New Doepfer Power Supply A-100PSU3
youkon
frequency research department
Post by youkon » Thu Dec 20, 2018 4:16 am
I would never have imagined that I run out of power with the psu3, but I actually did!
I have a large system. 1 psu3 per 2 rows of approximately 104 HP.
Now my mixing part of the system seems to be the most power hungry part.
Installed more filters, then this suddenly happened after some hours:
video is so short because I better wanted to power down the system :-D
what you see is constant flickering of the led's from different modules. All at the same time.
5V led on the doepfer busboard blinking as well, -12V led off.
I then checked modulargrid:
Power Consumption: 1553 mA +12V | 1598 mA -12V | 0 mA 5V
too much need for -12V!!! damn!!!!!
don't know what to do now..... of course I could spread them over my whole system, but I want to keep them toghether.
Perhaps a tiny extra psu inside the case for the wmd performance mixer?
Shledge
Post by Shledge » Thu Dec 20, 2018 4:36 am
It's more likely your tube module. They eat up power like no tomorrow.
Plugler
Post by Plugler » Fri Dec 28, 2018 8:53 am
Hi,
how hot will the PSU3 get, if only using less then 1/2 of the max. power?
I'm thinking about putting one into an external self-build wooden case as "external power supply".
And connecting it with a 84HP skiff via XLR connectors.
In this way, I don't need a front powered PSU like e.g. "Tiptop Audio - uZeus", and will not waste precious HPs.
Will the long +12/-12/5V connection produce noise or other problems?
I would use a good 4x1,0mm cable like this:
https://www.thomann.de/gb/jaeger_h07rn_f_4_x_10_mm.htm
youkon
Post by youkon » Sun Dec 30, 2018 2:13 pm
Shledge wrote:It's more likely your tube module. They eat up power like no tomorrow.
btw: I've put that module now into another case and the problem disappeared
ersatzplanet
Synthwerks Design
Post by ersatzplanet » Sun Dec 30, 2018 5:42 pm
Plugler
Edit: I didn't check out the cable you showed. Are you planning on using the barrel on the XLR for ground or are you using a 4-pin XLR? Manny XLR connectors internally connect the barrel to the center pin with the screw that locks the connector together.
-James
Plugler
Post by Plugler » Tue Feb 05, 2019 5:24 pm
ersatzplanet wrote:Plugler
I have just discovered your message. :confused:
I've planned to use 4-pin XLR for this. As I always use 4-pin XLR for connecting power at my Eurorack cases. To prevent problems with normal audio XLR. :hihi:
But I've changed my plans. I've built recently my planned skiff, but instead of a fully external PSU I've used a small internal PSU: "Microbus DIY" from Frequency Central.
That delivers enough power for my modules: ~750mA at +/-12V and 100mA at +5V
Here are further details and photos of my new skiff:
viewtopic.php?p=2990982#2990982
Mr. Aloud
Re: New Doepfer Power Supply A-100PSU3
Post by Mr. Aloud » Mon Mar 23, 2020 4:08 pm
I´m getting more and more tempted to get Monster Base as my next case, but I don´t like the internal PSU.
- I´ve been running into power limitations with another case already and don´t want ever see that again
- Internal PSU will add to the heat generated by the modules. Fans are out of the question.
- There is probably not enough room to add a 3rd PSU-3 should I decide to need one
Which brings me to the question: Are there any decent solutions to have a "PSU-3 power brick", preferably metal casing for better heat dissipation? Preferably not in the ACL power bar price range, because then I could pick one of those instead ^^.
It would seem that still, after all these years, perception is essentially thought to be a passive process.
Chartreuse-J
Post by Chartreuse-J » Mon Mar 23, 2020 10:10 pm
These power supplies don't get hot. Your modules are probably generating more heat than the PSU-3. As long as you have A/C, you have nothing to worry about in that regard.
I've added some pretty hungry modules to my Dopefer case, 78deg F maintained keeps everything cool even after leaving these cases on for over 24 hours.
Mr. Aloud
Post by Mr. Aloud » Mon Mar 23, 2020 11:05 pm
Now that is good news! Easy to build an external case then or - if space permits - put them inside the rack. Thanks for pointing that out!
