Tiptop Mantis cases
MutantLabs
Re: Tiptop Mantis cases
Post by MutantLabs » Wed Mar 25, 2020 5:14 am
To those with brackets: If you push a module (like when pluggin in a patchcable) on the top Mantis, will the whole thing bend or move backwards? How stable is it?
bin7me
Post by bin7me » Tue Apr 14, 2020 2:57 am
It's incredibly stable and both cases feel like a single unit, patch cables won't move it at all and I have to push with my whole arm to get it to move, as the rubber sliders provide good grip on my desk. (It won't tilt, as the brackets protrude quite a bit in the back)
solipsvs
Post by solipsvs » Tue Apr 14, 2020 9:57 am
same with my brackets
variablewaveshape
Post by variablewaveshape » Tue Apr 14, 2020 12:00 pm
the brackets are rock solid, nothing ever feels like its wiggling around
MutantLabs
Post by MutantLabs » Wed May 06, 2020 11:30 am
Thanks for the reassurance that the stacked cases will be stable.
fredke
Post by fredke » Wed May 06, 2020 11:49 am
I have a Mantis.
Pros:
- super stable, super solid
- very ergonomic, with 2 positions: horizontal or at an angle
- a power rail with MANY connectors
- 2 power possibilities: USB or regular wall wart.
Cons:
- receded rail: you'll need longish screws.
- no protecting cover for transporting a patched patch, and
- the optional bag is very tight, making it impossible not to turn knobs when sliding the mantis in or taking it out
[EDIT: apparently there is a new soft case, that opens like a suitcase, and seems to solve these last two points]
- some shallow zones, where thick modules become problematic
solipsvs
Post by solipsvs » Wed May 06, 2020 12:20 pm
they also have their very own decksaver design for sale over at decksaver.com i think it is
solipsvs
Post by solipsvs » Wed May 06, 2020 12:24 pm
fredke
Post by fredke » Wed May 06, 2020 6:04 pm
Yeah ok. I didn't know. This would actually get it protected more than my other racks, which I never close (except for moving them). From the website, we don't know whether it will keep shut with cables pushing from the inside, but if it does then it's actually a great product.
solipsvs
Post by solipsvs » Wed May 06, 2020 8:30 pm
lil bit o duck tape’ll git er done!
drowld
Post by drowld » Sat Jun 20, 2020 4:41 am
Owners of 2 mantis how do you stack them ? I don't really like the kinda permanent stack brackets they are selling so looking for alternatives
blakeq
Post by blakeq » Sat Jun 20, 2020 10:45 am
You could try a laptop stand.
Mr. Aloud
Post by Mr. Aloud » Sun Jun 21, 2020 12:21 am
https://www.thomann.de/de/km_heli_2_black_acoustic.htm
Acoustic guitar stand. Should be easily available at every music shop near you.
It would seem that still, after all these years, perception is essentially thought to be a passive process.
virtualpt
Post by virtualpt » Sun Jun 21, 2020 6:24 pm
I bought one of these https://duronic.com/products/duronic-mo ... 6cm-x-24cm (they seem to be sold out now, but there must be others with similar measurements). It is the perfect size & gives me the same sort of layout I'd get by using the brackets, but with the flexibility to move each individual rack (plus it's a lot cheaper than the brackets). The Mantis sits solidly on the stand & I have had no issues with it at all.
Matt_L
Post by Matt_L » Tue Jun 23, 2020 4:54 pm
What modules have folks been struggling to fit in their Tiptop Mantis cases? I've yet to come across a module that is too deep, but I'm struggling right now to fit the Befaco Hexpander in -- the Hexpander has a unique two-tiered PCB layout which seems too big for the case. Might have to try to file down the board?
edit: Was able to fit it in the bottom row with some elbow grease. Still a very tight fit
bago
Post by bago » Tue Jun 23, 2020 5:36 pm
Most of my newer WMD modules are hard to fit due to there big PCBs. The newest one (crater) doesn‘t fit at all in any spot or position. I also tried to file down the top and bottom of the PCB, but it still won’t fit.
a773
Post by a773 » Wed Jun 24, 2020 5:57 am
Nano rand won’t fit, rails press on the side of the button, making it stick. Found an ok position at some point, but at the current location it won’t fit at all...
scarkord
Post by scarkord » Wed Jun 24, 2020 6:47 am
Here's how I stack my three Mantis...
Agawell
Post by Agawell » Wed Jun 24, 2020 7:30 am
for people having issues trying to fit modules into the rack - did you try loosening the rails a little bit and wiggling them a bit? - slight rotation
the only modules I have ever had issues with are ones that are too deep (don't fit at all) and a malekko invmix - where the panel is 0.1mm (or something) too high - but will fit with a bit of wiggling
Instagram
Utility modules are the inexpensive, dull polish that makes the expensive, shiny modules actually shine - and stops them tarnishing too!!!
3hands
Post by 3hands » Wed Jun 24, 2020 7:47 am
Things I own that won’t fit in my Mantis...
Living Memory VCO (It’s a monster)
4MS Rotating Clock Divider (Randomly deep PCB and Finn for coming off the back which adds an additional 2mm or so.)
And that’s it!! Haha!
Gum is fun, but not on a cat.
My minds an art gallery.
TheNthMan
Post by TheNthMan » Wed Jun 24, 2020 9:26 am
I have a Mantis.
Pros:
Cons:
How do you power the Mantis with USB? Is it a separate USB B adapter to 15v barrel adapter? I would love to power a Mantis case directly with USB C or similar.
continuum
Post by continuum » Wed Jun 24, 2020 10:00 am
I have a Mantis.
Pros:
Cons:
Mantis cannot be powered from USB. The second connector on Mantis is for Syncbus but the cables were never made due to lack of demand.
Tiptop Audio R&D
www.tiptopaudio.com/
TheRosskonian
Post by TheRosskonian » Wed Jun 24, 2020 10:08 am
You have to file the button down on the side that rubs again the rails. I did it a while ago, do not remember the details, but I don't believe I even had to take the module apart to do this. Once you do this, the button should work with no friction on the rails.
a773
Post by a773 » Wed Jun 24, 2020 11:00 am
How do you keep the top one from falling forwards?
WMDevices
Post by WMDevices » Wed Jun 24, 2020 3:39 pm
You should be able to loosen the mantis rails from the side, and that will get them spaced out a bit more.
Check out the growing number of WMD Demo Videos | WMD Website
