1010 Music Bitbox - Sampler/Looper
stujay18
Re: 1010 Music Bitbox - Sampler/Looper
Post by stujay18 » Sun Sep 27, 2020 8:09 pm
exper wrote:
Mon Sep 21, 2020 1:57 pm
stujay18. Please post if you see flickering on the replacement. My screen was shot as well, but the replacement they sent is still flickering. So I’m not sure if it’s a matter of time before it dies or ??. I think I’ll still return it if there’s no improvement.
Worse. They "fixed" it and sent it back. Dead again within 5 minutes of use. Returning it for a Rample. I've lost confidence in 1010 Music.
DoverBeach
Post by DoverBeach » Wed Sep 30, 2020 3:26 pm
Hello everyone, is it possible to play samples poliphonically via cv or do I need to sequence it over midi?
pekbro
Post by pekbro » Wed Sep 30, 2020 4:50 pm
You can trigger them of course, if that's what you meant.
DoverBeach
Post by DoverBeach » Wed Sep 30, 2020 10:08 pm
Thank you for your answer.
I mean sequencing samples poliphonically to play chords with a sequencer. ..
I read that bitbox has 4 note polyphony but I can't figure out how can I play let's say a C maj from a cell that contains a piano sample. I was able to play chords with the touchscreen piano on the bitbox so I assume it's possible, but when I send pitch infos on the trigger input it just trigger the sample.
English is not my native language, hope it's more clear now.
pekbro
Post by pekbro » Wed Sep 30, 2020 11:47 pm
Yeah if you use midi, you can play them chromatically. Otherwise, you could probably rig something
to modulate the pitch with the cv inputs. But midi is the method they have allotted for that.
Check to see if you need their proprietary midi adapter as well, since the BB wont work with everything
out of the box.
-Cheers
kriskeyman
Post by kriskeyman » Thu Oct 08, 2020 9:44 pm
Having a hard time finding a straight answer to this... will bitbox mk2 audio input accept line level in addition to euro level for recording?
menagerie
Post by menagerie » Fri Oct 09, 2020 2:40 am
Yes, I did this from my Android phone directly to the Bitbox Micro and it worked very well. I think mobiles output line level?
Just as an aside, not sure if anyone else has had issues with recording deep, bass heavy sounds - I was recording a kick with a lot of low end and ended up with a horrible, noisy, distorted recording. And no, definitely wasn't clipping when recording!
DoverBeach
Post by DoverBeach » Sun Oct 18, 2020 8:53 am
fx box available for bitboxmk2 :nana:
seychmar
Post by seychmar » Sun Oct 18, 2020 12:31 pm
Synthbox available for bitbox mk2 as well.
DoverBeach
Post by DoverBeach » Sun Oct 18, 2020 12:35 pm
synthbox is underrated imho.
seychmar
Post by seychmar » Sun Oct 18, 2020 12:39 pm
I agree. Great way to get wavetables into a modular system, especially with the individual output per voice.
pekbro
Post by pekbro » Sun Oct 18, 2020 4:53 pm
It's pretty much the only thing I use the BB for anymore...
Popemello
Post by Popemello » Mon Oct 19, 2020 12:42 am
Yes, but you may have to turn the gain all the way up on the sample. I use an input amplifier (error instruments megaphone for example) to maximize the sound. I have also noticed that some instruments provide more ‘drive’ than others in terms of the BB signal recording.
LDT
The Modu-Lars
Post by LDT » Mon Oct 19, 2020 4:32 am
Does Synthbox run on Bitbox Micro?
xcc
Post by xcc » Mon Oct 19, 2020 7:50 am
Nope. Hopefully someday.
djthopa
Post by djthopa » Fri Oct 23, 2020 1:30 pm
stujay18 wrote:
Fri Sep 11, 2020 10:07 pm
I'm another victim of the dead-screen-practically-out-of-the-box Bitbox Micro. Attempting to lower brightness fries the module. Contacted 1010music for guidance. I feel for them, this has to be a nightmare, and an expensive one at that.
Same here, didnt even touch the brightness settings. Screen failed straight away.
Contacted 1010 and im wating for answer to get it repaired (hopefully)
Shop was upset since they thought this issues had been ironed out.
:cry:
Post by exper » Fri Oct 23, 2020 1:44 pm
EDIT: Answered in PM...
FS/T: CV.OCD / Goike Folding Case / Grayscale Panels
djthopa
Post by djthopa » Sat Oct 24, 2020 2:32 pm
Got a quick reply from 1010 abd aparentoly my module is from the first batch.
Arranging repair at the moment :tu:
Bob Charlotte
Post by Bob Charlotte » Wed Oct 28, 2020 9:16 am
Will they solve the screen problem with the second batch? I'm really interested in the micro, but all the dead screen posts here and on the 1010 forum are pulling me back.
xcc
Post by xcc » Wed Oct 28, 2020 11:16 am
If it adds a data point I can say my recently purchased Micro has no issues with the screen. I did accidentally change the brightness the other night and almost panicked though.
Underwood
Post by Underwood » Wed Oct 28, 2020 1:11 pm
People without problems probably don't post about it. Bought mine about two month ago and it works fine.
kriskeyman
Post by kriskeyman » Wed Oct 28, 2020 7:11 pm
I’m hearing a high pitched noise from the bitbox mk2 module when brightness is lowered. Using latest firmware, have tested in multiple cases. Also, I don’t notice a change in brightness until about 10%. So...
0-10% lowers brightness, no high pitched noise
11-99% no change in brightness + high pitched noise (most audible around 50%)
100% no issues
Anyone else having this issue?
rayultine
Post by rayultine » Wed Oct 28, 2020 10:54 pm
I don't have a high pitched noise, but yeah there is almost no sensitivity to the brightness on the mk2 until you get to 10%. Very silly
scragz
Post by scragz » Wed Oct 28, 2020 11:57 pm
I just checked and mk1 has all the brightness adjustment between 8.5% (totally black) -> 10% (full brightness).
Bob Charlotte
Post by Bob Charlotte » Fri Oct 30, 2020 10:46 am
That's for sure. But read about people having some problems even with a repaired unit it's something to worry about. Glad to read some wigglers don't have this failure, btw.
