MusicThing Radio Music -- sounds, patches, ideas
Moderators: lisa, Kent, Joe.
nectarios
Post by nectarios » Thu Jan 12, 2017 8:43 am
Threw in some loops that are the same tempo and same length.
Then programmed Modcan Touch Sequencer and used Doepfer A-185-2 to jam the stations.
Settings are in one shot mode.
Worwell
Post by Worwell » Sat Jan 21, 2017 5:06 pm
Mr_Mojo_Risin wrote:
duck1887 wrote:Thanks bobbcorr, looks great! And again to Mr Mojo! Now to create my masterpiece, "Preacher on Drugs Takes the Train" ... :bananaguitar:
Wow! I should know by now not to eat or drink anything when reading posts on the Forum.
Really laughed loud at that one.
Clean-up on aisle 3 :lolspew:
My version of "Preacher on Drugs Takes the Train"
concretic
Post by concretic » Tue Jan 24, 2017 12:48 pm
Does anyone have a problem that the sample just stops playing (while resetting via CV) and no sound is going out until you move the start knob? It happens to me every few minutes, sometimes sooner, sometimes later =/
nectarios
very nice sequencing there with modcan and precision adder
tenshun
Post by tenshun » Mon Feb 13, 2017 11:38 pm
I just had a idea. Has anyone tried loading control voltages (lfo,envelopes ,etc) on the sd card for the radio music?
This reason is because i saw that the new tip top one module can play control voltages off the sd card used for it.
I guess i should just try it out
Jumbuktu
Post by Jumbuktu » Tue Feb 14, 2017 12:46 am
concretic wrote:Does anyone have a problem that the sample just stops playing (while resetting via CV) and no sound is going out until you move the start knob? It happens to me every few minutes, sometimes sooner, sometimes later
Yes, I have this happening occasionally.
Kybernaughty
Post by Kybernaughty » Tue Feb 14, 2017 1:46 am
Yep, happens to me sometimes... even had ro reflash once. That's why I keep it accessible in my rack. Still, Radiomusic feeding A-112 and Phonogene = tons of weirdness & fun!
Zymos
Post by Zymos » Tue Feb 14, 2017 8:08 am
tenshun wrote:I just had a idea. Has anyone tried loading control voltages (lfo,envelopes ,etc) on the sd card for the radio music?
RM is not DC coupled, so nope...
(Disting should be able to do this, though have not tried it.)
Worwell
Post by Worwell » Wed Mar 15, 2017 7:52 pm
Verbos Complex Oscillator sequenced by the Varigate 8 into Dual Wasp, QMMF, Elements and Rings. Radio Music sequenced by Maths into Geiger Counter.
Mr_Mojo_Risin
*.WAV Files - Radio Music
Post by Mr_Mojo_Risin » Fri May 26, 2017 8:20 pm
Awesome!!! Just when you thought Radio Music couldn't get any better.
New developments by the inventor of this module which enables it to use *.WAV files!!!
http://polyfather.com/radio_music/ :yay:
lohacker
Re: *.WAV Files - Radio Music
Post by lohacker » Sat May 27, 2017 2:35 am
Mr_Mojo_Risin wrote:Awesome!!! Just when you thought Radio Music couldn't get any better.
Awesome, I didn't know the new firmware was ready, great news! :party:
edit: I've noticed now there's a pitch control :nana:
risome
Post by risome » Sat May 27, 2017 3:54 am
anyone tried this yet ?
eclectics
Post by eclectics » Sun May 28, 2017 7:35 am
I tried it this aft. The pitch shifting is really cool. I havent got it to read the wav files yet, must be doing something wrong.
EternalTurtle
Post by EternalTurtle » Sun May 28, 2017 2:22 pm
eclectics wrote:I tried it this aft. The pitch shifting is really cool. I havent got it to read the wav files yet, must be doing something wrong.
I was having problems too but I just loaded some files w/ .WAV suffix in all caps not lower case and it works great. got somewest african flutes blowing and it sounds awesome. :bananaguitar:
Hope that helps.
bc3
Post by bc3 » Sun May 28, 2017 2:44 pm
Just loaded the new firmware and wow! SO GOOD!
biggator6
Post by biggator6 » Sun May 28, 2017 9:41 pm
wait.. what is this? Is it a different firmware? Didn't see anything on the github page.
cliffemu
Post by cliffemu » Sun May 28, 2017 9:44 pm
^Wow do you understand what this means? Pitch cv plus file select cv, plus files organized in banks, WAV, in 4hp and inexpensive. This is very serious!!!! Many thanks to the creator.
New firmware also fixed my sd hotswap problem.
Mr_Mojo_Risin
Post by Mr_Mojo_Risin » Wed Jun 07, 2017 9:29 am
Here's a demo video of the new Radio Music firmware.
The new Chord Organ firmware looks amazing as well.
I need to quit my job so I can spend more time using all this new stuff!!! :hit:
plus: http://www.polyfather.com/chord_organ/
jfprimeau
Post by jfprimeau » Fri Jun 09, 2017 6:42 pm
The new firmware is amazing! I was mainly using the radio music for percussions, and now it works even better. However, I think that if the samples are too loud, the module clips a bit. Will need to investigate this further over the weekend. If it's the case, it's much easier to batch process WAV files to reduce their amplitude than the old process to convert to raw files. So rejoicing all around! Might get a second unit soon...
Mr_Mojo_Risin
Post by Mr_Mojo_Risin » Tue Jun 13, 2017 12:49 am
jfprimeau wrote:The new firmware is amazing! I was mainly using the radio music for percussions, and now it works even better. However, I think that if the samples are too loud, the module clips a bit. Will need to investigate this further over the weekend. If it's the case, it's much easier to batch process WAV files to reduce their amplitude than the old process to convert to raw files. So rejoicing all around! Might get a second unit soon...
:oldmanureuro: If it's clipping, don't forget about the 50K Ohm trimmer pot on the back of the module for adjusting the output volume.
From the install docs: "The trimmer on the back sets the output volume - adjust to your needs to avoid distortion"
Daisuk
Post by Daisuk » Fri Jun 30, 2017 6:01 am
Holy fuckballs, the new firmware for Radio Music is killer! :yay: :mrgreen:
Jumbuktu
Post by Jumbuktu » Fri Jun 30, 2017 7:32 am
Worwell wrote:Verbos Complex Oscillator sequenced by the Varigate 8 into Dual Wasp, QMMF, Elements and Rings. Radio Music sequenced by Maths into Geiger Counter.
Oops I quoted the wrong video. You know the one I mean.
There is something kind of weird about this video. I imagine Tom Whitwell as a Dr Who English genius character. Then we get an American accent in a video that sounds like a promo for Gillette or an automobile company. Not that it's a bad video. Just unexpected.
Daisuk
Post by Daisuk » Sun Jul 09, 2017 5:19 am
Radio Music with the new firmware squibbering the fuck out of this patch. :mrgreen:
http://soundcloud.com/hurumkisteforening/klinkekulene
Mr_Mojo_Risin
Radio Music Distortion Mod
Post by Mr_Mojo_Risin » Mon Jul 17, 2017 1:15 am
FYI -
I somehow missed this update when building my Radio Music modules.
Apparently, there is a problem with distortion if the module is powered on for long periods of time.
Simply adding a 100k resistor across two points will fix the issue.
The thread is here: https://github.com/TomWhitwell/RadioMusic/issues/70
unclebastard
Free audiobooks
Post by unclebastard » Mon Jul 17, 2017 5:41 am
This is a whole online library of public domain audio books, including H.P.Lovecraft and Philip K Dick: https://www.librivox.org/ which should provide hours of material
Struggle
Re: Free audiobooks
Post by Struggle » Mon Jul 17, 2017 7:02 am
unclebastard wrote:This is a whole online library of public domain audio books, including H.P.Lovecraft and Philip K Dick: https://www.librivox.org/ which should provide hours of material
Thank you!!
