question to answer because a fully operational system can be anything from one module to a synth wall. It depends what you want to do with it and there is no circumventing the steep hands-on learning curve. Buy a few modules that you're interested in and spend some time with them. Then exchange and/or expand :)
YouTube
nightmachines.tv
Red7fade
Post by Red7fade » Fri Dec 15, 2017 6:35 pm
Great videos, thanks for sharing!
Instagram : red7fade
spinalbeatz
Post by spinalbeatz » Sun Dec 17, 2017 5:50 pm
Thank you for these!
Audiodog
Post by Audiodog » Mon Dec 25, 2017 9:22 am
Thx for your response. I did exactly as you suggested. I bought a few (probably too many) modules that seem interesting to me and should complement my existing synth setup. I'm working on learning them now. Not easy but definitely a lot of fun!
Maarz
Post by Maarz » Wed Feb 07, 2018 5:43 am
Great videos, learnt a lot!
Traffik
Post by Traffik » Mon Feb 12, 2018 8:01 am
these videos are awesome, has helped me out massively!
Many thanks
Dextreme08
Post by Dextreme08 » Mon Feb 12, 2018 3:52 pm
Found these on YouTube, useful to have them all in one place. Thanks for the content!
Nocturnal Knob Turner
Nice work.
Post by Nocturnal Knob Turner » Tue Feb 13, 2018 11:27 am
Much appreciated thanks.
THE96
Doepfer DIY PSU2 strange issue
Post by THE96 » Tue Feb 13, 2018 8:11 pm
Hello everyone,
I'm not sure if this is the right place to put this but I suppose I have to start somewhere (I can't make my own thread yet and also haven't been able to find anyone with a similar issue).
A while ago I started building my modular system, I acquired all of my modules and 2 Doepfer DIY kit #1's second hand. (the kits come with the PSU with external trafo) I put the two kits in a case I built for them and for quite some time everything worked perfectly. However since yesterday there appears to be a problem that I really do not know how to fix.
The system suddenly turned off. I assumed the fuse had blown and when I checked today it turned out I was correct. However when I replaced the fuse the system powered on briefly and then powered off again, so I took out all the modules and started putting them back one by one. What happened however is the following.
The system doesn't even work with none of the modules plugged in anymore, which leads me to believe the PSU broke. So, since I have a second empty system ready to go I tried powering this one, it worked without anything in it. However the moment I plugged a module in the fuse blew again. After replacing the fuse and disconnecting the module it turned out that now this system too does not work anymore (i.e. it only turns on for a second after replacing the fuse, and then powers down again), even without any modules plugged in.
Does anyone have any idea what the problem could be? I'm wondering wether the external trafo might be causing the problem, what makes me doubt this however is the fact that before plugging in any of the modules into the second system it was working, all the correct lights on the PSU and busboards lit up.
Also, would this be the correct fuses to buy for this PSU:
http://uk.farnell.com/littelfuse/021802 ... dp/1271683
Thank you all very much in advance!
THE96
Post by THE96 » Wed Feb 14, 2018 9:56 am
To my last post I'd like to add that if there's anyone in London (I'm in the South East) that happens to know a lot about synths and would like to share some experience I'd love that. Hands on doing things generally works easier for me than looking at the computer (however this forum seems very helpful!).
Chozal
Post by Chozal » Fri Feb 16, 2018 12:59 pm
Hi all,
so my first case just arrived (iko).
And now the first noob hurdle ... What plug do I actually use ? I know it's a dumb, dumb question, but I'm absolutely useless with most practical things. Wouldn't want to fry stuff. I assume I'd need a laptop-style cable, the plug itself looks like it could be powered by the cables I use for my guitar amps (aka this https://www.thomann.de/fr/the_sssnake_s ... bel_5m.htm)
Any insight hugely appreciated :D <3
Lhet
Post by Lhet » Tue Feb 20, 2018 2:03 am
I picked up a mother32 and have moved it to a 104 hp case I'm slowly building up. Is there anything I can do with the base case/power supply the mother32 comes with? I figure at some point I'll rehome the mother32 as the 104 becomes full, but for now it'd be nice if I could find a way to home a few overflow modules in the mother32 case without needing to pick up another power supply.
realchildofhell
Post by realchildofhell » Wed Feb 21, 2018 10:41 pm
These videos are great! Finally pulled the trigger on a LC9 case after having the Mother 32 for a while. Think I'm just going to leave the M32 as is since it would take up a lot of room in the case. It's pretty fun to play with the Microbrute. Anyway, thanks!
SCOOBA_TANK
Post by SCOOBA_TANK » Thu Mar 08, 2018 8:31 pm
HOLY INSANE PILE OF KNOWLEDGE!!!!! :eek: :eek:
#thankyousodamnmuch
knarf
Post by knarf » Fri Mar 30, 2018 1:24 pm
Thanks for the knowledge!!
Midiot
Post by Midiot » Fri May 04, 2018 10:32 pm
RE:
ArtForTheEars (brand) rack ears... which are mated with their eurorack rails.
I've been using these (19" rack ears) with their 84hp rails...to fit in my 19" rack cases.
But no screws are provided, screw sizes, nor any instructions.
Here's their pic of the finished ensemble...from their site.
LINK web LINK
The ears have 2 slightly offset holes that match the ends of the extruded rails (w/ a larger hole and a smaller hole, per end)
Although I did find that 10-32 screws will self-thread into the rails (or metric equivalent, M5 ??).... and the smaller hole is too small, and needs to be enlarged.
BUT.... if I install 2 screws per end, modules will not fit (module space is too small).
What I do is....enlarge the smaller hole, and fit only one screw per end.... and twist the rails a couple of degrees until the modules fit.
This works for my needs, but it also means the rails are slightly protruding out from the ears. Not ideal, but it works.
I know... 'contact them'. (I will)
But in the meantime, I thought I'd offer a solution, temp or otherwise.
"We'll be living in all the oceans now."
(type of music I make.... drone atmospheres, deep late-night beats.)
kidkoexist
Post by kidkoexist » Wed May 16, 2018 9:48 am
Thank you so much for these videos. I have a good understanding of classic synthesis (east coast) and your information is helping me rapidly fill in the gaps. I'm currently planning my jump into a full Euro case after owning an 0-coast for a little over a year, and your videos are a huge help. Thanks again. One day, I hope to pay it forward.
Jimmy Needs Coffee
Post by Jimmy Needs Coffee » Wed May 16, 2018 11:11 pm
Cool! Thanks for those informations!
