unfortunately you lose all that glide goodness. sinfonion however will scale the input and can also pass glides which is the only workaround I'm aware of.uebl wrote:I know it's not what you'd like to hear, but you can of course just attenuate and use an external quantiser. Yes, I know, more hp. I would also love to have this functionality, but it's not gonna happen, I'm afraid.
Malekko Heavy Industries Voltage Block
- meatbeatz
- Super Deluxe Wiggler
For anyone who may run into the same "VB stops responding to clock" problem I had:hewed wrote:Is there a reliable key sequence to get the unit responding to external clock? I've convinced it to start sometimes by mashing mute, shift and length in random combinations, but not reliably.
- My VB is a v1.5
- I finally got around to contacting Malekko support about this issue
- I got a very fast and friendly response from Paul
- After trying a few things, it turned out flashing the v1.5 firmware onto the unit fixed it up straight away
- I also got to exchange pleasant pleasantries with a key member of Ministry and Lard, both bands who were the soundtracks of my late teens/early 20s and whose music I can still happily listen to
More GAS budget than talent
Re: Malekko Heavy Industries Voltage Block
I'm looking for a hands-on way to send up to 16 preset voltages to multiple destinations in a patch. Can you slave a Voltage Block to another Voltage Block?
Also, when using very slow clocks, how smooth is "SMOOTH"? Will it slowly morph between presets? I see no means to change the glide rate, so I assume it is derived from the external clock?
Finally, how mature is the current firmware and have all bugs been ironed-out? Thanks!
- bemushroomed
Does anyone know how many stages of attenuation is possible with this?
Yes, i know you can put 16 notes in the sequence, i mean possible note range in total.
This isn't in the manual. Maybe its somehow self-explanatory and its just me who doesn't get it.
I want to use it for a wide range of sample selection.
Edit: I used a text-to-speech program and sampled numbers from 1 to 60. I was able to dial in 36 samples.
Edit 2: Got a reply from Malekko (i emailed them earlier today).. they claim it's 60 in chromatic scale (didnt test chromatic scale, only unquantized - which i thought would give the best range).
Re:
Where can i get the VB Firmwire ? And how can i flash it ?hewed wrote: ↑Sat Dec 14, 2019 7:07 amFor anyone who may run into the same "VB stops responding to clock" problem I had:hewed wrote:Is there a reliable key sequence to get the unit responding to external clock? I've convinced it to start sometimes by mashing mute, shift and length in random combinations, but not reliably.
- My VB is a v1.5
- bemushroomed
When did you buy it? Just very recent ones can be updated afaik.
I dont know the exact date.bemushroomed wrote: ↑Sat Apr 04, 2020 4:40 amWhen did you buy it? Just very recent ones can be updated afaik.
I think about its about 12- 18 months old
I got a copy and instructions from Paul Barker at Malekko after sending a note to Malekko customer support and swapping a few e-mails as I tried different solutions.
- RustedMechanism
- Learning to Wiggle
I am just a couple days into my new Voltage Block, and I am running into a very frustrating problem. VB will be functioning as it should, until the Length control stops working. No matter how many steps are selected, VB remains playing all 16 steps (however, LEDs are acting as they should). This has happened twice now, with just powering off/back on seeming to be the only remedy. I am in the process of writing to Malekko support, but I just figured I'd mention this here as well.
Has anyone else encountered this?
“... just as early industrial capitalism moved the focus of existence from being to having, post-industrial culture has moved that focus from having to appearing.”
I've never encountered this problem. Are you sure you have the right channel selected first? Use the shift button to make sure you have the right channel selected first.RustedMechanism wrote: ↑Wed Apr 22, 2020 9:49 pmI am just a couple days into my new Voltage Block, and I am running into a very frustrating problem. VB will be functioning as it should, until the Length control stops working. No matter how many steps are selected, VB remains playing all 16 steps (however, LEDs are acting as they should). This has happened twice now, with just powering off/back on seeming to be the only remedy. I am in the process of writing to Malekko support, but I just figured I'd mention this here as well.
- RustedMechanism
Thank you for your response! My problem was in fact user error, only slightly embarrasssing.TTHX wrote: ↑Thu Apr 23, 2020 7:34 amI've never encountered this problem. Are you sure you have the right channel selected first? Use the shift button to make sure you have the right channel selected first.RustedMechanism wrote: ↑Wed Apr 22, 2020 9:49 pmI am just a couple days into my new Voltage Block, and I am running into a very frustrating problem. VB will be functioning as it should, until the Length control stops working. No matter how many steps are selected, VB remains playing all 16 steps (however, LEDs are acting as they should). This has happened twice now, with just powering off/back on seeming to be the only remedy. I am in the process of writing to Malekko support, but I just figured I'd mention this here as well.
- aintnopicnic
Re:
Hi, can you tell where it is possible to download a firmware for the Voltage Block?hewed wrote: ↑Sat Dec 14, 2019 7:07 amFor anyone who may run into the same "VB stops responding to clock" problem I had:hewed wrote:Is there a reliable key sequence to get the unit responding to external clock? I've convinced it to start sometimes by mashing mute, shift and length in random combinations, but not reliably.
- My VB is a v1.5
Searched on the Malekko Site.
Help would be greatly appreciated.
Thanks a lot!
- aintnopicnic
- jwise
- Wiggling with Experience
- Contact:
So I'm confused as I thought it was common knowledge that the Voltage Block could not be updated with new firmware? Can someone please clarify?
They released a new hardware version who can handle firmware update some times ago.
instagram | current rack | bandcamp | audiomack | ig
FS EU/CH:
- mosorensen
Is there a way to tell which version you have?
I’d be curious to know how you can tell which version I have as well. If anyone knows, please let me know. Thanks.
- aintnopicnic
Paul from Malekko told me it has to be the one with black PCBs. At the moment, I don‘t know if there is an updated firmware available. Maybe it‘s just the ‚old’ and there‘s just the possibilty to flash it because of malfunction.
I‘ll post it, when I have the time to sort out problems
with their support.
with their support.
Thanks for letting me know. Unfortunately my module has red PCBs.
How fast can the vb be clocked? Anyone here experimented with clocking at audiorate, so you get a wavetable like behaviour with the vb?
- Veteran Wiggler
So the Voltage Block is a module that somehow intuitively clicked right away for me. But I'm wondering if I'm missing any non-obvious ways to use it or any weird tricks. Anyone?
found this vid … but doesnt explain anything in detail:
its a digital sequencer so it wont get as fast and wont sound as a analog sequencer does
