Expert Sleepers Disting Mk4
os
Post by os » Wed Aug 22, 2018 6:12 am
It's 100 samples per playlist at the moment. The recently-added multisample playback uses multiple sample folders, and I plan to extend that to the other algorithms soon.
wickfut
Post by wickfut » Wed Aug 22, 2018 7:52 am
thanks.
looking forward to it
os
Post by os » Fri Aug 24, 2018 1:57 pm
Just thought you might like to know that I have this working - switchable folders of samples for all sample playback algorithms.
7C
Post by 7C » Mon Aug 27, 2018 2:17 am
the jacks on a friend's of mine are a total mess, unfortunately. it's unusable most of the time. and idea how to fix this (changing isn't that easy is it?) except taping the cables to the module?
soundcloud > https://tinyurl.com/y6jbowbh
nonetheless bandcamp > https://tinyurl.com/qrt5bjp
nonetheless soundcloud > https://tinyurl.com/yc98l8s5
racks > http://tinyurl.com/p4clpyp
HIMA
Post by HIMA » Fri Aug 31, 2018 6:44 am
any idea when Schneiders can expect a new batch?
The Book of Bad Ideas - A compendium of knowledge from Muffs. Download it here: http://bit.ly/1oz2zaI
lohacker
Post by lohacker » Fri Aug 31, 2018 7:35 am
HIMA wrote:any idea when Schneiders can expect a new batch?
I've asked them yesterday, probably mid september but this is not confirmed yet
os
Post by os » Tue Sep 04, 2018 5:57 am
Firmware v4.8 beta is available - please test if you use the SD card algorithms:
viewtopic.php?p=2900879#2900879
Also, here's a teaser video:
SCOOBA_TANK
Post by SCOOBA_TANK » Wed Sep 05, 2018 3:59 am
os wrote:Firmware v4.8 beta is available - please test if you use the SD card algorithms:
Wait. No more playlists?!? How does the file structure work?
os
Post by os » Wed Sep 05, 2018 4:00 am
WAV files in folders. Each algorithm can switch between folders (on a parameter).
SCOOBA_TANK
Post by SCOOBA_TANK » Wed Sep 05, 2018 4:05 am
os wrote:WAV files in folders. Each algorithm can switch between folders (on a parameter).
That’s awesome!!! Thanks. I always had such a hard time getting the playlists to work properly that i never bothered to use the SD algorithms at all. Now this opens up a whole new world!!
nedrush
Post by nedrush » Thu Sep 06, 2018 6:00 am
I’ve been following the info with this update but I’m getting a bit confused about not needing playlists anymore. What do I do with my loops that have different clock speeds for my clocked audio playback? Just keep using he same playlist?
os
Post by os » Thu Sep 06, 2018 6:04 am
Yes. Playlists still work - they're just optional now.
nedrush
Post by nedrush » Thu Sep 06, 2018 7:44 am
That’s good to know.
But out of interest, if you aren’t using playlists, then how do files work without them in modes like the clocked audio playback which relies on information in the playlist?
os
Post by os » Thu Sep 06, 2018 7:54 am
The files use default settings (which is 4 clocks per sample IIRC).
nedrush
Post by nedrush » Thu Sep 06, 2018 8:39 am
Would there be a way to set/change that default?
os
Post by os » Thu Sep 06, 2018 8:40 am
matcsat
Post by matcsat » Thu Sep 06, 2018 10:58 am
Hi,
is there a chances for an algorithm that emulate the Buchla 256e control voltage processor ?
The screen would be a bless for the breackpoint part of the operation.
The encoder and knob with pushbutton capability also fitt well with this purpouse.
The crossfader section is not important.
Here a quick explanation of the Buchla 256e.
I'm not an owner of the disting (yet), just checking.
Thanks in advance.
Marco.
matcsat
Post by matcsat » Thu Sep 06, 2018 1:34 pm
Hi,
ops. I saw now the discussion about feature request in the expert sleepers forum section.
Sorry for posting in the wrong place.
I'll post there.
Marco.
DJ_JITTER
Post by DJ_JITTER » Thu Sep 06, 2018 3:52 pm
Naenyn wrote:Can the Disting do gate logic? Something like...
X = A OR B
Y = A AND B
... etc
It doesn't seem like it... was a bit surprised when I went looking for that functionality and couldn't find it.
Isn't this doable with A4 Min/Max? Min is an AND gate and max is an OR gate.
Edit:
Yeah, works well for gates
akrenaut
Post by akrenaut » Fri Sep 07, 2018 7:52 pm
Thank you for this latest firmware. I'm testing it now. Samples in a folder without the need for a text file is great.
phutureboy
Post by phutureboy » Sun Sep 09, 2018 5:25 am
Hi OS, any chance the Dual Euclidean Patterns mode could have an internal/external clock switch ? plus ideally BPM/clock rate assigned to a pot.
FS: EMS Analyse Filterbank B1-II | EMS AKS | RSF Expander I & II | PEARL Syncussion SY-1 | KORG MS-20 | KORG SQ-10
os
Post by os » Mon Sep 10, 2018 12:16 pm
@phutureboy Have a look at the FH-2!
Also, in other news:
REVIVER
Post by REVIVER » Mon Sep 10, 2018 12:18 pm
Sample crossfading?
:hmm:
:eek:
mckenic
pew!pew!pew!kthnxbye!
Post by mckenic » Mon Sep 10, 2018 12:26 pm
Jesus!
bemushroomed
Post by bemushroomed » Mon Sep 10, 2018 2:02 pm
Very nice addition :party: :hyper:
