Expert Sleepers Disting Mk4
deft_bonz
Re: Expert Sleepers Disting Mk4
Post by deft_bonz » Fri Dec 04, 2020 3:58 am
xxeyes wrote:
Thu Dec 03, 2020 11:32 pm
I need a stereo preamp in my system. It seems like mode E-4 Stereo Compressor should work for this if I set the z knob fully Counterclockwise for no compression. However, the output sounds very different than the input - maybe compressed? I don’t know; it sounds kind of lo-fi and has a slight echo. I can’t seem to get clean amplification no matter what settings I try. Should this be possible? Can anyone tell me how I might achieve clean stereo amplification with this mode or another?
Do you need the preamp for mics or line level signals from external instruments? Mic signals are very low, you'd need a proper analog preamp to get a line level signals. Then with line level signals, you have to consider that they are normally lower than modular signals. Don't know if the Disting will have enough gain to compensate for that with the make-up gain alone within the compressor function. It might be not enough depending on how low your line level signal is. For modular signal it should be enough. It has 36dB of make up gain.
xxeyes
Post by xxeyes » Fri Dec 04, 2020 8:05 am
os wrote:
Fri Dec 04, 2020 3:23 am
Preamplification should be done in the analogue domain, otherwise you're just amplifying digital noise.
You could try 'E-5 Side-chain Compressor' with Z at zero (mid-range) and use the make-up gain to boost the signal.
Thanks, I’ll give that a try.
xxeyes
Post by xxeyes » Fri Dec 04, 2020 8:13 am
I’m using it to boost stereo field recordings from my Zoom H1N to modular levels. The make-up gain in E-4 is sufficient and the amplification of digital noise isn’t too bad. The problem is that the resulting sound is kind of hollow and has an echo. I’m not sure why this is the case since I have the Z knob fully counterclockwise for no compression.
deft_bonz
Post by deft_bonz » Fri Dec 04, 2020 8:22 am
Can it be, that it mono's the stereo signal and thus creates that "hollow" sound? I'm not sure, if the Disting processes true stereo. What happens if you listen back to the Zoom signal mono'd? A lot of analog mixer feature such a button to check mono compatibility. Or you can import the Zoom recording into a DAW and sum it there to mono.
Post by os » Fri Dec 04, 2020 8:24 am
The stereo compressors on the disting are true stereo.
deft_bonz
Post by deft_bonz » Fri Dec 04, 2020 8:40 am
Good to know, thanks. Got to try that once.
I've looked it up in the manual. Out of curiosity: How is the detection signal generated? Both channels summed, only one channel, or both chhanels independently detected?
Then something else is happening somewhere, or the recorded sound is already off, or somewhere on the signal path one side gets phase reversed, or cable defect, etc. Stereo recordings can get messy when one side gets screwed. The wider they are, the worse they can get.
xxeyes
Post by xxeyes » Fri Dec 04, 2020 9:21 am
Fixed! It was just a cable issue. I was stupidly plugging a stereo cable directly into the Disting to test it while I wait for my stereo breakout cable to arrive. I figured I would just get a mono signal because this works fine with all my other modules without distortion. However, I guess the unique light-up Disting jacks won’t accept a stereo cable as mono in the same way.
Thanks for the help os and deft_bonz.
Post by os » Fri Dec 04, 2020 9:28 am
This is nothing to do with the sockets. A TRS/stereo 3.5mm plug inserted into a TS socket is connecting the plug ring to ground, and the cable ground to nothing. I.e. badness.
xxeyes
Post by xxeyes » Fri Dec 04, 2020 9:37 am
Ah ok, thanks.
escargot
Post by escargot » Sat Dec 05, 2020 8:04 pm
Os would it be possible to get a stereo EG+vca preset? Thanks
mcpepe
Post by mcpepe » Sat Dec 26, 2020 6:21 pm
All my wav files loop in all the wav playback algorithms I have tried. Also the dual wav players, but they all loop my files. Why?
I have also tried using a playlist, with no success. This was the simple playlist.txt content:
disting playlist v1
-loop=0
I am running the latest firmware 4.17. Can you help me?
mister_wavey
Post by mister_wavey » Mon Dec 28, 2020 4:57 pm
can you confirm you didn't accidentally create playlist.txt.txt ? this is a common error on OSs that hide the extension.
OptionalVolcano
Post by OptionalVolcano » Tue Dec 29, 2020 5:04 am
I have the same problem. The order in which I put the samples in the playlist is ignored too. Made the file in notepad on win10, did not copy lines from the manual but typed it myself. I'm positive I don't have a double .txt in there.
mcpepe
Post by mcpepe » Tue Dec 29, 2020 5:32 am
Thanks for the help. I did check it and my file is playlist.txt, looking at its properties.
In the Expert Sleepers forum someone told me to make the file with Sublime text, to have a clean txt file. I am going to try it and I will report back.
mister_wavey
Post by mister_wavey » Tue Dec 29, 2020 6:43 am
other problems have included the wrong encoding - ensure it is UTF-8 (win notepad shows the encoding in the bottom right corner) and sublime text lets you choose encoding with File | Save With Encoding to be sure.
mcpepe
Post by mcpepe » Tue Dec 29, 2020 7:21 am
Using Sublime Text did work!. Thanks! :yay:
lazze
Expert Sleepers Disting Mk4 firmware update
Post by lazze » Sat Jan 02, 2021 4:05 pm
i wanted to update my disting and found out taht tehre ist a version 4.10.2 on my disting mk4.1
when i try to update a firmware before 4.15 like written in the manual, holding s-knob while starting – it doesnt ask for confirm. it starts after the vertical/horizontal line to fully blink and shows success. BUT when i reboot there is still the old system...
any idea ?
mother misty
Re: Expert Sleepers Disting Mk4 firmware update
Post by mother misty » Sat Jan 02, 2021 4:22 pm
any idea ?
I had a similar problem a while ago, I think you have to upgrade the bootloader to b2 first if you're only on 4.10.2 (see manual / firmware updates)
tdallas
Post by tdallas » Sun Jan 03, 2021 6:01 am
any idea ?
Would you like to update to 1.) a newer/equal or 2.) an older version than 4.15? In case of the first scenario you have to update the bootloader first as described on the Expert Sleepers firmware homepage below the 4.15 section -> https://www.expert-sleepers.co.uk/dist ... dates.html. After that you can install 4.15+ versions.
But in general I have never seen a update process without a initial „confirm“ dialog on my module.
Edit: stupid idea -> is it possible, that you still have the old/initial firmware file stored at your SD card and therefore flashed it to the already installed version (happened to me once because I missed to replace the file on the card) ;)
Righty
Post by Righty » Sun Jan 03, 2021 5:50 pm
Yes, it can do everything, but can the guy hire someone who has skills in writing clearly and another person to check him on his internal consistency on how this thing functions? It is a usability nightmare. He simply has no skills in anything to do with a user interface or manual writing. Again, yes, yes it can do everything, but that does not mean it inherently has to be this bad. It violates myriad usability and human factors principles. it is clearly the product of someone who has zero competency in usability and human factors. It doesn't have to be a clusterf%&k to use. Steve Jobs would have a stroke if he used a Disting. If Steve Jobs was running this company he would blow out his vocal chords screaming about the disting's user interface.
depth20
Post by depth20 » Sun Jan 03, 2021 7:03 pm
Well, that was a really rude and unhelpful post. On the contrary I find the manual pretty clear if you take your time to read it and everything work as stated. 90% of the questions here are clearly stated in the manual. There are even a bunch of youtube videos explaining most of the algorithms.
I don't see how it would be possible to make the module "easier" to understand without making it four times wider with a big screen, but that's not something I would want at least.
rayultine
Post by rayultine » Sun Jan 03, 2021 7:11 pm
lol poor Righty trying to hammer anything that looks like a nail
tdallas
Post by tdallas » Mon Jan 04, 2021 3:29 am
I guess Steve Jobs would also explode about the actual „design“ state of Apple. And if Apple was running this company you would have to buy an adapter for every single jack (not included, if not working „you plugged it in wrong“), audio/power is wireless only, the front panel would be made by glass and the price is at least tripled. The Disting is small, the manual is big. If you want a better UI go for the EX. There are far worse designed modules / written manuals (if available at all) out there IMHO :hide:
Risc_Terilia
Post by Risc_Terilia » Mon Jan 04, 2021 8:50 am
Is this copypasta? :hihi:
Byzero
Post by Byzero » Mon Jan 04, 2021 9:23 am
Has anyone managed to record V/oct CV using J-5 Audio Recorder successfully?
I've got a V/oct CV going into X and coming out from A controlling the pitch of the VCO. Unfortunately the pitch doesn't appear to track. I've measured the voltage going into X and coming out of A and there appears to be drift.
Is the drift expected? Is what I am trying to do not feasible?
I've also posted the Q in the ES forum (viewtopic.php?f=35&t=242601) but thought someone here might have experience with it.
Latest music:
