SeaGoUt
gijs
SeaGoUt
Post by gijs » Sat Jun 13, 2015 2:46 am
made a module with seagate hard disc motors, check it here:
http://gieskes.nl/eurorack/?file=seagout
these 3 pin motors are difficult to get, so i just have a few. i can make kits if there is interest, then you could find your own motor.
lud
Post by lud » Sat Jun 13, 2015 4:36 am
Excellent idea well done!
roqeja
Post by roqeja » Sat Jun 13, 2015 8:25 am
lovely! interested!
FS: Harvestman Tyme Sefari and SOT Mk2, Synthrotek EKO
WTB: LZX VWG, A-198 Ribbon controller, Trigger Riot, Circadian Rhythm, d0, Storage Strip
glia
Post by glia » Mon Jun 15, 2015 7:01 am
what do the trim pots do?
gijs
Post by gijs » Mon Jun 15, 2015 2:23 pm
glia wrote:what do the trim pots do?
one trims the audio output, one trims the cv output and one sets the amount of demodulation of the cv output.
pulplogic
Re: SeaGoUt
Post by pulplogic » Mon Jun 15, 2015 4:04 pm
gijs wrote:made a module with seagate hard disc motors, check it here:
I love it! Very cool :sb:
Have you tried the little brushless DC motors used on small RC aircraft? You can get 3 phases 120 deg apart.
gijs
Re: SeaGoUt
Post by gijs » Tue Jun 16, 2015 4:53 am
thanks! no i did not know this, will take a look.
glia
Post by glia » Tue Jun 16, 2015 11:34 am
surprised there's no input for 317vcprea control
glennfin
Post by glennfin » Tue Jun 16, 2015 11:48 am
Awesome!.... love your circuit bent CT660 8-)
gijs
Post by gijs » Wed Jun 17, 2015 1:13 am
glia wrote:surprised there's no input for 317vcprea control
i don't understand..
glia
Post by glia » Wed Jun 17, 2015 3:39 am
this looks fantastic as is, but, i was imagining it might allow for cv control of the seagout's dc motor
mharpum
Post by mharpum » Wed Jun 17, 2015 8:28 am
Looks ace. What can you use it for?
glia
Post by glia » Wed Jun 17, 2015 8:48 am
mharpum wrote:Looks ace. What can you use it for?
a sine
a clock
a gate
+/- voltage
simultaneously if you need em
can be pretty much anything
adds human touch to your patch
Paranormal Patroler
Post by Paranormal Patroler » Fri Sep 06, 2019 3:07 am
Is anybody selling their SeaGoUt module? I'd like to buy one.
MarcelP
Post by MarcelP » Fri Sep 06, 2019 3:28 am
Paranormal Patroler wrote:Is anybody selling their SeaGoUt module? I'd like to buy one.
Seeing how small the motors are on tiny quad copters you might get a micro version in 2hp - or a quad version in 8hp. Happens to most everything else.
Paranormal Patroler
Post by Paranormal Patroler » Fri Sep 06, 2019 3:38 am
I'm sorry, but I'm not following. What do you mean? I doubt anyone would make a module where the panel is smaller than the range of the rotator. So a 2hp module is out of the question.
Anything between 6hp - 8hp seams feasible but other than the Gieskes, I know of no other manufacturer that would even bother with such a design.
MarcelP
Post by MarcelP » Fri Sep 06, 2019 4:21 am
I find it hard to believe anyone would make a panel narrower than a sensibly sized knob for human fingers, but it happens.
Paranormal Patroler
Post by Paranormal Patroler » Fri Sep 06, 2019 6:12 am
2hp modules are just fine. I actually prefer the minipots sometimes. For set-and-forget parameters they are perfect, as they are less likely to be knocked out of position when performing.
Anyway, still looking for a SeaGoUt module. :mrgreen:
MarcelP
Post by MarcelP » Fri Sep 06, 2019 8:28 am
Paranormal Patroler wrote:2hp modules are just fine. I actually prefer the minipots sometimes. For set-and-forget parameters they are perfect, as they are less likely to be knocked out of position when performing.
yeah - sorry I was just being facile for laughs, didn't mean to derail your search... :oops:
Good point about small pots being less likely to be knocked though.
Damn I just did it again! :doh:
Has anyone seen this mans module!?!?
Paranormal Patroler
Post by Paranormal Patroler » Sat Sep 07, 2019 2:16 am
Does anyone know if there are smaller HDD motor / spindles than the one used here? I'm thinking a 6hp version of this should be possible without losing much rotational energy.
Paranormal Patroler
Re: SeaGoUt
Post by Paranormal Patroler » Sat Aug 01, 2020 11:04 am
And after almost a year I managed to get one of these. Just received mine directly from Gieskes. Can't wait to put it on the case!
Re: SeaGoUt
Post by Kent » Sat Aug 01, 2020 11:23 am
Nice! Can't wait to hear some sounds from you.
