there are 3 jumpers on the PCB
#1 is the sync Jumper
#2 and #3 is the saw up saw down jumper
and where are the triangle / trapezoid jumpers?
I've never confirmed the 53 minute maximum, but Batumi can definitely do over 10 minutes in Quad mode with negative CV, and the first LFO does serve as the master controlling the frequency of the other three LFOs. The manual is pretty clear about this, but I just tested it on mine to be sure and can confirm that the phase relation of the 4 LFOs stays the same when slowing down the master LFO with CV.Dadodetres wrote: ↑Sat Feb 20, 2021 1:25 pmHello!
Im interested in having 4 LFO´s with the same 90 degrees out of sync. I need the rate to be between 2 and 10 minutes slow.
Im reasearching and maybe the XAOC Butami can do this, setting it to QUAD mode.
The manual says that negative voltage in the "frq/ph/div" CV input will allow an extended frequency range up to 53 minutes, but doesnt specify if all the LFO`s will react to this lowering of frequency, while mantaining the "90 degrees out of phase" relation of the QUAD mode . Maybe only LFO 1´s rate changes.
Is there another module that can do this?
thanks!
Ornament and Crime
Like many wigglers, I have a Batumi and an o_C (and actually, a uo_C, too). They’re reallly not equivalent, though.
The o_C requires a ton of menu diving. I keep it around for the quantizer and chaos modes, but I've never found it fun to use, at least not with the original firmware. Hemispheres is a bit easier to set up.Dadodetres wrote: ↑Sat Feb 20, 2021 5:26 pmThe o_C seems to require menu-diving, is this correct?
I dont want to menu diving, unless is 100% necesary.
The o_C is not fun to use as is, but is really powerful, and has a lot of functions that can be sequenced/controlled by CV.bronzebygold wrote: ↑Sat Feb 20, 2021 5:32 pmThe o_C requires a ton of menu diving. I keep it around for the quantizer and chaos modes, but I've never found it fun to use, at least not with the original firmware. Hemispheres is a bit easier to set up.Dadodetres wrote: ↑Sat Feb 20, 2021 5:26 pmThe o_C seems to require menu-diving, is this correct?
Then you don't want an Ornament & Crime.Dadodetres wrote: ↑Sat Feb 20, 2021 5:26 pmThe o_C seems to require menu-diving, is this correct?
Personally I found Batumi more menu-divey than the o_c and, beyond doing really basic stuff, obtuse and frustrating. Different strokes and all that...AnalogDigits wrote: ↑Sat Feb 20, 2021 6:23 pmThen you don't want an Ornament & Crime.Dadodetres wrote: ↑Sat Feb 20, 2021 5:26 pmThe o_C seems to require menu-diving, is this correct?
Are you sure you’re talking about the same Batumi? What menu are you referring to exactly? One on the back of the module? I guess I missed that when I was installing.muleskinner wrote: ↑Sat Feb 20, 2021 6:55 pmPersonally I found Batumi more menu-divey than the o_c and, beyond doing really basic stuff, obtuse and frustrating. Different strokes and all that...AnalogDigits wrote: ↑Sat Feb 20, 2021 6:23 pmThen you don't want an Ornament & Crime.Dadodetres wrote: ↑Sat Feb 20, 2021 5:26 pmThe o_C seems to require menu-diving, is this correct?
I dont want to menu diving, unless is 100% necesary.![]()
A menu doesn't have to involve a screen. Zoom mode on Batumi is a menu dive, albeit without a screen,so you end up with sliders in the 'wrong' place. It's very far from a 'one knob per function' module unless you ignore the zoom mode and alternate firmwares.guitargyro wrote: ↑Sat Feb 20, 2021 9:58 pmAre you sure you’re talking about the same Batumi? What menu are you referring to exactly? One on the back of the module? I guess I missed that when I was installing.
This. It's a case of menu-diving vs manual-divingmuleskinner wrote: ↑Sun Feb 21, 2021 4:18 amA menu doesn't have to involve a screen. Zoom mode on Batumi is a menu dive, albeit without a screen,so you end up with sliders in the 'wrong' place. It's very far from a 'one knob per function' module unless you ignore the zoom mode and alternate firmwares.guitargyro wrote: ↑Sat Feb 20, 2021 9:58 pmAre you sure you’re talking about the same Batumi? What menu are you referring to exactly? One on the back of the module? I guess I missed that when I was installing.
It also requires a negative voltage patched to the frequency input to get the free-running LFOs running at what I would define as 'slow'.
Hey, you’re obv the “expert”. I’ve never heard anyone complain about the standard firmware (or the expert til now) and I haven’t found the need to change anything myself. So my ignorance sounds bliss and I’ll be sticking with mine from your description.muleskinner wrote: ↑Sun Feb 21, 2021 4:18 amA menu doesn't have to involve a screen. Zoom mode on Batumi is a menu dive, albeit without a screen,so you end up with sliders in the 'wrong' place. It's very far from a 'one knob per function' module unless you ignore the zoom mode and alternate firmwares.guitargyro wrote: ↑Sat Feb 20, 2021 9:58 pmAre you sure you’re talking about the same Batumi? What menu are you referring to exactly? One on the back of the module? I guess I missed that when I was installing.
Sorry to bring up an old post, but I am interested in how you use Batumi as a clock divider. I assume you can send an external clock into one of the sync inputs, and then use a square wave LFO to divide it?jarvis wrote: ↑Sun Nov 08, 2015 4:06 pmIt's pretty handy and does things that your current (and prospective) LFOs can't do.
Phase and quadrature modes are great for "cascading" modulations, where the outputs are all at the same frequency but at varying offsets (phases) of the 1st LFO.
I often use division mode as a clock divider, but it's great to have lfo's that are at multiples of the 1st LFO.
Plus they're working on some open source firmware updates, so I'm sure some people will come up with some interesting modes for it.
The "expert firmware" by Matthias Puech (just a name someone gave to it, not saying it is for experts!) lets you, among other things, set the level of the LFOs by: moving a fader (to select it), holding the button, then adjusting the second fader. I switched to this firmware for this feature alone, since it freed up attenuators. But yeah, it's not really that "fun" to do, feels a little tedious.guitargyro wrote: ↑Sun Feb 21, 2021 8:36 amHey, you’re obv the “expert”. I’ve never heard anyone complain about the standard firmware (or the expert til now) and I haven’t found the need to change anything myself. So my ignorance sounds bliss and I’ll be sticking with mine from your description.muleskinner wrote: ↑Sun Feb 21, 2021 4:18 amA menu doesn't have to involve a screen. Zoom mode on Batumi is a menu dive, albeit without a screen,so you end up with sliders in the 'wrong' place. It's very far from a 'one knob per function' module unless you ignore the zoom mode and alternate firmwares.guitargyro wrote: ↑Sat Feb 20, 2021 9:58 pmAre you sure you’re talking about the same Batumi? What menu are you referring to exactly? One on the back of the module? I guess I missed that when I was installing.
