The elusive 'all black' panel themed euro systems.
SunSpots
Post by SunSpots » Wed May 22, 2019 4:11 pm
Has anyone used printable aluminum before? This company does custom sizes/prints. I imagine you would need to maybe settle here, not sure.
but what if you somehow coated your existing panel with some vinyl coating so that the vinyl heat transfer would work?
SunSpots
chuckleone
Post by chuckleone » Thu May 23, 2019 1:36 pm
sempervirent wrote:
chuckleone wrote:Thanks for the info in the knobs. I measured the shaft on my Maths and they are 6mm with a flat side, essentially half a shaft. I’m looking at just replacing the blue ones with white or replacing all of them with a completely different set. I haven’t decided yet.
Yep, those are the typical 6mm D-shaft knobs used by most Euro manufacturers so the knobs I linked to are identical replacements for the ones that MN uses.
Thanks a lot!
retoid
Post by retoid » Sun May 26, 2019 10:23 am
VM wrote:
retoid wrote:@doubleehno
Thank you very much! I've got a couple MN panels designed up but not finished yet. Here is Maths.
Where/when can we buy these and the others you've made?
Sorry I missed your post, you can find them at https://bkmpanels.bigcartel.com
Maths should be available in a month or so.
Thank you
retoid
Post by retoid » Sun May 26, 2019 10:31 am
Black_Materia wrote:Does anyone know where to purchase the 'official' Xaoc Batumi black panel? I can only find the BKM ones, and from what i can tell from actual photo's i'm not completely convinced by their durability and build quality.
Hey, was wondering what sort of things worried you about the build quality of the BKM panels? They are made from 2mm thick FR4, the most common PCB sizes are 1.6mm and 1.8mm. 1.6mm can feel a little flimsy and easy slightly bendable. But moving up to 2mm thick they feel pretty solid and do not flex.
If located in the states I'd be happy to send you a second/off panel to let you feel and see it in person.
ggillon
Post by ggillon » Mon May 27, 2019 4:33 am
I can confirm the BKM feel very solidly made and are nearly undistinguishable from make noise black and gold panels.
Black_Materia
Post by Black_Materia » Mon May 27, 2019 5:26 pm
I thought i noticed in pictures that sometimes pots or buttons aren't properly centered in the gold-ringed openings for them on the panel, also it seems as if the printing on the panels would be easily damaged or rubbed off. These concerns are more aesthetical rather than functional.
I admit i haven't seen any in person and i like the look. I am based in Europe.
61050
Post by 61050 » Mon May 27, 2019 9:23 pm
eagerly awaiting the release of the cinnamon BKM panel. :tu:
ggillon
Post by ggillon » Tue May 28, 2019 2:56 am
Black_Materia wrote: I thought i noticed in pictures that sometimes pots or buttons aren't properly centered in the gold-ringed openings for them on the panel, also it seems as if the printing on the panels would be easily damaged or rubbed off. These concerns are more aesthetical rather than functional.
The printing is resisting fine. The layer is quite thick and I think it sticks better to PCB than aluminium. Only time I had issue with paint scratching off was with the Noise engineering panels. Those have really weak printing.
No problem with the opening alignment neither on those I got.
ggillon
Post by ggillon » Tue Jun 04, 2019 1:22 pm
Project "reface" is finally completed:
MARK27
Post by MARK27 » Tue Jun 04, 2019 1:24 pm
ggillon wrote:Project "reface" is finally completed:
Magnificent!
Absolutely beautiful!
gentle_attack
Post by gentle_attack » Tue Jun 04, 2019 4:31 pm
The Sequential Switch Matrix + Expander would be awesome to Black & Gold too.
@retoid if you are mad I keep asking and haven't bought (if you are keeping track that is) I have an additional 208hp en route and will be making purchases shortly. Cheers!
Control Skiff ||Big Case || cv.ocd || TT303v2 || Manther || OP-1 OP-Lab|| Octatrack Digitone RYTM || BX-8 BX-16 || Monologue KP3+
kristian
Post by kristian » Fri Jun 07, 2019 6:22 am
my BKM panels arrived today, well impressed!
retoid
Post by retoid » Fri Jun 07, 2019 11:18 pm
Wow that looks really nice!
@gentle_attack haha nah, not mad at all :) not keeping track either haha. Thanks buddy, appreciate it.
@Kristian, thank you! :)
ggillon
Post by ggillon » Tue Jun 25, 2019 4:07 pm
retoid wrote: Wow that looks really nice!
Well thank you for the nice panels ;)
Just made a track to celebrate it
http://soundcloud.com/gautier-gillon/canicule
retoid
Post by retoid » Sun Jun 30, 2019 9:15 am
Just got some more panels back from the manufacturer, here is Maths.
Joey P.
Post by Joey P. » Sun Jun 30, 2019 10:35 am
chuckleone wrote:
..swapped out the plates for BIA, Mimetic Digitalis and Maths.
I still need to source out some replacement knobs for Maths but I absolutely love the way it looks in black. Props to Grayscale for the awesome design!
Nice...I just replaced four NE modules with the black panels. I also have white switch caps arriving today. I also ordered red, yellow and green caps to see what they look on the Mimetic Digitalis to match the LEDs.
Also recently ordered some white knobs for my Maths here:
ROGAN KNOBS
Not sure if you are in the US, but if you are in Europe, there is a thread here about MN knobs with a link to a Euro dealer as well.
peripatitis
Post by peripatitis » Sun Jun 30, 2019 10:54 am
retoid wrote:Just got some more panels back from the manufacturer, here is Maths.
Loving that panel :tu:
target_destroyed
Post by target_destroyed » Sun Jun 30, 2019 3:07 pm
Does anyone make a black panel for Akemie's Castle?
abozzelli
Post by abozzelli » Sun Jun 30, 2019 3:34 pm
Cool panels, can I ask what the name of the font? I'd like to use it for some custom projects.
retoid
Post by retoid » Sun Jun 30, 2019 5:09 pm
abozzelli wrote:Cool panels, can I ask what the name of the font? I'd like to use it for some custom projects.
Thank you but it's not a font, I draw each letter in a PCB CAD application following a grid. It's drawn with straight lines that have rounded edges.
retoid
Post by retoid » Fri Jul 12, 2019 10:56 pm
Makin' some progress.
Image[/url]
nolongerhuman
Post by nolongerhuman » Sat Jul 13, 2019 12:21 am
Just a shout out to BKM panels. Ordered a couple recently and they are exceptionally high quality. Essentially a dead on match for the Make Noise B&G panel style.
kristian
Post by kristian » Sat Jul 27, 2019 3:44 am
Any hope for black Erbe-Verb ? :love:
christie
Post by christie » Sat Jul 27, 2019 3:55 am
Here's my small traveling eurorack. Yes it's only half black but you can see the grayscale black erbe verb panel. Also you can see my blacked out tetrapad. That turned out to be super simple - just remove the panel, mask off the line of numbered jacks and spray it black. There are no other labels on the panel to worry about.
Zerius
Post by Zerius » Sat Jul 27, 2019 8:33 am
Where did you find those stickers on your black key step?
