Expert Sleepers Disting Mk4
Re: Expert Sleepers Disting Mk4
Happiness :-)
Is there a way of getting (possibly clocked) random voltage like from a Doepfer A-118 from the Disting Mk4?
ops... wrong thread
And what's crazy is for 75%+ of its algorithms, it's still a very cost effective module even if you did dedicate it to a single function.
Hear my music at my Bandcamp site: E T H E R D I V E R
Look at pictures of my synths and tape recorders and hear the sounds at my Instagram
- mosorensen
- Wiggling with Experience
^ This. I may have used only a total of 10 different algorithms on my Disting (in actual patches, other than just playing around with it), but those ten algorithms alone make it totally worth it.
- Common Wiggler
@os: Bit off-topic, but discovered your band 'Darkroom' because of your product-placement blank panels.
Very nice.
Loving the contrabass clarinet. You do like your low notes.
Now I understand why you demoed the audio-to-CV convertor with clarinet sounds.
Bet it would struggle with the bottom notes.
Very nice.
Please see this post viewtopic.php?f=35&t=244394#p3456749 about a charity fundraiser we're running, auctioning some very rare disting mk4s.
I've used close to half, although a lot of those were just like, "Well, let's see what *this* does..." rather than an actual need. On a day-to-day basis I use like 6-10 algos on the regular, but it's really great knowing all that other stuff is there when I need it. Like the other day, I realized I needed a compressor to get some stuff to sit correctly and, hey, Disting has a compressor!mosorensen wrote: ↑Tue Feb 02, 2021 6:06 pm^ This. I may have used only a total of 10 different algorithms on my Disting (in actual patches, other than just playing around with it), but those ten algorithms alone make it totally worth it.
The auctions are now live for the limited edition sterling silver disting mk4s, in support of Help Musicians.
http://www.ebay.co.uk/itm/393133720829
http://www.ebay.co.uk/itm/393133721986
http://www.ebay.co.uk/itm/393133723742
http://www.ebay.co.uk/itm/393133729577
http://www.ebay.co.uk/itm/393133735111
- megarat
- Veteran Wiggler
Does anyone know what kind of knobs are used on the Disting Mk. 4? I scratched up one of mine pretty severely during a panel-swap and I'd like to get another. I know that most knobs fit for a 6mm splined shaft will work, but I'd rather get an original if possible.
- megarat
- Veteran Wiggler
Many thanks.os wrote: ↑Tue Feb 23, 2021 3:43 amIt's a Cliff FC7229NML.
https://www.cliffuk.co.uk/products/knob ... .htm#kmr12
